Gεεk 0 Posted ... Hey I can`t use Airvpn since a Week. I dont know why but nothing works and I`m not able to connect. What I tryed so far: ReinstallAdapter Reinstall - The first Connection works but same issue after that.Disable ipv6Disable Bitdefender (Security Suit)Deinstall BitdefenderDisable Windows Firewall . 2018.09.09 14:44:09 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319 . 2018.09.09 14:44:09 - Reading options from C:\Users\***\AppData\Local\AirVPN\default.xml . 2018.09.09 14:44:09 - Command line arguments (1): path="home" . 2018.09.09 14:44:09 - Profile path: C:\Users\***\AppData\Local\AirVPN\default.xml . 2018.09.09 14:44:10 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 . 2018.09.09 14:44:10 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe) . 2018.09.09 14:44:10 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe) . 2018.09.09 14:44:10 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe) . 2018.09.09 14:44:10 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe) . 2018.09.09 14:44:10 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem W 2018.09.09 14:44:10 - Recovery. Unexpected crash? . 2018.09.09 14:44:11 - Routes, remove 178.162.204.238 for gateway 10.22.196.1 failed: Network interface no more available. . 2018.09.09 14:44:11 - Routes, remove 2a00:c98:2050:a02f:65dd:b463:939:a480 for gateway fde6:7a:7d20:12c4::1 failed: Network interface no more available. . 2018.09.09 14:44:11 - Routes, remove 46.21.154.83 for gateway 10.6.132.1 failed: Network interface no more available. . 2018.09.09 14:44:11 - Routes, remove 64.120.44.139 for gateway 10.4.0.1 failed: Network interface no more available. . 2018.09.09 14:44:11 - Updating systems & servers data ... I 2018.09.09 14:44:11 - Ready . 2018.09.09 14:44:11 - Systems & servers data update completed I 2018.09.09 14:47:02 - Session starting. I 2018.09.09 14:47:02 - Checking authorization ... . 2018.09.09 14:47:03 - IPv6 disabled with packet filtering. ! 2018.09.09 14:47:03 - Connecting to Chara (Netherlands, Alblasserdam) . 2018.09.09 14:47:03 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2018.09.09 14:47:03 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2018.09.09 14:47:03 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2018.09.09 14:47:03 - Connection to OpenVPN Management Interface . 2018.09.09 14:47:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2018.09.09 14:47:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.09.09 14:47:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.09.09 14:47:03 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.132:443 . 2018.09.09 14:47:03 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2018.09.09 14:47:03 - OpenVPN > UDP link local (bound): [AF_INET]192.168.*.*:1194 . 2018.09.09 14:47:03 - OpenVPN > UDP link remote: [AF_INET]109.232.227.132:443 . 2018.09.09 14:47:03 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.132:443, sid=60ead3e3 ed91d87f . 2018.09.09 14:47:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2018.09.09 14:47:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2018.09.09 14:47:03 - OpenVPN > VERIFY KU OK . 2018.09.09 14:47:03 - OpenVPN > Validating certificate extended key usage . 2018.09.09 14:47:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2018.09.09 14:47:03 - OpenVPN > VERIFY EKU OK . 2018.09.09 14:47:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2018.09.09 14:47:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2018.09.09 14:47:03 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.132:443 . 2018.09.09 14:47:04 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2018.09.09 14:47:05 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.14.0.1,dhcp-option DNS6 fde6:7a:7d20:a00::1,tun-ipv6,route-gateway 10.14.0.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:a00::108c/64 fde6:7a:7d20:a00::1,ifconfig 10.14.0.142 255.255.255.0,peer-id 15,cipher AES-256-GCM' . 2018.09.09 14:47:05 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2018.09.09 14:47:05 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:a00::1' . 2018.09.09 14:47:05 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2018.09.09 14:47:05 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:a00::108c/64 fde6:7a:7d20:a00::1' . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: peer-id set . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2018.09.09 14:47:05 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2018.09.09 14:47:05 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2018.09.09 14:47:05 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2018.09.09 14:47:05 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2018.09.09 14:47:05 - OpenVPN > interactive service msg_channel=0 . 2018.09.09 14:47:05 - OpenVPN > ROUTE_GATEWAY 192.168.*.*/255.255.255.0 I=14 HWADDR=78:24:af:32:f7:67 . 2018.09.09 14:47:05 - OpenVPN > open_tun . 2018.09.09 14:47:05 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{78FA0686-A69C-4D3A-AAFC-03193D605136}.tap . 2018.09.09 14:47:05 - OpenVPN > TAP-Windows Driver Version 9.21 . 2018.09.09 14:47:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.14.0.0/10.14.0.142/255.255.255.0 [SUCCEEDED] . 2018.09.09 14:47:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.14.0.142/255.255.255.0 on interface {78FA0686-A69C-4D3A-AAFC-03193D605136} [DHCP-serv: 10.14.0.254, lease-time: 31536000] . 2018.09.09 14:47:05 - OpenVPN > Successful ARP Flush on interface [10] {78FA0686-A69C-4D3A-AAFC-03193D605136} . 2018.09.09 14:47:05 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0 . 2018.09.09 14:47:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:10 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:14 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:15 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:15 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:16 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:16 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:16 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:18 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:19 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:20 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:21 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:22 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:24 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:25 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:26 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:27 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:29 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:30 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:31 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:33 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:34 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:35 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:36 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:37 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:38 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:47:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.232.227.132 MASK 255.255.255.255 192.168.*.* . 2018.09.09 14:47:39 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4 . 2018.09.09 14:47:39 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2018.09.09 14:47:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.14.0.1 W 2018.09.09 14:47:39 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.14.0.1 . 2018.09.09 14:47:39 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2018.09.09 14:47:39 - OpenVPN > Route addition fallback to route.exe . 2018.09.09 14:47:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2018.09.09 14:47:39 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.14.0.1 W 2018.09.09 14:47:39 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.14.0.1 . 2018.09.09 14:47:39 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2018.09.09 14:47:39 - OpenVPN > Route addition fallback to route.exe . 2018.09.09 14:47:39 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2018.09.09 14:47:39 - OpenVPN > SYSTEM ROUTING TABLE . 2018.09.09 14:47:39 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.*.* p=0 i=14 t=4 pr=3 a=10984 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 0.0.0.0 128.0.0.0 10.14.0.1 p=0 i=14 t=4 pr=3 a=0 h=0 m=26/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 109.232.227.132 255.255.255.255 192.168.*.* p=0 i=14 t=4 pr=3 a=0 h=0 m=25/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10986 h=0 m=331/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10986 h=0 m=331/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10986 h=0 m=331/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 128.0.0.0 128.0.0.0 10.14.0.1 p=0 i=14 t=4 pr=3 a=0 h=0 m=26/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.37.108 p=0 i=10 t=3 pr=2 a=10974 h=0 m=291/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 169.254.37.108 255.255.255.255 169.254.37.108 p=0 i=10 t=3 pr=2 a=10974 h=0 m=291/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.37.108 p=0 i=10 t=3 pr=2 a=10974 h=0 m=291/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 192.168.*.* 255.255.255.0 192.168.*.* p=0 i=14 t=3 pr=2 a=10980 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 192.168.*.* 255.255.255.255 192.168.*.* p=0 i=14 t=3 pr=2 a=10980 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 192.168.*.255 255.255.255.255 192.168.*.* p=0 i=14 t=3 pr=2 a=10980 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=10986 h=0 m=331/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.37.108 p=0 i=10 t=3 pr=2 a=10984 h=0 m=291/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.*.* p=0 i=14 t=3 pr=2 a=10984 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=10986 h=0 m=331/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.37.108 p=0 i=10 t=3 pr=2 a=10984 h=0 m=291/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.*.* p=0 i=14 t=3 pr=2 a=10984 h=0 m=281/0/0/0/0 . 2018.09.09 14:47:39 - OpenVPN > SYSTEM ADAPTER LIST . 2018.09.09 14:47:39 - OpenVPN > Intel(R) Ethernet Connection (2) I218-V . 2018.09.09 14:47:39 - OpenVPN > Index = 14 . 2018.09.09 14:47:39 - OpenVPN > GUID = {B15FF737-25A6-4F2B-815A-2C7289D2E7EC} . 2018.09.09 14:47:39 - OpenVPN > IP = 192.168.*.*/255.255.255.0 . 2018.09.09 14:47:39 - OpenVPN > MAC = 78:24:af:32:f7:67 . 2018.09.09 14:47:39 - OpenVPN > GATEWAY = 192.168.*.*/255.255.255.255 . 2018.09.09 14:47:39 - OpenVPN > DNS SERV = 8.8.8.8/255.255.255.255 8.8.4.4/255.255.255.255 . 2018.09.09 14:47:39 - OpenVPN > Kaspersky Security Data Escort Adapter . 2018.09.09 14:47:39 - OpenVPN > Index = 9 . 2018.09.09 14:47:39 - OpenVPN > GUID = {73432A96-3BCC-4093-A186-C4134862C885} . 2018.09.09 14:47:39 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2018.09.09 14:47:39 - OpenVPN > MAC = 00:ff:73:43:2a:96 . 2018.09.09 14:47:39 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2018.09.09 14:47:39 - OpenVPN > DHCP SERV = . 2018.09.09 14:47:39 - OpenVPN > DHCP LEASE OBTAINED = Sun Sep 09 14:47:39 2018 . 2018.09.09 14:47:39 - OpenVPN > DHCP LEASE EXPIRES = Sun Sep 09 14:47:39 2018 . 2018.09.09 14:47:39 - OpenVPN > DNS SERV = . 2018.09.09 14:47:39 - OpenVPN > TAP-Windows Adapter V9 . 2018.09.09 14:47:39 - OpenVPN > Index = 10 . 2018.09.09 14:47:39 - OpenVPN > GUID = {78FA0686-A69C-4D3A-AAFC-03193D605136} . 2018.09.09 14:47:39 - OpenVPN > IP = 169.254.37.108/255.255.0.0 . 2018.09.09 14:47:39 - OpenVPN > MAC = 00:ff:78:fa:06:86 . 2018.09.09 14:47:39 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2018.09.09 14:47:39 - OpenVPN > DHCP SERV = 0.0.0.0/255.255.255.255 . 2018.09.09 14:47:39 - OpenVPN > DHCP LEASE OBTAINED = Sun Sep 09 14:47:39 2018 . 2018.09.09 14:47:39 - OpenVPN > DHCP LEASE EXPIRES = Sun Sep 09 14:47:39 2018 . 2018.09.09 14:47:39 - OpenVPN > DNS SERV = . 2018.09.09 14:47:39 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv4 . 2018.09.09 14:47:39 - Interface Ethernet 3 metric changed from Automatic to 3, layer IPv6 . 2018.09.09 14:47:39 - DNS leak protection with packet filtering enabled. . 2018.09.09 14:47:40 - DNS IPv4 of a network adapter forced (Ethernet 3, from automatic to 10.14.0.1) . 2018.09.09 14:47:40 - Routes, added a new route, 109.232.227.133 for gateway 10.14.0.1 . 2018.09.09 14:47:40 - Unable to compute route for 2a00:1678:2470:14:8b1f:21a6:b646:bf3d: IPv6 VPN gateway not available. . 2018.09.09 14:47:40 - Flushing DNS . 2018.09.09 14:47:43 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) ! 2018.09.09 14:47:43 - Disconnecting . 2018.09.09 14:47:43 - Routes, removed a route previously added, 109.232.227.133 for gateway 10.14.0.1 . 2018.09.09 14:47:43 - Sending management termination signal . 2018.09.09 14:47:43 - Management - Send 'signal SIGTERM' . 2018.09.09 14:47:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2018.09.09 14:47:43 - OpenVPN > SIGTERM received, sending exit notification to peer . 2018.09.09 14:47:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.232.227.132 MASK 255.255.255.255 192.168.*.* . 2018.09.09 14:47:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2018.09.09 14:47:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.14.0.1 W 2018.09.09 14:47:49 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.14.0.1 . 2018.09.09 14:47:49 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2018.09.09 14:47:49 - OpenVPN > Route deletion fallback to route.exe . 2018.09.09 14:47:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2018.09.09 14:47:49 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.14.0.1 W 2018.09.09 14:47:49 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.14.0.1 . 2018.09.09 14:47:49 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2018.09.09 14:47:49 - OpenVPN > Route deletion fallback to route.exe . 2018.09.09 14:47:49 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2018.09.09 14:47:49 - OpenVPN > Closing TUN/TAP interface . 2018.09.09 14:47:49 - OpenVPN > TAP: DHCP address released . 2018.09.09 14:47:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2018.09.09 14:47:49 - Connection terminated. . 2018.09.09 14:47:49 - IPv6 restored with packet filtering. . 2018.09.09 14:47:49 - DNS IPv4 of a network adapter restored to original settings (Ethernet 3, to automatic) . 2018.09.09 14:47:49 - DNS leak protection with packet filtering disabled. . 2018.09.09 14:47:49 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv4 . 2018.09.09 14:47:49 - Interface Ethernet 3 metric restored from 3 to Automatic, layer IPv6 I 2018.09.09 14:47:52 - Checking authorization ... . 2018.09.09 14:47:52 - IPv6 disabled with packet filtering. ! 2018.09.09 14:47:52 - Connecting to Ursa (United States, Atlanta, Georgia) . 2018.09.09 14:47:52 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2018.09.09 14:47:52 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2018.09.09 14:47:52 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2018.09.09 14:47:52 - Connection to OpenVPN Management Interface . 2018.09.09 14:47:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2018.09.09 14:47:52 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.09.09 14:47:52 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2018.09.09 14:47:52 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]64.42.179.50:443 . 2018.09.09 14:47:52 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2018.09.09 14:47:52 - OpenVPN > UDP link local (bound): [AF_INET]192.168.*.*:1194 . 2018.09.09 14:47:52 - OpenVPN > UDP link remote: [AF_INET]64.42.179.50:443 . 2018.09.09 14:47:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2018.09.09 14:47:52 - OpenVPN > TLS: Initial packet from [AF_INET]64.42.179.50:443, sid=1598e94c c40d26fe . 2018.09.09 14:47:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2018.09.09 14:47:52 - OpenVPN > VERIFY KU OK . 2018.09.09 14:47:52 - OpenVPN > Validating certificate extended key usage . 2018.09.09 14:47:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2018.09.09 14:47:52 - OpenVPN > VERIFY EKU OK . 2018.09.09 14:47:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Ursa, emailAddress=info@airvpn.org . 2018.09.09 14:47:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2018.09.09 14:47:53 - OpenVPN > [Ursa] Peer Connection Initiated with [AF_INET]64.42.179.50:443 . 2018.09.09 14:47:54 - OpenVPN > SENT CONTROL [Ursa]: 'PUSH_REQUEST' (status=1) . 2018.09.09 14:47:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.23.128.1,dhcp-option DNS6 fde6:7a:7d20:1380::1,tun-ipv6,route-gateway 10.23.128.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1380::10e1/64 fde6:7a:7d20:1380::1,ifconfig 10.23.128.227 255.255.255.0,peer-id 8,cipher AES-256-GCM' . 2018.09.09 14:47:54 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2018.09.09 14:47:54 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:1380::1' . 2018.09.09 14:47:54 - OpenVPN > Pushed option removed by filter: 'tun-ipv6' . 2018.09.09 14:47:54 - OpenVPN > Pushed option removed by filter: 'ifconfig-ipv6 fde6:7a:7d20:1380::10e1/64 fde6:7a:7d20:1380::1' . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: peer-id set . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2018.09.09 14:47:54 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2018.09.09 14:47:54 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2018.09.09 14:47:54 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2018.09.09 14:47:54 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2018.09.09 14:47:54 - OpenVPN > interactive service msg_channel=0 . 2018.09.09 14:47:54 - OpenVPN > ROUTE_GATEWAY 192.168.*.*/255.255.255.0 I=14 HWADDR=78:24:af:32:f7:67 . 2018.09.09 14:47:54 - OpenVPN > open_tun . 2018.09.09 14:47:54 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{78FA0686-A69C-4D3A-AAFC-03193D605136}.tap . 2018.09.09 14:47:54 - OpenVPN > TAP-Windows Driver Version 9.21 . 2018.09.09 14:47:54 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.23.128.0/10.23.128.227/255.255.255.0 [SUCCEEDED] . 2018.09.09 14:47:54 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.23.128.227/255.255.255.0 on interface {78FA0686-A69C-4D3A-AAFC-03193D605136} [DHCP-serv: 10.23.128.254, lease-time: 31536000] . 2018.09.09 14:47:54 - OpenVPN > Successful ARP Flush on interface [10] {78FA0686-A69C-4D3A-AAFC-03193D605136} . 2018.09.09 14:47:54 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0 . 2018.09.09 14:47:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:47:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:47:59 - Eddie Windows Interface Hack executed (Ethernet 3) ! 2018.09.09 14:48:01 - Disconnecting . 2018.09.09 14:48:01 - Sending management termination signal . 2018.09.09 14:48:01 - Management - Send 'signal SIGTERM' . 2018.09.09 14:48:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2018.09.09 14:48:01 - OpenVPN > SIGTERM received, sending exit notification to peer . 2018.09.09 14:48:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:48:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:48:01 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:48:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:48:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:48:02 - Eddie Windows Interface Hack executed (Ethernet 3) . 2018.09.09 14:48:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=-1 ret=0 a=0 u/d=down . 2018.09.09 14:48:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2018.09.09 14:48:03 - Eddie Windows Interface Hack executed (Ethernet 3) Quote Share this post Link to post
Staff 10331 Posted ... Hello! The tun/tap interface, i.e. the virtual network adapter used by OpenVPN, does not come up.Please try the following:- make sure that no anvirus/antimalware tool is interfering- shut down the Air client software- right-click and run the "Start-->Tap-Windows-->Delete ALL TAP virtual ethernet adapters" as administrator- reboot the system- right-click and run as administrator "Start-->Tap-Windows-->Add a new TAP virtual ethernet adapter"- start Eddie and test again connections to various servers in different locations.Kind regards Quote Share this post Link to post
Gεεk 0 Posted ... Thanks 4 your fast reply Done it - but same result. The first Connection works but the second is broken again. Quote Share this post Link to post
Gεεk 0 Posted ... It looks like my new Security Suit "Bitdefender" damaged somethin on my Computers. Its the same Bug on all of them. But even if I Uninstall Bitdefender the issue is still there - But I cant reinstall all my Computer and Servers :/ Quote Share this post Link to post
Staff 10331 Posted ... Hello, if this is confirmed, it should be brought to the attention of Bitdefender and its users, as well as our customers and in general OpenVPN users or any user needing the tun/tap interface in Windows. We would recommend that you contact their customer support service for further investigation and troubleshooting. Kind regards Quote Share this post Link to post
Flx 77 Posted ... The tun/tap interface, i.e. the virtual network adapter used by OpenVPN, does not come up.Your firewall is blocking the MAC address of the TAP-Adapter and that is why you get that message and your set IP 169.x.x.xFind a way to allow TAP.mac addresses for Bit defender.This is how you do it in COMODO---->>>>https://airvpn.org/uploads/monthly_02_2018/post-98252-0-25036500-1518043235_thumb.jpgFix for TAP adapter in Windows - General & Suggestions - AirVPN<<<----See this.Regards,Flx Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
Flx 77 Posted ... To be more specific ---->>>https://airvpn.org/topic/17440-guide-fix-for-tap-adapter-in-windows/?do=findComment&comment=69262Good Luck & Regards,Flx Quote Hide Flx's signature Hide all signatures Guide - EMBY Block ALL interfaces except tap/vpn Windows OS - Configuring your operating system Windows OS - Multi Session/Tunnel Share this post Link to post
