hostyourminer 0 Posted ... Hello, I am using an Asus RT-AC87U with AirVPN. I have a couple of problems. I wish to forward multiple :80 ports to multiple addresses, but I believe that is not directly possible. I can create the IPTABLES rules, but I can only open port 80 to the VPN if I am correct? Is there a way I can open multiple :80 ports on multiple local IPs? It doesn't really matter if I need different or new hardware. Second, my Asus router seems very instable. The speeds are slow (around 1.5mbps where I can get 300mbps without VPN), but that isn't the real problem. Every week or so, the VPN client disables itself without further notice, and I can't enable it manually, it simply never starts. The logs state nothing. The only option I found so far is to fully reset the router and setup everything from stock again, until it breaks again. Am I maybe better of using a custom (server-grade) box or router running PfSense (or similar)? Also keeping my first quesion in mind. Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... I'm wondering what you're trying to achieve. Multiple websites on one machine? Multiple webserver daemons? To mitigate the XY problem, please let us know. Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
hostyourminer 0 Posted ... I'm sorry if I wasn't clear enough. I am indeed using multiple computers as webservers to achieve a hobby project. All computers need port 80, that is the problem. I can't change the port in the webserver software, it is custom made (proprietary) software. Quote Share this post Link to post
go558a83nk 383 Posted ... AirVPN offers dynamic DNS. All you'll need to remember is the DDNS name you gave to each forwarded port. Then you can force your servers to listen on whatever port AirVPN assigns you, no need to remember the different port numbers. If you're having stability problems, then talk about it on the AsusMerlin forums. https://www.snbforums.com/forums/asuswrt-merlin.42/ Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... A proprietary webserver software with no ability to change the port it listens to? There are a few red flags. Is Apache or nginx for example not an option? Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
