squibble
Eddie freezing on linux and dns leak
I had this happen a couple times, and wondered if anyone else has experienced it.
I was using airvpn with network lock and bittorrent on linux mint when eddie would disconnect, and then reconnect to another server.  It looked like it was working but when I went to click on any tabs in eddie i noticed it was frozen and stopped responding.  The second time it happened i checked ipleak.net before force closing eddie and it showed my dns was leaking..
What version of Eddie are you using? You can go to Eddies menu>About.
I have been having the same problem recently. I use linux mint. I have tried reinstalling my entire OS yet once every few days Eddie freezes and I am still connected to Air server but my DNS is leaking.
Also keep getting disconnected and reconnected more frequently then ever, especially Netherlands servers.
Welcome, I see you're new.
We can't help you with any of that, if you don't supply any information to us . So I can only recommend that you either share your Eddie logs, try the Beta Eddie client or both.
For information on how to do that, you're welcome to follow the link in my signature, to the new user guide.
There's also no DNS leaks on Linux.
