Been having issues connecting for the last couple of days. Managed to eventually yesterday, not sure how, but it's not working again now.
Also if I shut down AirVPN and try to just connect normally it won't, why is this? It means if AirVPN is down I can't get online at all! I'm not at all technical so sorry if I'm being slow.
I can't paste my logs as I can't get online but I did take a couple of photos with my phone if that's OK.
Edit: OK I think it's working now, think I have it figured out, but cannot figure out how to delete this thread!
You probably had Network Lock enabled and this was then shut down abnormally and thus the rules NL put in, stayed in place, thus preventing you from going online after shutting down Eddie.
I imagine you're probably using an older version of the Eddie client; do check in its "About" page. If so, please update.
You can't delete threads .
