b2431521
How do you use routing servers?
I understand these are used to bypass geo-ip blocking websites - is that correct?
I'm trying to stream from bbc.co.uk/iplayer while connected to an NL server (Asellus) - How do I go about routing the traffic via the UK routing server so that the stream works correctly? I've started using the AirVPN windows client can't see any options.
Thanks,
By connecting to Air servers and DNS. Sometimes there's errors of course:). Check ipleak.net for leaks.
It works automagically (as long as you are connected to AirVPN and using AirVPN DNS, like LZ1 said).
