sadlove05
Suddenly connection drop
Hi, I've been facing this problems for almost a week where whenever I connect to vpn ( usually US server vega or sirius, UDP 53 ), a few minutes later the connection lost, webpage will keep loading without any progress, downloading stopped.. this keep happening everytime.. is there anything i can do with this issue? I can't using other port for some reason, can only stick to udp 53.. any server would be ok I guess.. please help me.. thanks
Please try all the servers to check whether connection stability improves. If you lose connection with your ISP and it re-assigns you a new IP address, unfortunately a reconnection to a VPN server is unavoidable (your previous IP address is no more, so the VPN server needs to know your new one).
