Max4All
Trying to avoid Vodafon (ex KabelDeutschland) throttling
I found out that Vodafone, ex KabelDeutschland, is throttling my VPN traffic to ca. 20MBps. After playing with Eddie, I found out that alternate IP, UDP and Port 53 avoids throtteling. I get on my MacBookPro about 10% less than the 100MBps I'm paying for. So far so good.
Now I wanted connect my whole network. I tried to use my Tomato router as well as my Synology NAS as a router. I used the same setup (alternate IP, UDP, Port 53). In both cases the throttle slows me down to 20 MBps.
So, why can I avoid the throttle using Eddie but can't using the same settings on Tomato or Synology? Any ideas?
maybe with Tomato or Synology you just hit the processing power limit of a core of their CPUs to encrypt/decrypt AES-256. A limit that's so near to the shaping cap of your ISP that can be confused with it.
I would say that's very likely to be part of the issue when using the router.  Depending the router chipset, getting above the 30-50 range is very difficult at this high of a level of encryption.
I can confirm this issue, I am using a Netgear R7000 with DD-Wrt (OpenVPN).
Until recently I was able to get close to max. speed: 32MBps on a 32 MBps line,
In the mean time I got upgraded to a 100 MBps line, now I get 20-23 MBps on a 100 MBps line .......
Ok, that might be the reason.
My Synology NAS reaches as much as 50-60% CPU when used as VPN-Client. The R7000 router never exceeds 30%.
