kittyberry
Do NOT forward on your router the same ports...?
So, I will look like a complete noob while asking this question, but better safe than sorry. What exactly is meant by the note on the bottom of the p2p FAQ (IMPORTANT: do NOT forward on your router the same ports you use on your Bittorrent or eMule client (or any other listening service) while connected to the VPN. Doing so exposes your system to correlation attacks and potentially causes uncencrypted packets to be sent outside the tunnel from your client.)? I'm mostly using the vpn to keep my torrent downloads anonymous (my ISP has already warned me about it), so I think it's really important for me to understand everything that has to do with using airvpn and BitTorrent. So I've forwarded one port and have set it up on BitTorrent via the instructions provided. I've done nothing else with the forwarding of ports/setting them up. Am I in the clear? Thanks. c:
Yes, you're fine, just do not forward ports on your router.
If you forward both remotely and on your router the same ports, an adversary with the ability to monitor/wiretap your line can send packets to the same port both on the exit-IP of the VPN server you're connected to and to your real IP address. If the service you're running responds also the the packets arriving to your real IP address outside the tunnel, the adversary have established a correlation between you and the VPN usage on that port.
More on this topic .. on the 'ports' page it is noted "configure your firewall to block connections outside the tunnel to these ports". My connection is as a OpenVPN client on a DD_WRT router and the standard set of iptables commands is in place (iptables -I FORWARD -i br0 -o tun0 -j ACCEPT iptables -I FORWARD -i tun0 -o br0 -j ACCEPT iptables -I INPUT -i tun0 -j REJECT
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE) ... is this sufficient or must something specific be done with the forwarded port?TIA!
Can you please send us the complete iptables tables/chains? The rules you mention do not appear to prevent leaks from your br0 in case of VPN disconnection.
Not sure if this is what is wanted?
root@DD-WRT:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
logaccept 0 -- anywhere anywhere
REJECT 0 -- anywhere anywhere reject-with icmp-po
rt-unreachable
logaccept 0 -- anywhere anywhere state RELATED,ESTAB
LISHED
logdrop udp -- anywhere anywhere udp dpt:route
ACCEPT udp -- anywhere anywhere udp dpt:route
logdrop icmp -- anywhere anywhere
logdrop igmp -- anywhere anywhere
ACCEPT 0 -- anywhere anywhere state NEW
logaccept 0 -- anywhere anywhere state NEW
logdrop 0 -- anywhere anywhere
Chain FORWARD (policy ACCEPT)
logaccept gre -- 192.168.1.0/24 anywhere
logaccept tcp -- 192.168.1.0/24 anywhere tcp dpt:1723
TCPMSS tcp -- anywhere anywhere tcp flags:SYN,RST/S
YN TCPMSS clamp to PMTU
lan2wan 0 -- anywhere anywhere
LISHED
TRIGGER 0 -- anywhere anywhere TRIGGER type:in mat
ch:0 relate:0
trigger_out 0 -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain advgrp_1 (0 references)
Chain advgrp_10 (0 references)
Chain advgrp_2 (0 references)
Chain advgrp_3 (0 references)
Chain advgrp_4 (0 references)
Chain advgrp_5 (0 references)
Chain advgrp_6 (0 references)
Chain advgrp_7 (0 references)
Chain advgrp_8 (0 references)
Chain advgrp_9 (0 references)
Chain grp_1 (0 references)
Chain grp_10 (0 references)
Chain grp_2 (0 references)
Chain grp_3 (0 references)
Chain grp_4 (0 references)
Chain grp_5 (0 references)
Chain grp_6 (0 references)
Chain grp_7 (0 references)
Chain grp_8 (0 references)
Chain grp_9 (0 references)
Chain lan2wan (1 references)
Chain logaccept (8 references)
LOG 0 -- anywhere anywhere state NEW LOG level
warning tcp-sequence tcp-options ip-options prefix `ACCEPT '
Chain logbrute (0 references)
0 -- anywhere anywhere recent: SET name: B
RUTEFORCE side: source
RETURN 0 -- anywhere anywhere !recent: UPDATE sec
onds: 60 hit_count: 4 name: BRUTEFORCE side: source
RETURN 0 -- anywhere anywhere limit: avg 1/min bu
rst 1
Chain logdrop (7 references)
DROP 0 -- anywhere anywhere
Chain logreject (0 references)
REJECT tcp -- anywhere anywhere reject-with tcp-res
et
Chain trigger_out (1 references)
So I currently have the following rules:
The quoted thread suggests the following:
iptables -I FORWARD -i wl0 -o tun+ -j ACCEPT
iptables -I FORWARD -i tun+ -o wl0 -j ACCEPT # make sure that eth+ and tun+ can "communicate"
iptables -I INPUT -i tun+ -j REJECT
iptables -t nat -A POSTROUTING -o tun+ -j MASQUERADE # in the POSTROUTING chain of the NAT table, map the tun+ interface outgoing packet IP address, cease examining rules and let the header be modified, so that we don't have to worry about ports or any other issue - please check this rule with care if you have already a NAT table in your chain
iptables -I OUTPUT -o eth+ ! --dst 50.115.127.44 -j DROP # if destination for outgoing packet on eth+ is NOT a.b.c.d, drop the packet, so that nothing leaks if VPN disconnects
# the above line can be duplicated for as many Air servers as you wish to connect to, just insert the appropriate Air server entry-IP8888888888888
The above is modified from eth+ as LAN connections with the exception of VOip are all wireless
Combining the above it seems I should add:
iptables -I FORWARD -i tun+ -o wl0 -j ACCEPT # make sure that wl0 and tun+ can "communicate"
iptables -I OUTPUT -o wl0 ! --dst 50.115.127.44 -j DROP # if destination for outgoing packet on eth+ is NOT a.b.c.d, drop the packet, so that nothing leaks if VPN disconnects
then save the firewall, reboot and reconnect. (am unsure how to "make sure that wl0 and tun+ can "communicate"")
Hope this is correct. TIA!!!
