Not connected, Your IP: 216.73.216.161
I have been using Eddie for months, the experimental v2.11 since it was published, and never had any problem with leaked information.
Today, my DNS information is leaking. I haven't changed any setting, the network lock is active as usual, and yet ..
​Does anyone else experience the same issue?
Please show us some logs and/or give us more workable information about your setup. You may need to update to the latest Beta version as well .
Which website did you check on?
Sorry for not getting back to you earlier. I realized that something else was amiss, and, in the end, I had to replace my SSD and used the opportunity to set up my system from the ground up. And I am already contemplating to move from the new dual-OS solution (Linux, Windows) to Linux alone.
Well, I am not the first one here to walk that road ...
The problem with the DNS has not re-appeared, and, unfortunately, the logs were lost with the failing drive.
Thank you for trying to solve this with me! I might come back to you when I get into trouble with AIRVPN on Linux.
Thanks again!
​PS:
@333_half_evil, no, that was not it - but, you're right, it's one of the usual suspects.
@​LZ1, in case you're still interested, I checked it on:
https://ipleak.net/
(of course)
https://www.doileak.com/
https://www.dnsleaktest.com/
