Not connected, Your IP: 216.73.216.78
anonimus1105
How to connect VPN through a proxy?
How to connect VPN through a proxy? When I put in the settings vpn address and port of the proxy server, he or simply not connected, or connected, but the sites define vpn server ip, not a proxy ...
In that field you have to specify the proxy IP address, not the VPN server entry-IP address. Then you need to know whether it's an http or a SOCKS proxy (select the appropriate option).
Please do not hesitate to contact us for any further support.
I did, but the client gave the error "Failed to start". I tried to insert the IP address and then the port proxy from the list, but failed to Connect: <link removed by admin: no ads to privacy infringing VPNs allowed>
I did' date=' but the client gave the error "Failed to start". I tried to insert the IP address and then the port proxy from the list, but failed to Connect: [/quote']
Please try to delete the XML configuration file and restart the client. The file path can be found in the Air client logs. Finally, please make sure that you pick the correct proxy type (OpenVPN supports http and SOCKS proxies).
Let us know whether it fixes the problem.
I was able to connect through a proxy but the IP address of the sites see AIR VPN and not the address of the proxy server. How do get IP address of the sites have seen a proxy?
How to hide IP address of the VPN behind a proxy server?
Scrin: http://s019.radikal.ru/i624/1206/32/4cefdf8f0159.jpg
That's correct: with AirVPN over proxy, you will be visible on the Internet with the exit-IP address of the server you're connected to. For your purpose, just do not connect Air over proxy, use the proxy with a properly configured application after you have connected to Air with proxy "None".
