Hi All,
Does anyone experience some routing problems regarding Swiss servers?
I have some of my sites routing via AirVPN but experiencing incredible lags routing via CH.
Some of your sites? Do you mean when you browse around? If you could go into more detail about your setup that would be useful.
It all looks fine according to the Status page. So is it a specific CH? Did you try other ones and maybe other protocols too? Assuming you're using the Eddie client of course .
