ahoneybadger 0 Posted ... Im having a lot of trouble getting this to work. It says initialization complete but I cant get the actual traffic to flow, I think its just the routing thats causing problems, Im not really sure how to go about doing this so if anyone has any idea what to do its appreciated. Quote Share this post Link to post
Staff 10565 Posted ... Im having a lot of trouble getting this to work. It says initialization complete but I cant get the actual traffic to flow, I think its just the routing thats causing problems, Im not really sure how to go about doing this so if anyone has any idea what to do its appreciated.Hello!Can you please describe your setup (host machine, virtual guest, VirtualBox networking configuration)?Kind regards Quote Share this post Link to post
ahoneybadger 0 Posted ... The host machine is a macbook pro running lion. the network settings on the pfsense is nat and internal network, and the network on the VM is just internal network. I seem to have most things configured as the vpn seems to be initializing but the routing seems to be the only problem. Quote Share this post Link to post
Staff 10565 Posted ... The host machine is a macbook pro running lion. the network settings on the pfsense is nat and internal network, and the network on the VM is just internal network. I seem to have most things configured as the vpn seems to be initializing but the routing seems to be the only problem.Hello!If you don't have particular bridging needs, a tested and working configuration is to set NAT in the networking option of VirtualBox for that guest. After that, you can choose to connect to the VPN the host (so that all the virtual machines will use transparently the VPN tunnel) or the guest only. NAT in VB fully supports port forwarding, so you can forward the remotely forwarded ports to your VMs as well.Kind regards Quote Share this post Link to post
ahoneybadger 0 Posted ... Sadly, I do need pfSense because I have to add custom firewall rules and other things like that. Quote Share this post Link to post
