Pingviinit 0 Posted ... Hello guys! I'm on vacation in USA from Finland and starting today my AirVpn Eddie client has been given me a Connection Refused error. My set up is pretty standard, I have the nameserver 10.4.0.1 in /etc/resolv.conf. DNS is set to Renaming. I reprogrammed my Arch recently and today am trying to connect to AirVpn with no luck. I have heard there is a new law in USA cracking down on VPN users (Rule 41) and am wondering if my hostess' ISP simply is blocking all VPN access. In any case, here the log! I 2017.01.01 12.17.53 - Eddie client version: 2.11.9 / linux_x64, System: Linux, Name: Arch Linux \r (\l), Mono/.Net Framework: v4.0.30319. 2017.01.01 12.17.53 - Reading options from /home/matemaatikko/.airvpn/AirVPN.xml. 2017.01.01 12.17.54 - Data path: /home/matemaatikko/.airvpn. 2017.01.01 12.17.54 - Application path: /usr/lib/AirVPN. 2017.01.01 12.17.54 - Executable path: /usr/lib/AirVPN/AirVPN.exe. 2017.01.01 12.17.54 - Command line arguments (1): path="/home/matemaatikko/.airvpn". 2017.01.01 12.17.54 - Operating System: Unix 4.8.13.1 - Linux Pingviini 4.8.13-1-ARCH #1 SMP PREEMPT Fri Dec 9 07:24:34 CET 2016 x86_64 GNU/LinuxI 2017.01.01 12.17.54 - OpenVPN Driver - Found, /dev/net/tunI 2017.01.01 12.17.54 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09 (/usr/bin/openvpn)I 2017.01.01 12.17.54 - SSH - Version: OpenSSH_7.4p1, OpenSSL 1.0.2j 26 Sep 2016 (/usr/bin/ssh)W 2017.01.01 12.17.54 - SSL - Not available! 2017.01.01 12.17.54 - Ready. 2017.01.01 12.17.54 - Updating systems & servers data .... 2017.01.01 12.17.58 - Systems & servers data update completedI 2017.01.01 12.18.30 - Session starting.. 2017.01.01 12.18.30 - Unable to understand if IPv6 is active.I 2017.01.01 12.18.30 - Checking authorization ...! 2017.01.01 12.18.31 - Connecting to Alderamin (Austria, Vienna). 2017.01.01 12.18.31 - OpenVPN > OpenVPN 2.4.0 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Dec 28 2016. 2017.01.01 12.18.31 - OpenVPN > library versions: OpenSSL 1.0.2j 26 Sep 2016, LZO 2.09. 2017.01.01 12.18.31 - OpenVPN > setsockopt(IPV6_V6ONLY=0). 2017.01.01 12.18.31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET6]::1:3100. 2017.01.01 12.18.31 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.01 12.18.31 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.01 12.18.31 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.9.19.106:443. 2017.01.01 12.18.31 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]. 2017.01.01 12.18.31 - OpenVPN > UDP link local: (not bound). 2017.01.01 12.18.31 - OpenVPN > UDP link remote: [AF_INET]185.9.19.106:443. 2017.01.01 12.18.31 - OpenVPN > TLS: Initial packet from [AF_INET]185.9.19.106:443, sid=8a66fa9f 257117e2. 2017.01.01 12.18.31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.01.01 12.18.31 - OpenVPN > Validating certificate key usage. 2017.01.01 12.18.31 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.01.01 12.18.31 - OpenVPN > VERIFY KU OK. 2017.01.01 12.18.31 - OpenVPN > Validating certificate extended key usage. 2017.01.01 12.18.31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.01.01 12.18.31 - OpenVPN > VERIFY EKU OK. 2017.01.01 12.18.31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alderamin, emailAddress=info@airvpn.org. 2017.01.01 12.18.32 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.01.01 12.18.32 - OpenVPN > [Alderamin] Peer Connection Initiated with [AF_INET]185.9.19.106:443. 2017.01.01 12.18.33 - OpenVPN > SENT CONTROL [Alderamin]: 'PUSH_REQUEST' (status=1). 2017.01.01 12.18.33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.5.25 255.255.0.0'. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.01.01 12.18.33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.01.01 12.18.33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.01 12.18.33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.01 12.18.33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.01.01 12.18.33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.01.01 12.18.33 - OpenVPN > ROUTE_GATEWAY 192.168.1.254/255.255.255.0 IFACE=wlp3s0 HWADDR=60:6c:66:21:9b:fc. 2017.01.01 12.18.33 - OpenVPN > TUN/TAP device tun0 opened. 2017.01.01 12.18.33 - OpenVPN > TUN/TAP TX queue length set to 100. 2017.01.01 12.18.33 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.01.01 12.18.33 - OpenVPN > /usr/bin/ip link set dev tun0 up mtu 1500. 2017.01.01 12.18.33 - OpenVPN > /usr/bin/ip addr add dev tun0 10.4.5.25/16 broadcast 10.4.255.255. 2017.01.01 12.18.39 - OpenVPN > /usr/bin/ip route add 185.9.19.106/32 via 192.168.1.254. 2017.01.01 12.18.39 - OpenVPN > ERROR: Linux route add command failed: external program exited with error status: 2. 2017.01.01 12.18.39 - OpenVPN > RTNETLINK answers: File exists. 2017.01.01 12.18.39 - OpenVPN > /usr/bin/ip route add 0.0.0.0/1 via 10.4.0.1. 2017.01.01 12.18.39 - OpenVPN > /usr/bin/ip route add 128.0.0.0/1 via 10.4.0.1. 2017.01.01 12.18.39 - Starting Management InterfaceW 2017.01.01 12.18.39 - Connection refused! 2017.01.01 12.18.39 - Disconnecting. 2017.01.01 12.18.39 - Connection terminated.I 2017.01.01 12.18.42 - Checking authorization ...I 2017.01.01 12.18.42 - Cancel requested.! 2017.01.01 12.18.42 - Session terminated. Quote Share this post Link to post
Pingviinit 0 Posted ... edit: Date should read 01.01.2017 Happy New Years btw!! Quote Share this post Link to post
wer 14 Posted ... It has something to do with the latest openVPN update on Arch, read here: https://www.archlinux.org/news/openvpn-240-update-requires-administrative-interaction/ In case you don't have the time you could downgrade the package: go to cd /var/cache/pacman/pkg/ and do pacman -U openvpn-2.3.14-1-x86_64.pkg.tar.xz Quote Share this post Link to post
LZ1 678 Posted ... Hello! This has been reported here 1 wer reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Pingviinit 0 Posted ... It worked you guys!! Thank you so much. I'm using the management 127.0.0.1 3100 method as of right now but tested downgrading too and it worked as well. Cheers! Quote Share this post Link to post
wer 14 Posted ... This has been reported here Thanks a lot! Didn't know about that until now. :-) 1 LZ1 reacted to this Quote Share this post Link to post
