LlamaLord 0 Posted ... So i have been using Air for a few and like it and works great but wanted to know if there is any settings i should do in Eddie & Qbit to make sure all traffic is going through it. Quote Share this post Link to post
LZ1 679 Posted ... Hello! Yes you can refer to the New User guide in my signature below. Then go to the Community Guides section, where there's links to setting up your torrent client. Enjoy Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Tech Jedi Alex 1525 Posted ... QBit = QBittorrent? Disable uTP first Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Kingdom 0 Posted ... In qbittorrent go to tools - options - advanced - Network Interface (requires restart) and be sure to select tun0 for linux or tap for windows/mac.If your running linux install GUFW = sudo apt-get install gufwOpen it up and select report then connect to Qbit - tools - options - connections and take note of the port number. This should match the port numbers and internal vpn ip in GUFW. You can investigate further by running https://ipleak.net/ and click Activate under Torrent Address detection, open the magnet link in Qbit. ipleak will display a port and ip, this should match your external vpn ip and port numbers in both Qbit and GUFW. Hope this helps Quote Share this post Link to post
