dooley2009
Can connect, Port Forwarding working, can't seed?
Im on Win 10 64.
Using OpenVPN to connect not the Eddie client.
Port has been forwarded and verified working.
I plugged that port number into QBitTorrent like this site says to do.
Undid all the options you said to.
Trackers load, and everything looks like it is going GREAT......no seeding EVER happens.
Flags are blank.
What do I do?
If by "you said to" you mean the torrent guides then okay. Did you check your firewall isn't blocking anything and that qBittorent is bound to the VPN interface?
