Herkulez99
ISP is blocking me from accessing AirVPN.org?
Hello dear forum,
I recently tested out your service and everything worked fine.
But after one day, after turning off the client on windows, I couldn't reach airvpn.org. I thought maybe it is down, but nope just for me.
I went on my phone and my notebook (which are in the wifi network) and same thing.
I started a free vpn on my phone and voila, I could reach airvpn.org again. Same thing on laptop with a free proxy.
The interesting thing is that the client and VPN itself works fine, nothing is blocked.
But it seems that my ISP blocked airvpn.org...
Could you help? Did that help to someone else already? I thought using a VPN itself is perefectly legal.
I'm from germany btw
Thank you!
Willkommen bei AirVPN.
We'd need the OpenVPN logs. Paste them into spoiler tags as described in my signature.
Ergo, it has nothing to do with access restrictions. It wouldn't work in the first place if it was blocked, so don't worry about your ISP
It sounds like an issue with DNS or Network Lock, let's confirm this with your logs.
Okay, here are my logs
I 2017.03.31 12:28:26 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727
. 2017.03.31 12:28:26 - Reading options from C:\Users\Dennis\AppData\Local\AirVPN\AirVPN.xml
. 2017.03.31 12:28:28 - Data path: C:\Users\Dennis\AppData\Local\AirVPN
. 2017.03.31 12:28:28 - Application path: C:\Program Files\AirVPN
. 2017.03.31 12:28:28 - Executable path: C:\Program Files\AirVPN\AirVPN.exe
. 2017.03.31 12:28:28 - Command line arguments (1): path="home"
. 2017.03.31 12:28:28 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
I 2017.03.31 12:28:30 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2017.03.31 12:28:30 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Program Files\AirVPN\openvpn.exe)
I 2017.03.31 12:28:30 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2017.03.31 12:28:30 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2017.03.31 12:28:30 - curl - Version: 7.34.0 (C:\Program Files\AirVPN\curl.exe)
I 2017.03.31 12:28:30 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
! 2017.03.31 12:28:31 - Ready
. 2017.03.31 12:28:31 - Updating systems & servers data ...
. 2017.03.31 12:28:32 - Systems & servers data update completed
I 2017.03.31 12:31:56 - Session starting.
. 2017.03.31 12:31:57 - IPv6 disabled with packet filtering.
I 2017.03.31 12:31:57 - Checking authorization ...
! 2017.03.31 12:31:57 - Connecting to Edasich (Netherlands, Alblasserdam)
. 2017.03.31 12:31:58 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.03.31 12:31:58 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.03.31 12:31:58 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.31 12:31:58 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.31 12:31:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 12:31:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 12:31:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.210:443
. 2017.03.31 12:31:58 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.03.31 12:31:58 - OpenVPN > UDP link local: (not bound)
. 2017.03.31 12:31:58 - OpenVPN > UDP link remote: [AF_INET]213.152.161.210:443
. 2017.03.31 12:31:58 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.210:443, sid=c4b2ffb9 d6a6423c
. 2017.03.31 12:31:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.31 12:31:59 - OpenVPN > Validating certificate key usage
. 2017.03.31 12:31:59 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.31 12:31:59 - OpenVPN > VERIFY KU OK
. 2017.03.31 12:31:59 - OpenVPN > Validating certificate extended key usage
. 2017.03.31 12:31:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.31 12:31:59 - OpenVPN > VERIFY EKU OK
. 2017.03.31 12:31:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Edasich, emailAddress=info@airvpn.org
. 2017.03.31 12:31:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.31 12:31:59 - OpenVPN > [Edasich] Peer Connection Initiated with [AF_INET]213.152.161.210:443
. 2017.03.31 12:32:00 - OpenVPN > SENT CONTROL [Edasich]: 'PUSH_REQUEST' (status=1)
. 2017.03.31 12:32:00 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.4.186 255.255.0.0,peer-id 100,cipher AES-256-GCM'
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.03.31 12:32:00 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.03.31 12:32:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.03.31 12:32:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.03.31 12:32:00 - OpenVPN > interactive service msg_channel=0
. 2017.03.31 12:32:00 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=11 HWADDR=d4:3d:7e:bd:be:10
. 2017.03.31 12:32:00 - OpenVPN > open_tun
. 2017.03.31 12:32:00 - OpenVPN > TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{8B60797A-B005-4910-A84A-C9A7A9835AF9}.tap
. 2017.03.31 12:32:00 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.03.31 12:32:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.4.186/255.255.0.0 [sUCCEEDED]
. 2017.03.31 12:32:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.4.186/255.255.0.0 on interface {8B60797A-B005-4910-A84A-C9A7A9835AF9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.03.31 12:32:00 - OpenVPN > Successful ARP Flush on interface [14] {8B60797A-B005-4910-A84A-C9A7A9835AF9}
. 2017.03.31 12:32:00 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.31 12:32:05 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.03.31 12:32:05 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.210 MASK 255.255.255.255 192.168.178.1
. 2017.03.31 12:32:05 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.03.31 12:32:05 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.03.31 12:32:05 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 12:32:05 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 12:32:05 - Starting Management Interface
. 2017.03.31 12:32:05 - OpenVPN > Initialization Sequence Completed
. 2017.03.31 12:32:06 - DNS leak protection with packet filtering enabled.
. 2017.03.31 12:32:06 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.03.31 12:32:06 - Flushing DNS
I 2017.03.31 12:32:12 - Checking route
I 2017.03.31 12:32:13 - Checking DNS
! 2017.03.31 12:32:25 - Connected.
. 2017.03.31 12:32:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.03.31 12:32:25 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.03.31 12:38:58 - Updating systems & servers data ...
. 2017.03.31 12:38:58 - Systems & servers data update completed
. 2017.03.31 12:49:49 - Updating systems & servers data ...
. 2017.03.31 12:49:49 - Systems & servers data update completed
. 2017.03.31 13:00:44 - Updating systems & servers data ...
. 2017.03.31 13:00:45 - Systems & servers data update completed
. 2017.03.31 13:11:40 - Updating systems & servers data ...
. 2017.03.31 13:11:41 - Systems & servers data update completed
. 2017.03.31 13:22:36 - Updating systems & servers data ...
. 2017.03.31 13:22:36 - Systems & servers data update completed
. 2017.03.31 13:31:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.31 13:31:58 - OpenVPN > Validating certificate key usage
. 2017.03.31 13:31:58 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.31 13:31:58 - OpenVPN > VERIFY KU OK
. 2017.03.31 13:31:58 - OpenVPN > Validating certificate extended key usage
. 2017.03.31 13:31:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.31 13:31:58 - OpenVPN > VERIFY EKU OK
. 2017.03.31 13:31:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Edasich, emailAddress=info@airvpn.org
. 2017.03.31 13:31:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.03.31 13:31:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.03.31 13:31:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.31 13:33:24 - Updating systems & servers data ...
. 2017.03.31 13:33:25 - Systems & servers data update completed
! 2017.03.31 13:37:09 - Disconnecting
. 2017.03.31 13:37:09 - Management - Send 'signal SIGTERM'
. 2017.03.31 13:37:09 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.03.31 13:37:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.03.31 13:37:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.210 MASK 255.255.255.255 192.168.178.1
. 2017.03.31 13:37:14 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.03.31 13:37:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 13:37:14 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 13:37:14 - OpenVPN > Closing TUN/TAP interface
. 2017.03.31 13:37:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2017.03.31 13:37:14 - Connection terminated.
. 2017.03.31 13:37:14 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.03.31 13:37:14 - DNS leak protection with packet filtering disabled.
. 2017.03.31 13:37:14 - IPv6 restored with packet filtering.
. 2017.03.31 13:37:14 - Flushing DNS
! 2017.03.31 13:37:20 - Session terminated.
! 2017.03.31 13:37:21 - Activation of Network Lock - Windows Filtering Platform
I 2017.03.31 13:37:22 - Session starting.
. 2017.03.31 13:37:22 - IPv6 disabled with packet filtering.
I 2017.03.31 13:37:22 - Checking authorization ...
! 2017.03.31 13:37:22 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2017.03.31 13:37:22 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017
. 2017.03.31 13:37:22 - OpenVPN > Windows version 6.1 (Windows 7) 64bit
. 2017.03.31 13:37:22 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09
. 2017.03.31 13:37:22 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.03.31 13:37:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 13:37:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 13:37:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.116:443
. 2017.03.31 13:37:23 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2017.03.31 13:37:23 - OpenVPN > UDP link local: (not bound)
. 2017.03.31 13:37:23 - OpenVPN > UDP link remote: [AF_INET]213.152.161.116:443
. 2017.03.31 13:37:23 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=c9abc037 9316d012
. 2017.03.31 13:37:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.03.31 13:37:23 - OpenVPN > Validating certificate key usage
. 2017.03.31 13:37:23 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0
. 2017.03.31 13:37:23 - OpenVPN > VERIFY KU OK
. 2017.03.31 13:37:23 - OpenVPN > Validating certificate extended key usage
. 2017.03.31 13:37:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.03.31 13:37:23 - OpenVPN > VERIFY EKU OK
. 2017.03.31 13:37:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.03.31 13:37:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.03.31 13:37:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443
. 2017.03.31 13:37:24 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.03.31 13:37:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.106.159 255.255.0.0'
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.03.31 13:37:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.03.31 13:37:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.31 13:37:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 13:37:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.03.31 13:37:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.03.31 13:37:24 - OpenVPN > interactive service msg_channel=0
. 2017.03.31 13:37:24 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=11 HWADDR=d4:3d:7e:bd:be:10
. 2017.03.31 13:37:24 - OpenVPN > open_tun
. 2017.03.31 13:37:24 - OpenVPN > TAP-WIN32 device [LAN-Verbindung 2] opened: \\.\Global\{8B60797A-B005-4910-A84A-C9A7A9835AF9}.tap
. 2017.03.31 13:37:24 - OpenVPN > TAP-Windows Driver Version 9.21
. 2017.03.31 13:37:24 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.106.159/255.255.0.0 [sUCCEEDED]
. 2017.03.31 13:37:24 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.106.159/255.255.0.0 on interface {8B60797A-B005-4910-A84A-C9A7A9835AF9} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2017.03.31 13:37:24 - OpenVPN > Successful ARP Flush on interface [14] {8B60797A-B005-4910-A84A-C9A7A9835AF9}
. 2017.03.31 13:37:24 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.03.31 13:37:29 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2017.03.31 13:37:29 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.178.1
. 2017.03.31 13:37:29 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2017.03.31 13:37:29 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2017.03.31 13:37:29 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 13:37:29 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.03.31 13:37:29 - Starting Management Interface
. 2017.03.31 13:37:29 - OpenVPN > Initialization Sequence Completed
. 2017.03.31 13:37:29 - DNS leak protection with packet filtering enabled.
. 2017.03.31 13:37:29 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1)
. 2017.03.31 13:37:29 - Flushing DNS
I 2017.03.31 13:37:35 - Checking route
I 2017.03.31 13:37:35 - Checking DNS
! 2017.03.31 13:37:47 - Connected.
. 2017.03.31 13:37:47 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.03.31 13:37:47 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
