Droopy 2 Posted ... This is happening constantly.I'm running Win 7 here is the log file.Thanks for any helpAirVPN_20170123_222344.txt Quote Share this post Link to post
LZ1 678 Posted ... Hello! Please try go to the Eddie protocol settings and switch to TCP . Do also try turn of IPv6 on ALL networking adapters. Including the TAP driver. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Droopy 2 Posted ... Hello! Please try go to the Eddie protocol settings and switch to TCP . Do also try turn of IPv6 on ALL networking adapters. Including the TAP driver. Thanks for your help, Ive done as you suggested, see if that resolves the problem. Quote Share this post Link to post
Droopy 2 Posted ... Hello! Please try go to the Eddie protocol settings and switch to TCP . Do also try turn of IPv6 on ALL networking adapters. Including the TAP driver.Thanks for your help, Ive done as you suggested, see if that resolves the problem.Unfortunately that didnt work anyone else got any other suggestions please.Thanks Quote Share this post Link to post
LZ1 678 Posted ... Then please attach logs again when the problem occurs Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Droopy 2 Posted ... Then please attach logs again when the problem occurs Thanks again, i think i solved that problem it was my firewall, but now every time i bring the PC out of sleep/lock mode the VPN disconnectes.AirVPN_20170128_221302.txt Quote Share this post Link to post
LZ1 678 Posted ... Well strictly speaking, you should turn off the client first haha. It looks like you still have IPv6 on in your TAP driver, if this is anything to go by:. 2017.01.28 18:49:54 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{685BC911-B5B1-4CA9-8E37-46A4D0AC2B9F}.tapAlso, try switch to the TCP protocol. If all fails, then I do recommend you try the Experimental client, if you're not already using it .You can also go to your TAP drivers properties settings, then into Advanced and enable "Always Connected" then click apply. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Droopy 2 Posted ... Well strictly speaking, you should turn off the client first haha. It looks like you still have IPv6 on in your TAP driver, if this is anything to go by:. 2017.01.28 18:49:54 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{685BC911-B5B1-4CA9-8E37-46A4D0AC2B9F}.tapAlso, try switch to the TCP protocol. If all fails, then I do recommend you try the Experimental client, if you're not already using it .You can also go to your TAP drivers properties settings, then into Advanced and enable "Always Connected" then click apply.Gday again, thanks for your patience, IPV6 is off, i did have it to TCP didn't help so put it back to UDP, i have tried your suggestion above, see how that goes.Thanks for your help really appreciate it. 1 LZ1 reacted to this Quote Share this post Link to post
Tech Jedi Alex 1515 Posted ... Thanks again, i think i solved that problem it was my firewall, but now every time i bring the PC out of sleep/lock mode the VPN disconnectes. On Windows, if you put your computer to sleep, the routing table will be reset, thus breaking any VPN functionality until a full reconnect is performed. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Droopy 2 Posted ... Thanks again, i think i solved that problem it was my firewall, but now every time i bring the PC out of sleep/lock mode the VPN disconnectes. On Windows, if you put your computer to sleep, the routing table will be reset, thus breaking any VPN functionality until a full reconnect is performed.I don't think I'm putting it to sleep I'm only locking it, here is the log from Eddie 2.11 hopefully that puts some light on why its happening. Go to 2.53 and you can see the VPN being cut.ThanksEddie_20170201_084345.txt Quote Share this post Link to post
Droopy 2 Posted ... Thanks again, i think i solved that problem it was my firewall, but now every time i bring the PC out of sleep/lock mode the VPN disconnectes. On Windows, if you put your computer to sleep, the routing table will be reset, thus breaking any VPN functionality until a full reconnect is performed.I don't think I'm putting it to sleep I'm only locking it, here is the log from Eddie 2.11 hopefully that puts some light on why its happening. Go to 2.53 and you can see the VPN being cut.ThanksOk I found out what the problem was, in Win 7 Power Options you have to turn the power plan to High Performance, if you dont the other options put the computer to sleep, killing the VPN .Thank you very much to all who have tried to help it means alot Quote Share this post Link to post
