shindoable77
Can't connect, it's going in a loop
my log:
I 2016.12.20 01:57:35 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64
. 2016.12.20 01:57:35 - Reading options from C:\Users\Markus\AppData\Local\AirVPN\AirVPN.xml
. 2016.12.20 01:57:36 - Data Path: C:\Users\Markus\AppData\Local\AirVPN
. 2016.12.20 01:57:36 - App Path: C:\Program Files\AirVPN
. 2016.12.20 01:57:36 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.12.20 01:57:36 - Command line arguments (1): path="home"
. 2016.12.20 01:57:36 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1
. 2016.12.20 01:57:36 - Updating systems & servers data ...
I 2016.12.20 01:57:37 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.12.20 01:57:37 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.12.20 01:57:37 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.12.20 01:57:37 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.12.20 01:57:37 - Ready
I 2016.12.20 01:57:38 - Session starting.
. 2016.12.20 01:57:38 - Systems & servers data update completed
I 2016.12.20 01:57:39 - IPv6 disabled.
I 2016.12.20 01:58:49 - Checking authorization ...
! 2016.12.20 01:58:49 - Connecting to Mirach (Netherlands, Alblasserdam)
! 2016.12.20 01:59:27 - Disconnecting
. 2016.12.20 01:59:27 - Connection terminated.
I 2016.12.20 01:59:31 - Checking authorization ...
! 2016.12.20 01:59:32 - Connecting to Mirach (Netherlands, Alblasserdam)
! 2016.12.20 02:00:09 - Disconnecting
. 2016.12.20 02:00:09 - Connection terminated.
I 2016.12.20 02:00:12 - Checking authorization ...
! 2016.12.20 02:00:13 - Connecting to Mirach (Netherlands, Alblasserdam)
! 2016.12.20 02:00:50 - Disconnecting
. 2016.12.20 02:00:50 - Connection terminated.
I 2016.12.20 02:00:53 - Checking authorization ...
! 2016.12.20 02:00:54 - Connecting to Mirach (Netherlands, Alblasserdam)
! 2016.12.20 02:01:31 - Disconnecting
. 2016.12.20 02:01:31 - Connection terminated.
I 2016.12.20 02:01:35 - Checking authorization ...
! 2016.12.20 02:01:35 - Connecting to Mirach (Netherlands, Alblasserdam)
! 2016.12.20 02:02:14 - Disconnecting
. 2016.12.20 02:02:14 - Connection terminated.
I 2016.12.20 02:02:17 - Checking authorization ...
! 2016.12.20 02:02:18 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2016.12.20 02:02:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 02:02:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 02:02:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 02:02:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 02:02:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:02:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:02:45 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.20 02:02:45 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 02:02:45 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443
. 2016.12.20 02:02:45 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 02:02:45 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 02:02:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 02:02:45 - Disconnecting
. 2016.12.20 02:02:45 - Connection terminated.
I 2016.12.20 02:02:48 - Checking authorization ...
! 2016.12.20 02:02:49 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2016.12.20 02:02:49 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 02:02:49 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 02:02:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 02:02:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 02:02:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:02:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:02:50 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.20 02:02:50 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 02:02:50 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443
. 2016.12.20 02:03:22 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 02:03:22 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 02:03:27 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 02:03:27 - Disconnecting
. 2016.12.20 02:03:27 - Connection terminated.
I 2016.12.20 02:03:31 - Checking authorization ...
! 2016.12.20 02:03:31 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2016.12.20 02:03:31 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 02:03:31 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 02:03:31 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 02:03:32 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 02:03:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:03:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:03:32 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.20 02:03:32 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 02:03:32 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443
. 2016.12.20 02:04:04 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 02:04:04 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 02:04:10 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 02:04:10 - Disconnecting
. 2016.12.20 02:04:10 - Connection terminated.
I 2016.12.20 02:04:13 - Checking authorization ...
! 2016.12.20 02:04:13 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2016.12.20 02:04:14 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 02:04:14 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 02:04:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 02:04:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 02:04:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:04:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:04:14 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.20 02:04:14 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 02:04:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443
. 2016.12.20 02:04:46 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 02:04:46 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 02:04:51 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 02:04:51 - Disconnecting
. 2016.12.20 02:04:51 - Connection terminated.
I 2016.12.20 02:04:54 - Checking authorization ...
! 2016.12.20 02:04:55 - Connecting to Mirach (Netherlands, Alblasserdam)
. 2016.12.20 02:04:55 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 02:04:55 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 02:04:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 02:04:56 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 02:04:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:04:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 02:04:56 - OpenVPN > Socket Buffers: R=[8192->131072] S=[8192->131072]
. 2016.12.20 02:04:56 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 02:04:56 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.68:443
. 2016.12.20 02:05:28 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 02:05:28 - OpenVPN > SIGTERM received, sending exit notification to peer
Same here - has been a constant problem since I moved to Win10 (was a frequent problem in Win7 but the workarounds usually resulted in a connection) but now I get a reliable connection maybe 1 in 10 attempts and the rest of the time it falls over as soon as I try to transfer any volume of data (eg launch emule) and frequently disconnects and tries to reconnect (with 'Authorization failed, connect anyway/') messages in an endless loop, with no success.
I have tried the stickied workaround (basically uninstall TUN driver and reboot every time I want to access the VPN) but it makes no difference.
I don't see any sign of anyone being interested in fixing this ... AirVPN on Windows is not effectively useless for me.  I can use Linux to get a connection but that is a real hassle when I want to do something on the main PC.
Logs (if anyone is interested):
I 2016.12.20 14:04:25 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.12.20 14:04:25 - Reading options from C:\Users\xxxxxxxxxx\AppData\Local\AirVPN\AirVPN.xml
. 2016.12.20 14:04:26 - Data Path: C:\Users\xxxxxxxxxx\AppData\Local\AirVPN
. 2016.12.20 14:04:26 - App Path: C:\Program Files\AirVPN
. 2016.12.20 14:04:26 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.12.20 14:04:26 - Command line arguments (1): path="home"
. 2016.12.20 14:04:26 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.12.20 14:04:26 - Updating systems & servers data ...
. 2016.12.20 14:04:26 - Cannot find tunnel adapter.
E 2016.12.20 14:04:27 - OpenVPN Driver - Not available
I 2016.12.20 14:04:27 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.12.20 14:04:27 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.12.20 14:04:27 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.12.20 14:04:27 - Ready
I 2016.12.20 14:04:31 - Checking login ...
. 2016.12.20 14:04:36 - Systems & servers data update completed
! 2016.12.20 14:04:38 - Logged in.
! 2016.12.20 14:04:40 - Activation of Network Lock - Windows Firewall
I 2016.12.20 14:04:47 - Session starting.
. 2016.12.20 14:04:47 - Cannot find tunnel adapter.
! 2016.12.20 14:04:47 - Installing tunnel driver
I 2016.12.20 14:04:52 - IPv6 disabled.
I 2016.12.20 14:04:52 - Checking authorization ...
! 2016.12.20 14:04:52 - Connecting to Alcyone (Netherlands, Alblasserdam)
. 2016.12.20 14:04:53 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 14:04:53 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 14:04:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 14:04:53 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 14:04:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:04:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:04:53 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.20 14:04:53 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 14:04:53 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.116:443
. 2016.12.20 14:04:53 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.116:443, sid=8a0b03a3 e88ee196
. 2016.12.20 14:04:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.20 14:04:53 - OpenVPN > Validating certificate key usage
. 2016.12.20 14:04:53 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.12.20 14:04:53 - OpenVPN > VERIFY KU OK
. 2016.12.20 14:04:53 - OpenVPN > Validating certificate extended key usage
. 2016.12.20 14:04:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.20 14:04:53 - OpenVPN > VERIFY EKU OK
. 2016.12.20 14:04:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.20 14:04:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.20 14:04:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:04:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.20 14:04:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:04:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.20 14:04:56 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.116:443
. 2016.12.20 14:04:58 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.20 14:04:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.3.131 255.255.0.0'
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.20 14:04:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.20 14:04:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.20 14:04:59 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.20 14:04:59 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{32F245A6-CAD6-4C76-AB47-D3D9BC4B9D94}.tap
. 2016.12.20 14:04:59 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.20 14:04:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.3.131/255.255.0.0 [sUCCEEDED]
. 2016.12.20 14:04:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.3.131/255.255.0.0 on interface {32F245A6-CAD6-4C76-AB47-D3D9BC4B9D94} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.20 14:04:59 - OpenVPN > Successful ARP Flush on interface [38] {32F245A6-CAD6-4C76-AB47-D3D9BC4B9D94}
. 2016.12.20 14:05:04 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.12.20 14:05:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.116 MASK 255.255.255.255 192.168.0.1
. 2016.12.20 14:05:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.12.20 14:05:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.20 14:05:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 10
. 2016.12.20 14:05:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.20 14:05:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.20 14:05:04 - Starting Management Interface
. 2016.12.20 14:05:04 - OpenVPN > Initialization Sequence Completed
I 2016.12.20 14:05:05 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.20 14:05:05 - DNS of a network adapter forced (Broadcom NetXtreme 57xx Gigabit Controller)
I 2016.12.20 14:05:05 - Flushing DNS
I 2016.12.20 14:05:06 - Checking route
I 2016.12.20 14:05:06 - Checking DNS
! 2016.12.20 14:05:18 - Connected.
. 2016.12.20 14:05:18 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.20 14:05:18 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.12.20 14:06:53 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.12.20 14:06:53 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.12.20 14:06:53 - OpenVPN > Restart pause, 2 second(s)
! 2016.12.20 14:06:53 - Disconnecting
. 2016.12.20 14:06:53 - Management - Send 'signal SIGTERM'
. 2016.12.20 14:06:53 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.20 14:06:53 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.12.20 14:06:53 - OpenVPN > Assertion failed at misc.c:779
. 2016.12.20 14:06:53 - OpenVPN > Exiting due to fatal error
. 2016.12.20 14:06:53 - Connection terminated.
I 2016.12.20 14:06:53 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.20 14:06:53 - DNS of a network adapter restored to original settings (Broadcom NetXtreme 57xx Gigabit Controller)
I 2016.12.20 14:06:56 - Checking authorization ...
W 2016.12.20 14:07:36 - Authorization check failed, continue anyway ({1])
! 2016.12.20 14:07:36 - Connecting to Pleione (Netherlands, Alblasserdam)
. 2016.12.20 14:07:36 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 14:07:37 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 14:07:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 14:07:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 14:07:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:07:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:07:37 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.20 14:07:37 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 14:07:37 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.148:443
. 2016.12.20 14:08:09 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 14:08:09 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 14:08:14 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 14:08:14 - Disconnecting
. 2016.12.20 14:08:14 - Connection terminated.
I 2016.12.20 14:08:17 - Checking authorization ...
W 2016.12.20 14:08:57 - Authorization check failed, continue anyway ({1])
! 2016.12.20 14:08:57 - Connecting to Pleione (Netherlands, Alblasserdam)
. 2016.12.20 14:08:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.20 14:08:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.20 14:08:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.20 14:08:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.20 14:08:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:08:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.20 14:08:57 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.20 14:08:57 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.20 14:08:57 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.148:443
. 2016.12.20 14:09:29 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2016.12.20 14:09:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.20 14:09:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2016.12.20 14:09:34 - Disconnecting
. 2016.12.20 14:09:34 - Connection terminated.
I 2016.12.20 14:09:37 - Checking authorization ...
and so on, in a loop.
You need to switch to the experimental eddie client.  You are using 2.10.  You need to be using the 2.11 client.
Go to here:  https://airvpn.org/windows/
click experimental, then click download, and you will be using the new client.  It's the only one where everything works well in Windows 10.  Both of you are using 2.10.3.
Maybe you're doing something incorrectly, since as per your logs, Eddie is struggling to find your tunnel drivers and you know, it's really hard to go through a tunnel without a driver! . Not seeing any sign of anyone being interested in fixing this, is a strange thing to say in my view, considering you're writing on a forum which has a wealth of threads about issues much like yours. It's just that we can't sticky all threads and thus you have to *search* for them ^^. But also, this forum is made up of volunteers and as such, we have no obligation to answer your queries. Thus if you want actual official support, you should go to your Client Area and submit a support ticket .
Are you or the OP by any chance trying to sign in, while already connected on 2 other devices?
