Clevio 0 Posted ... ooh and the log file - 22/05/2012 - 07:40 AirVPN client version: 1.7 22/05/2012 - 07:40 Reading options from C:\Users\**********\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 22/05/2012 - 07:40 OpenVPN bundle version: OpenVPN 2.2.2 22/05/2012 - 07:40 OpenVPN current version: OpenVPN 2.2.2 22/05/2012 - 07:40 Ready. 22/05/2012 - 07:40 Login... 22/05/2012 - 07:40 Login success. 22/05/2012 - 07:40 Contacting service... 22/05/2012 - 07:40 Connecting... 22/05/2012 - 07:40 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 22/05/2012 - 07:40 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 22/05/2012 - 07:40 LZO compression initialized 22/05/2012 - 07:40 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 22/05/2012 - 07:40 Socket Buffers: R=[8192->8192] S=[8192->8192] 22/05/2012 - 07:40 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 22/05/2012 - 07:40 Local Options hash (VER=V4): '22188c5b' 22/05/2012 - 07:40 Expected Remote Options hash (VER=V4): 'a8f55717' 22/05/2012 - 07:40 UDPv4 link local: [undef] 22/05/2012 - 07:40 UDPv4 link remote: 108.59.8.147:443 22/05/2012 - 07:41 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) 22/05/2012 - 07:41 TLS Error: TLS handshake failed 22/05/2012 - 07:41 TCP/UDP: Closing socket 22/05/2012 - 07:41 SIGUSR1[soft,tls-error] received, process restarting 22/05/2012 - 07:41 Restart pause, 2 second(s) 22/05/2012 - 07:41 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 22/05/2012 - 07:41 LZO compression initialized 22/05/2012 - 07:41 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] 22/05/2012 - 07:41 Socket Buffers: R=[8192->8192] S=[8192->8192] 22/05/2012 - 07:41 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] 22/05/2012 - 07:41 Local Options hash (VER=V4): '22188c5b' 22/05/2012 - 07:41 Expected Remote Options hash (VER=V4): 'a8f55717' 22/05/2012 - 07:41 UDPv4 link local: [undef] 22/05/2012 - 07:41 UDPv4 link remote: 108.59.8.147:443 Quote Share this post Link to post
Clevio 0 Posted ... err ... why didnt that attach to the previous post as a reply that is werid - lolz got to love the interwebs Orginal post - HI, the last few days , (with out any changes to my system at this end) I am finding that the Air VPN client allows me to login , select a sever but does not progress pass the "connecting" message and simply stays at that ? I know I can connect via Open VPN - but I like the airvpn popup for ease of changing servers. Any ideas what I can look for or do ? ---------- Added if you wish to delete the other one-as it seems posters cannot Quote Share this post Link to post
Staff 10483 Posted ... err ... why didnt that attach to the previous post as a reply that is werid - lolz got to love the interwebsHello!No worries, just a Kunena glitch.Orginal post - HI, the last few days , (with out any changes to my system at this end) I am finding that the Air VPN client allows me to login , select a sever but does not progress pass the "connecting" message and simply stays at that ?I know I can connect via Open VPN - but I like the airvpn popup for ease of changing servers.Any ideas what I can look for or do ?----------It looks like outbound port 443 UDP is blocked on your system. Can you please check that some firewall is not blocking OpenVPN?Also, in case your ISP has started blocking 443 UDP or other UDP ports, try a TCP connection (for example to 80 TCP).We're looking forward to hearing from you.Kind regards Quote Share this post Link to post
