For some time, I've been trying to better my connectivity on private trackers, but each time I try, I either get frustrated beyond all recognition and quit or screw up royally and have to resort to switching back to factory settings or having to reinstall everyone outright
Could anyone give me a "For dummies" guide on how to do port forwarding through a VPN? I've tried searching here on the forums for one, but there's a lot of terminology I don't fully understand. Can anyone give me some assistance? If you need any further info, feel free to chime in.
Client: qBittorrent 3.3.16
Frustration is normal. You can go to the New User guide in my signature and then scroll to the guides section, to find guidance on configuring torrent clients like qBittorent .
Not sure how much help you need but go to "Client Area" / "Forwarded Ports". Read the "Help". Enter a port between 49152-65534. When you find a port that works, enter that port # into qBittorrent. From what I've read, these are the best ports to use for port forwarding. Good luck.
Okay, so I've read LZ1's guide on how to do it and I'm pretty sure I followed it to a T. However, I'm still getting an error saying "Not reachable on server IP over the external port 63***, tcp protocol, Error 110: connection timed out"
I've tried this with 3 other ports all within that number range all giving me the same error message on the client page
I found this in one of the forums. It may or may not help: https://airvpn.org/topic/13768-port-forwarding-in-qbittorrent/
qBittorrent is awesome.
In Options/Connection, fill in the port you forwarded in AirVPN
Uncheck "Use UPnP"
Unhceck "Use different port on each startup"
In Options/BitTorrent, Check Enable DHT"
Uncheck "Use a different port for DHT and BitTorrent"
Check Enable Peer Exchange (PeX)
Check Enable Local Peer Discovery (optional, based on seranecks post below)
Encryption Mode: Prefer encryption
Uncheck Enable anonymous mode
Uncheck Torrent Queueing (my preference - use the entire ISP pipe for concurrent torrenting)
In Options/Advanced, ensure the "Network Interface" is set to "tun0" so it will exclusively use the AirVPN Tunnel.
(if on Windows, find the Local Area Connection number that references your tunnel adapter.  You can find this out by going to a command prompt, running ipconfig /all, and look for the adapter with the 10.x address).
Restart qBittorrent, and you should be good to go.
I was essentially able to change all settings that aren't in red. Either because I can't find them or they just don't exist in my current qBittorrent build. I tried humblegod's link for testing ports and it still says it's closed
As for dlebasC's post, he mentioned a port forwarding guide but didn't link it. I tried searching for it but no dice. Does anyone have a link?
EDIT: After much hair pulling and headbanging against my desk, I found that the culprit was my router settings and that the port wasn't open under security settings.
I feel like a bloody idiot now. Much thanks to all who gave me some guidance
Did you try updating your qBittorent client? I don't know what your OS is, but if you're using 3.3.16 you're quite far behind and that would explain the missing features.
Are you saying you forwarded ports both on your router and in your client? Be careful with that.
