wildrise 0 Posted ... I 2016.12.09 06:01:13 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64 . 2016.12.09 06:01:13 - Reading options from C:\Users\user6\AppData\Local\AirVPN\AirVPN.xml . 2016.12.09 06:01:13 - Data Path: C:\Users\user6\AppData\Local\AirVPN . 2016.12.09 06:01:13 - App Path: C:\Program Files\AirVPN . 2016.12.09 06:01:13 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe . 2016.12.09 06:01:13 - Command line arguments (1): path="home" . 2016.12.09 06:01:13 - Operating System: Microsoft Windows NT 6.2.9200.0 . 2016.12.09 06:01:13 - Updating systems & servers data ... I 2016.12.09 06:01:13 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2 I 2016.12.09 06:01:13 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe) I 2016.12.09 06:01:13 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe) I 2016.12.09 06:01:13 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe) ! 2016.12.09 06:01:13 - Ready . 2016.12.09 06:01:17 - Systems & servers data update completed I 2016.12.09 06:01:19 - Session starting. I 2016.12.09 06:01:20 - IPv6 disabled. I 2016.12.09 06:01:20 - Checking authorization ... ! 2016.12.09 06:01:20 - Connecting to Matar (Netherlands, Alblasserdam) . 2016.12.09 06:01:20 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015 . 2016.12.09 06:01:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.12.09 06:01:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.12.09 06:01:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.12.09 06:01:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 06:01:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 06:01:20 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072] . 2016.12.09 06:01:20 - OpenVPN > UDPv4 link local: [undef] . 2016.12.09 06:01:20 - OpenVPN > UDPv4 link remote: [AF_INET]109.232.227.137:443 . 2016.12.09 06:01:20 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.137:443, sid=0c9b49e4 bbf96fe5 . 2016.12.09 06:01:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.12.09 06:01:20 - OpenVPN > Validating certificate key usage . 2016.12.09 06:01:20 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.12.09 06:01:20 - OpenVPN > VERIFY KU OK . 2016.12.09 06:01:20 - OpenVPN > Validating certificate extended key usage . 2016.12.09 06:01:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.12.09 06:01:20 - OpenVPN > VERIFY EKU OK . 2016.12.09 06:01:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.12.09 06:01:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 06:01:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 06:01:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 06:01:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 06:01:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.12.09 06:01:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.137:443 . 2016.12.09 06:01:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.12.09 06:01:26 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.93.86 255.255.0.0' . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.12.09 06:01:26 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.12.09 06:01:26 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.12.09 06:01:26 - OpenVPN > open_tun, tt->ipv6=0 . 2016.12.09 06:01:26 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{BFDFF554-91B8-459A-8945-A56EF153E5AB}.tap . 2016.12.09 06:01:26 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.12.09 06:01:26 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.93.86/255.255.0.0 [sUCCEEDED] . 2016.12.09 06:01:26 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.93.86/255.255.0.0 on interface {BFDFF554-91B8-459A-8945-A56EF153E5AB} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.12.09 06:01:26 - OpenVPN > Successful ARP Flush on interface [14] {BFDFF554-91B8-459A-8945-A56EF153E5AB} . 2016.12.09 06:01:31 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.12.09 06:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 109.232.227.137 MASK 255.255.255.255 192.168.1.254 . 2016.12.09 06:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=9 and dwForwardType=4 . 2016.12.09 06:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 06:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 16 . 2016.12.09 06:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=9 and dwForwardType=4 . 2016.12.09 06:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 06:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 06:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 06:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 06:01:31 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 06:01:31 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 06:01:31 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 06:01:31 - Starting Management Interface . 2016.12.09 06:01:31 - OpenVPN > Initialization Sequence Completed I 2016.12.09 06:01:31 - DNS of a network adapter forced (TAP-Windows Adapter V9) I 2016.12.09 06:01:31 - DNS of a network adapter forced (Killer Wireless-n|a|ac 1535 Wireless Network Adapter) I 2016.12.09 06:01:31 - Flushing DNS I 2016.12.09 06:01:31 - Checking route W 2016.12.09 06:02:21 - The operation has timed out ! 2016.12.09 06:02:21 - Disconnecting . 2016.12.09 06:02:21 - Management - Send 'signal SIGTERM' . 2016.12.09 06:02:21 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.12.09 06:02:21 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.12.09 06:02:21 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.12.09 06:02:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 109.232.227.137 MASK 255.255.255.255 192.168.1.254 . 2016.12.09 06:02:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 06:02:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.254 MASK 255.255.255.255 192.168.1.254 . 2016.12.09 06:02:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 06:02:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 06:02:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 06:02:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 06:02:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 06:02:26 - OpenVPN > Closing TUN/TAP interface . 2016.12.09 06:02:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2016.12.09 06:02:26 - Connection terminated. I 2016.12.09 06:02:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9) I 2016.12.09 06:02:26 - DNS of a network adapter restored to original settings (Killer Wireless-n|a|ac 1535 Wireless Network Adapter) I 2016.12.09 06:02:29 - Cancel requested. I 2016.12.09 06:02:29 - IPv6 restored. ! 2016.12.09 06:02:29 - Session terminated. First time using airvpn. Getting a loop of "connecting,flushing DNS disconnecting, restarting,". New to networks so can't figure any of this out myself. Help would be great! Logs are in the spoiler. Thanks Share this post Link to post
itsmefloraluca 7 Posted ... Try installing Eddie 2.11 click on enter at the top of the page and after click on windows and were it says other versions click on it and download Experimental Share this post Link to post
wildrise 0 Posted ... Yeah, doesn't work. If this is the kind of service that's proved then expect airVPN to not last much longer. I'm done. Share this post Link to post
Tech Jedi Alex 1531 Posted ... Yeah, doesn't work. If this is the kind of service that's proved then expect airVPN to not last much longer. I'm done. I was going to help you further, you know, searching topics for those too lazy to do it themselves, reading them, linking to solutions, as I did for many other users here... but not when someone writes this kind of shitposts. Bye! 2 breitfahrt and Khariz reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
LZ1 679 Posted ... Hello! You could also submit a support request, in the client area, OP. But with any VPN, you have to have some patience to resolve issues. Your checking route times out. So you could try going to preferences in the Eddie client and turning off tunnel check and DNS route check, to see if anything works. The fact still remains, that without patience, you'll hardly find any worthwhile services. Sent to you from me with datalove Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Khariz 109 Posted ... Yeah, doesn't work. If this is the kind of service that's proved then expect airVPN to not last much longer. I'm done.I was going to help you further, you know, searching topics for those too lazy to do it themselves, reading them, linking to solutions, as I did for many other users here... but not when someone writes this kind of shitposts. Bye! Wow...I agree completely. If you are going to act like a turd when people try to help you (especially when you could have used the search feature to find your own solution to the problem), I don't care to explain the solution to you. Have fun wherever you end up. Share this post Link to post
