For some reason I can't connect anymore, some help is needed.  I removed all the current connections from the client area and tried reconnecting, it keeps restarting. Here's the log:
I 2017.01.06 11:18:34 - Checking authorization ...
! 2017.01.06 11:18:34 - Connecting to Antares (Singapore, Singapore)
. 2017.01.06 11:18:34 - OpenVPN > OpenVPN 2.4.0 x86_64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Dec 28 2016
. 2017.01.06 11:18:34 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.06 11:18:34 - OpenVPN > setsockopt(IPV6_V6ONLY=0)
. 2017.01.06 11:18:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET6]::1:3100
. 2017.01.06 11:18:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:18:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:18:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]103.254.153.100:443
. 2017.01.06 11:18:34 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2017.01.06 11:18:34 - OpenVPN > UDP link local: (not bound)
. 2017.01.06 11:18:34 - OpenVPN > UDP link remote: [AF_INET]103.254.153.100:443
. 2017.01.06 11:18:34 - OpenVPN > TLS: Initial packet from [AF_INET]103.254.153.100:443, sid=152fbf4a 9f1bf875
. 2017.01.06 11:18:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.01.06 11:18:35 - OpenVPN > Validating certificate key usage
. 2017.01.06 11:18:35 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2017.01.06 11:18:35 - OpenVPN > VERIFY KU OK
. 2017.01.06 11:18:35 - OpenVPN > Validating certificate extended key usage
. 2017.01.06 11:18:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.01.06 11:18:35 - OpenVPN > VERIFY EKU OK
. 2017.01.06 11:18:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2017.01.06 11:18:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.01.06 11:18:35 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]103.254.153.100:443
. 2017.01.06 11:18:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2017.01.06 11:18:38 - OpenVPN > Key [AF_INET]103.254.153.100:443 [0] not initialized (yet), dropping packet.
. 2017.01.06 11:18:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.40.193 255.255.0.0'
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.01.06 11:18:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.01.06 11:18:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:18:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:18:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2017.01.06 11:18:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.06 11:18:38 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 IFACE=wlp1s0 HWADDR=a4:02:b9:34:8f:f5
. 2017.01.06 11:18:38 - OpenVPN > TUN/TAP device tun0 opened
. 2017.01.06 11:18:38 - OpenVPN > TUN/TAP TX queue length set to 100
. 2017.01.06 11:18:38 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.01.06 11:18:38 - OpenVPN > /usr/bin/ip link set dev tun0 up mtu 1500
. 2017.01.06 11:18:38 - OpenVPN > /usr/bin/ip addr add dev tun0 10.4.40.193/16 broadcast 10.4.255.255
. 2017.01.06 11:18:43 - OpenVPN > /usr/bin/ip route add 103.254.153.100/32 via 192.168.1.1
. 2017.01.06 11:18:43 - OpenVPN > ERROR: Linux route add command failed: external program exited with error status: 2
. 2017.01.06 11:18:43 - OpenVPN > RTNETLINK answers: File exists
. 2017.01.06 11:18:43 - OpenVPN > /usr/bin/ip route add 0.0.0.0/1 via 10.4.0.1
. 2017.01.06 11:18:43 - OpenVPN > /usr/bin/ip route add 128.0.0.0/1 via 10.4.0.1
. 2017.01.06 11:18:43 - Starting Management Interface
W 2017.01.06 11:18:43 - Connection refused
! 2017.01.06 11:18:43 - Disconnecting
. 2017.01.06 11:18:43 - Connection terminated.
I have the same problem using the latest openvpn version on arch linux. Downgrading openvpn fixes it:
sudo pacman -U /var/cache/pacman/pkg/openvpn-2.3.14-1-x86_64.pkg.tar.xz
