determined_weasel 0 Posted ... Hello, DNS lookups to AWS seem to be failing for me, see below. It works with Google's DNS server but not using the AirVPN ones. Any ideas why? DNS lookups to other websites seem to work fine. :~$ nslookup sqs.eu-west-1.amazonaws.com 8.8.8.8 Server: 8.8.8.8 Address: 8.8.8.8#53 Non-authoritative answer: sqs.eu-west-1.amazonaws.com canonical name = eu-west-1.queue.amazonaws.com. Name: eu-west-1.queue.amazonaws.com Address: 52.95.112.152 :~$ nslookup sqs.eu-west-1.amazonaws.com 10.9.100.1 Server: 10.9.100.1 Address: 10.9.100.1#53 ** server can't find sqs.eu-west-1.amazonaws.com: SERVFAIL :~$ nslookup sqs.eu-west-1.amazonaws.com 10.4.0.1 Server: 10.4.0.1 Address: 10.4.0.1#53 ** server can't find sqs.eu-west-1.amazonaws.com: SERVFAIL Quote Share this post Link to post
Tech Jedi Alex 1528 Posted ... I think there are similarities to the IMDb case (also Amazon). I get the same error from Kitalpha. ISP resolves fine, though. ViewDNS report outputs two problematic areas: FAILED Missing NS records at parent servers Oops! It appears that the following nameserves listed at your local servers are not listed at the parent servers: PDNS1.ultradns.net. PDNS2.ultradns.net. PDNS3.ultradns.org. You should ensure that these nameservers are valid and working. If they are not, you will encounter connectivity issues with your domain. --- FAILED Missing NS records at local servers Oops! It appears that the following nameserves listed at the parent servers are not listed at your local servers: pdns1.ultradns.net. pdns2.ultradns.net. pdns3.ultradns.org. You should ensure that these nameservers are valid and working. If they aren't, it can cause odd behaviour including some people not being able to access your domain. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10493 Posted ... Hello, the problem seems to be intermittently even worse: as you can see you often get SERVFAIL, i.e. a failure of the authoritative DNS servers. Normally a SERVFAIL means that the authoritative DNS server is down or refuses connections from our DNS servers, we will investigate. Kind regards Quote Share this post Link to post
airer 0 Posted ... I have same intermittent SERVFAIL issue when trying to browse to www.amazon.com (Other sites resolve without problems) > www.amazon.com ;; Got SERVFAIL reply from 10.4.0.1, trying next server Server: 10.4.0.1 Address: 10.4.0.1#53 ** server can't find www.amazon.com: NXDOMAIN > www.yahoo.com Server: 10.4.0.1 Address: 10.4.0.1#53 Non-authoritative answer: www.yahoo.com canonical name = atsv2-fp-shed.wg1.b.yahoo.com. Name: atsv2-fp-shed.wg1.b.yahoo.com Address: 87.248.98.8 Name: atsv2-fp-shed.wg1.b.yahoo.com Address: 87.248.98.7 Quote Share this post Link to post
