aquadesh 0 Posted ... Hi, I bought AirVPN so i can use the port forwarding functionality but its not working:(I am trying to get it working but until now i have no luck. I opened port 45080 TCP & UDP. When i check it i get error 110 not reachable o.n server IP over the external port 45080 tcp Protocol. I dont know what i need to do to get it working?I hope someone can help me Quote Share this post Link to post
Staff 10387 Posted ... Hello! IPlease make sure that the listening service is really running and listening to the correct port, and that no firewall blocks packets to/from the service while the system si connected to the VPN. Note: we assumed that the listening service runs in the same machine that connects to the VPN: if that's not the case an additional step is required, you need to forward packets from the tun interface of the connected device to the final machine running the service. Kind regards Quote Share this post Link to post
