Hey Guys,
im Using Kali as a virtual machine. Whonix-gateway too and kali is connected over this whonix gateway. If I want to connect to any server with eddie, at this connection screen its retrying every 30 seconds.
If I try this with openvpn and over the terminal, its connecting fine, but its disconnecting after a time about 30mins to 90 mins, tcp and UDP
Eddie_20170113_122513.txt
Are you using the Beta client? It's not clear.
Same problem here but with a WIN7 VM.
Internet work fine but when i try launch the eddie it keep try conect in a loop.
If i try without whonix in th middle everything is fine.
