solidstat8
audiobookbay.nl not working
You can try check the guide to blocked sites in my signature if you would like.
thanks for the help
i tested with the route checking and found a few servers that work
but all netherlands servers fail and that what i use most
i have no dns leaks and my isp dns do not block this site yet
so i think it is a problem for airvpn dns
but i have a working solution using different servers so thats good
thanks again
