djswitchone 0 Posted ... Hello, I can't connect to any servers. When I click on connect I just get a continuous loops of "connecting, disconnecting, restarting, flushing DNS loop". Could you please help? I have been using this for months now and with no issue until now. Thank you . 2016.12.08 22:33:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:47 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:48 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:49 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:50 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:51 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:52 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:33:53 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:33:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:33:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.24 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:33:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:33:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:33:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 4. 2016.12.08 22:33:54 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:33:54 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:33:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:33:54 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:33:54 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:33:54 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:33:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:33:54 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:33:54 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:33:54 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:33:54 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:33:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:33:54 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 22:33:54 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=4 t=4 pr=3 a=3657 h=0 m=25/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385881 h=0 m=331/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385881 h=0 m=331/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385881 h=0 m=331/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=2168 h=0 m=291/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 169.254.20.104 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2168 h=0 m=291/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2168 h=0 m=291/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=3657 h=0 m=281/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 192.168.0.14 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3657 h=0 m=281/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3657 h=0 m=281/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 213.152.161.24 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385881 h=0 m=331/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=2385879 h=0 m=281/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=3660 h=0 m=291/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385881 h=0 m=331/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=2385879 h=0 m=281/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=3660 h=0 m=291/0/0/0/0. 2016.12.08 22:33:54 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 22:33:54 - OpenVPN > Intel® Ethernet Connection (2) I218-V. 2016.12.08 22:33:54 - OpenVPN > Index = 4. 2016.12.08 22:33:54 - OpenVPN > GUID = {4822C4F8-34F2-4523-8AF5-F0998D0D3559}. 2016.12.08 22:33:54 - OpenVPN > IP = 192.168.0.14/255.255.255.0. 2016.12.08 22:33:54 - OpenVPN > MAC = ac:9e:17:b4:f4:de. 2016.12.08 22:33:54 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255. 2016.12.08 22:33:54 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:26:10 2016. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 22:26:10 2016. 2016.12.08 22:33:54 - OpenVPN > DNS SERV = 194.168.4.100/255.255.255.255 194.168.8.100/255.255.255.255. 2016.12.08 22:33:54 - OpenVPN > VPN Client Adapter - VPN. 2016.12.08 22:33:54 - OpenVPN > Index = 7. 2016.12.08 22:33:54 - OpenVPN > GUID = {96B9CD66-8088-4D86-9DF2-88BF5D2233FF}. 2016.12.08 22:33:54 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 22:33:54 - OpenVPN > MAC = 00:ad:74:1a:87:7c. 2016.12.08 22:33:54 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:33:54 - OpenVPN > DHCP SERV =. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:33:54 2016. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:33:54 2016. 2016.12.08 22:33:54 - OpenVPN > DNS SERV =. 2016.12.08 22:33:54 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 22:33:54 - OpenVPN > Index = 3. 2016.12.08 22:33:54 - OpenVPN > GUID = {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:33:54 - OpenVPN > IP = 169.254.20.104/255.255.0.0. 2016.12.08 22:33:54 - OpenVPN > MAC = 00:ff:1c:4e:f3:0d. 2016.12.08 22:33:54 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:33:54 - OpenVPN > DHCP SERV =. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:33:54 2016. 2016.12.08 22:33:54 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:33:54 2016. 2016.12.08 22:33:54 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 22:33:54 - Starting Management Interface. 2016.12.08 22:33:54 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )I 2016.12.08 22:33:54 - DNS of a network adapter forced (TAP-Windows Adapter V9)! 2016.12.08 22:33:54 - DisconnectingI 2016.12.08 22:33:54 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V). 2016.12.08 22:33:54 - Management - Send 'signal SIGTERM'. 2016.12.08 22:33:54 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoI 2016.12.08 22:33:54 - Flushing DNS. 2016.12.08 22:33:54 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 22:33:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 22:33:54 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 22:33:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.24 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:33:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:33:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:33:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:33:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:33:59 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:33:59 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:33:59 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:33:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:33:59 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:33:59 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:33:59 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:33:59 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:33:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:33:59 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 22:33:59 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 22:33:59 - Connection terminated.I 2016.12.08 22:33:59 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 22:33:59 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:34:02 - Checking authorization ...! 2016.12.08 22:34:02 - Connecting to Nash (Netherlands, Alblasserdam). 2016.12.08 22:34:02 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 22:34:02 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 22:34:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 22:34:02 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 22:34:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:34:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:34:02 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 22:34:02 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 22:34:02 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.12.08 22:34:02 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.24:443, sid=4809e8a8 84126bee. 2016.12.08 22:34:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 22:34:02 - OpenVPN > Validating certificate key usage. 2016.12.08 22:34:02 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 22:34:02 - OpenVPN > VERIFY KU OK. 2016.12.08 22:34:02 - OpenVPN > Validating certificate extended key usage. 2016.12.08 22:34:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 22:34:02 - OpenVPN > VERIFY EKU OK. 2016.12.08 22:34:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 22:34:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:34:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:34:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:34:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:34:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 22:34:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.24:443. 2016.12.08 22:34:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 22:34:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.89.25 255.255.0.0'. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 22:34:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 22:34:07 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 22:34:07 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 22:34:07 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}.tap. 2016.12.08 22:34:07 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 22:34:07 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.89.25/255.255.0.0 [sUCCEEDED]. 2016.12.08 22:34:07 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.89.25/255.255.0.0 on interface {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 22:34:07 - OpenVPN > Successful ARP Flush on interface [3] {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:34:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:13 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:18 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:18 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:18 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:19 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:20 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:20 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:20 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:21 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:23 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:23 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:23 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:24 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:25 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:26 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:27 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:28 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:29 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:30 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:32 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:33 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:34 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:35 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:36 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:37 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:38 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:39 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:40 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:34:41 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:34:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:34:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.24 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:34:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:34:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:34:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 4. 2016.12.08 22:34:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:34:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:34:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:34:42 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:34:42 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:34:42 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:34:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:34:42 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:34:43 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:34:43 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:34:43 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:34:43 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:34:43 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 22:34:43 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=4 t=4 pr=3 a=3705 h=0 m=25/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385930 h=0 m=331/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385930 h=0 m=331/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385930 h=0 m=331/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=2217 h=0 m=291/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 169.254.20.104 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2217 h=0 m=291/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2217 h=0 m=291/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=3705 h=0 m=281/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 192.168.0.14 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3705 h=0 m=281/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3705 h=0 m=281/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 213.152.161.24 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385930 h=0 m=331/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=2385927 h=0 m=281/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=3708 h=0 m=291/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2385930 h=0 m=331/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=2385927 h=0 m=281/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=3708 h=0 m=291/0/0/0/0. 2016.12.08 22:34:43 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 22:34:43 - OpenVPN > Intel® Ethernet Connection (2) I218-V. 2016.12.08 22:34:43 - OpenVPN > Index = 4. 2016.12.08 22:34:43 - OpenVPN > GUID = {4822C4F8-34F2-4523-8AF5-F0998D0D3559}. 2016.12.08 22:34:43 - OpenVPN > IP = 192.168.0.14/255.255.255.0. 2016.12.08 22:34:43 - OpenVPN > MAC = ac:9e:17:b4:f4:de. 2016.12.08 22:34:43 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255. 2016.12.08 22:34:43 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:33:59 2016. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 22:33:59 2016. 2016.12.08 22:34:43 - OpenVPN > DNS SERV = 194.168.4.100/255.255.255.255 194.168.8.100/255.255.255.255. 2016.12.08 22:34:43 - OpenVPN > VPN Client Adapter - VPN. 2016.12.08 22:34:43 - OpenVPN > Index = 7. 2016.12.08 22:34:43 - OpenVPN > GUID = {96B9CD66-8088-4D86-9DF2-88BF5D2233FF}. 2016.12.08 22:34:43 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 22:34:43 - OpenVPN > MAC = 00:ad:74:1a:87:7c. 2016.12.08 22:34:43 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:34:43 - OpenVPN > DHCP SERV =. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:34:43 2016. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:34:43 2016. 2016.12.08 22:34:43 - OpenVPN > DNS SERV =. 2016.12.08 22:34:43 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 22:34:43 - OpenVPN > Index = 3. 2016.12.08 22:34:43 - OpenVPN > GUID = {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:34:43 - OpenVPN > IP = 169.254.20.104/255.255.0.0. 2016.12.08 22:34:43 - OpenVPN > MAC = 00:ff:1c:4e:f3:0d. 2016.12.08 22:34:43 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:34:43 - OpenVPN > DHCP SERV =. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:34:43 2016. 2016.12.08 22:34:43 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:34:43 2016. 2016.12.08 22:34:43 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 22:34:43 - Starting Management Interface. 2016.12.08 22:34:43 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.08 22:34:43 - Disconnecting. 2016.12.08 22:34:43 - Management - Send 'signal SIGTERM'. 2016.12.08 22:34:43 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoI 2016.12.08 22:34:43 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 22:34:43 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:34:43 - Flushing DNS. 2016.12.08 22:34:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 22:34:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 22:34:43 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 22:34:48 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.24 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:34:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:34:48 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:34:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:34:48 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:34:48 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:34:48 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:34:48 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:34:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:34:48 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:34:48 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:34:48 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:34:48 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:34:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:34:48 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 22:34:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 22:34:48 - Connection terminated.I 2016.12.08 22:34:48 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 22:34:48 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:34:48 - Cancel requested.I 2016.12.08 22:34:48 - IPv6 restored.! 2016.12.08 22:34:48 - Session terminated.I 2016.12.08 22:37:37 - Session starting.I 2016.12.08 22:37:37 - IPv6 disabled.I 2016.12.08 22:37:37 - Checking authorization ...! 2016.12.08 22:37:37 - Connecting to Hyadum (Netherlands, Alblasserdam). 2016.12.08 22:37:37 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 22:37:37 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 22:37:37 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 22:37:37 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 22:37:37 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:37:37 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:37:37 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 22:37:37 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 22:37:37 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2016.12.08 22:37:37 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=a778110e 6127fadc. 2016.12.08 22:37:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 22:37:37 - OpenVPN > Validating certificate key usage. 2016.12.08 22:37:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 22:37:37 - OpenVPN > VERIFY KU OK. 2016.12.08 22:37:37 - OpenVPN > Validating certificate extended key usage. 2016.12.08 22:37:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 22:37:37 - OpenVPN > VERIFY EKU OK. 2016.12.08 22:37:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 22:37:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:37:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:37:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:37:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:37:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 22:37:38 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2016.12.08 22:37:40 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 22:37:40 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.77.127 255.255.0.0'. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 22:37:40 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 22:37:40 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 22:37:40 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 22:37:40 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}.tap. 2016.12.08 22:37:40 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 22:37:40 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.77.127/255.255.0.0 [sUCCEEDED]. 2016.12.08 22:37:40 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.77.127/255.255.0.0 on interface {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 22:37:40 - OpenVPN > Successful ARP Flush on interface [3] {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:37:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:46 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:51 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:52 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:53 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:54 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:55 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:56 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:58 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:37:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:37:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:37:59 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:00 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:01 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:02 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:03 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:05 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:06 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:07 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:08 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:09 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:10 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:11 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:11 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:12 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:12 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:12 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:13 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:13 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:13 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:14 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:14 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:14 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:15 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:38:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:38:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:38:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 4. 2016.12.08 22:38:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:38:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:38:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:38:15 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:38:15 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:38:15 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:38:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:38:15 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:38:15 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:38:15 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:38:15 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:38:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:38:16 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 22:38:16 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=4 t=4 pr=3 a=3918 h=0 m=25/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386143 h=0 m=331/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386143 h=0 m=331/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386143 h=0 m=331/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=2430 h=0 m=291/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 169.254.20.104 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2430 h=0 m=291/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2430 h=0 m=291/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=3918 h=0 m=281/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 192.168.0.14 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3918 h=0 m=281/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3918 h=0 m=281/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 213.152.161.34 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386143 h=0 m=331/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386140 h=0 m=281/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=3921 h=0 m=291/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386143 h=0 m=331/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386140 h=0 m=281/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=3921 h=0 m=291/0/0/0/0. 2016.12.08 22:38:16 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 22:38:16 - OpenVPN > Intel® Ethernet Connection (2) I218-V. 2016.12.08 22:38:16 - OpenVPN > Index = 4. 2016.12.08 22:38:16 - OpenVPN > GUID = {4822C4F8-34F2-4523-8AF5-F0998D0D3559}. 2016.12.08 22:38:16 - OpenVPN > IP = 192.168.0.14/255.255.255.0. 2016.12.08 22:38:16 - OpenVPN > MAC = ac:9e:17:b4:f4:de. 2016.12.08 22:38:16 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255. 2016.12.08 22:38:16 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:37:08 2016. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 22:37:08 2016. 2016.12.08 22:38:16 - OpenVPN > DNS SERV = 194.168.4.100/255.255.255.255 194.168.8.100/255.255.255.255. 2016.12.08 22:38:16 - OpenVPN > VPN Client Adapter - VPN. 2016.12.08 22:38:16 - OpenVPN > Index = 7. 2016.12.08 22:38:16 - OpenVPN > GUID = {96B9CD66-8088-4D86-9DF2-88BF5D2233FF}. 2016.12.08 22:38:16 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 22:38:16 - OpenVPN > MAC = 00:ad:74:1a:87:7c. 2016.12.08 22:38:16 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:38:16 - OpenVPN > DHCP SERV =. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:38:16 2016. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:38:16 2016. 2016.12.08 22:38:16 - OpenVPN > DNS SERV =. 2016.12.08 22:38:16 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 22:38:16 - OpenVPN > Index = 3. 2016.12.08 22:38:16 - OpenVPN > GUID = {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:38:16 - OpenVPN > IP = 169.254.20.104/255.255.0.0. 2016.12.08 22:38:16 - OpenVPN > MAC = 00:ff:1c:4e:f3:0d. 2016.12.08 22:38:16 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:38:16 - OpenVPN > DHCP SERV =. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:38:16 2016. 2016.12.08 22:38:16 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:38:16 2016. 2016.12.08 22:38:16 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 22:38:16 - Starting Management Interface. 2016.12.08 22:38:16 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.08 22:38:16 - Disconnecting. 2016.12.08 22:38:16 - Management - Send 'signal SIGTERM'. 2016.12.08 22:38:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoI 2016.12.08 22:38:16 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 22:38:16 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:38:16 - Flushing DNS. 2016.12.08 22:38:16 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 22:38:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 22:38:16 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 22:38:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:38:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:38:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:38:21 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:38:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:38:21 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:38:21 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:38:21 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:38:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:38:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:38:21 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:38:21 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:38:21 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:38:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:38:22 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 22:38:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 22:38:22 - Connection terminated.I 2016.12.08 22:38:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 22:38:22 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:38:25 - Checking authorization ...! 2016.12.08 22:38:25 - Connecting to Hyadum (Netherlands, Alblasserdam). 2016.12.08 22:38:25 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 22:38:25 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 22:38:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 22:38:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 22:38:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:38:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:38:25 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 22:38:25 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 22:38:25 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2016.12.08 22:38:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=ebe56bca 21997007. 2016.12.08 22:38:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 22:38:25 - OpenVPN > Validating certificate key usage. 2016.12.08 22:38:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 22:38:25 - OpenVPN > VERIFY KU OK. 2016.12.08 22:38:25 - OpenVPN > Validating certificate extended key usage. 2016.12.08 22:38:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 22:38:25 - OpenVPN > VERIFY EKU OK. 2016.12.08 22:38:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 22:38:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:38:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:38:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:38:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:38:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 22:38:27 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2016.12.08 22:38:29 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 22:38:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.77.127 255.255.0.0'. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 22:38:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 22:38:29 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 22:38:29 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 22:38:29 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}.tap. 2016.12.08 22:38:29 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 22:38:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.77.127/255.255.0.0 [sUCCEEDED]. 2016.12.08 22:38:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.77.127/255.255.0.0 on interface {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 22:38:29 - OpenVPN > Successful ARP Flush on interface [3] {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:38:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:35 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:41 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:42 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:43 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:44 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:45 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:46 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:47 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:48 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:49 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:50 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:52 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:53 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:54 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:55 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:56 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:57 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:58 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:38:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:38:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:38:59 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:01 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:02 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:03 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:39:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:39:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 4. 2016.12.08 22:39:04 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:39:04 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:39:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:04 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:04 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:39:04 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:39:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:04 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:04 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:04 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:39:04 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:39:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:04 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 22:39:04 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=4 t=4 pr=3 a=3967 h=0 m=25/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386191 h=0 m=331/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386191 h=0 m=331/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386191 h=0 m=331/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=2478 h=0 m=291/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 169.254.20.104 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2478 h=0 m=291/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2478 h=0 m=291/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=3967 h=0 m=281/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 192.168.0.14 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3967 h=0 m=281/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=3967 h=0 m=281/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 213.152.161.34 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386191 h=0 m=331/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386189 h=0 m=281/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=3970 h=0 m=291/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386191 h=0 m=331/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386189 h=0 m=281/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=3970 h=0 m=291/0/0/0/0. 2016.12.08 22:39:04 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 22:39:04 - OpenVPN > Intel® Ethernet Connection (2) I218-V. 2016.12.08 22:39:04 - OpenVPN > Index = 4. 2016.12.08 22:39:04 - OpenVPN > GUID = {4822C4F8-34F2-4523-8AF5-F0998D0D3559}. 2016.12.08 22:39:04 - OpenVPN > IP = 192.168.0.14/255.255.255.0. 2016.12.08 22:39:04 - OpenVPN > MAC = ac:9e:17:b4:f4:de. 2016.12.08 22:39:04 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255. 2016.12.08 22:39:04 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:38:22 2016. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 22:38:22 2016. 2016.12.08 22:39:04 - OpenVPN > DNS SERV = 194.168.4.100/255.255.255.255 194.168.8.100/255.255.255.255. 2016.12.08 22:39:04 - OpenVPN > VPN Client Adapter - VPN. 2016.12.08 22:39:04 - OpenVPN > Index = 7. 2016.12.08 22:39:04 - OpenVPN > GUID = {96B9CD66-8088-4D86-9DF2-88BF5D2233FF}. 2016.12.08 22:39:04 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 22:39:04 - OpenVPN > MAC = 00:ad:74:1a:87:7c. 2016.12.08 22:39:04 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:39:04 - OpenVPN > DHCP SERV =. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:39:04 2016. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:39:04 2016. 2016.12.08 22:39:04 - OpenVPN > DNS SERV =. 2016.12.08 22:39:04 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 22:39:04 - OpenVPN > Index = 3. 2016.12.08 22:39:04 - OpenVPN > GUID = {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:39:04 - OpenVPN > IP = 169.254.20.104/255.255.0.0. 2016.12.08 22:39:04 - OpenVPN > MAC = 00:ff:1c:4e:f3:0d. 2016.12.08 22:39:04 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:39:04 - OpenVPN > DHCP SERV =. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:39:04 2016. 2016.12.08 22:39:04 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:39:04 2016. 2016.12.08 22:39:04 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 22:39:04 - Starting Management Interface. 2016.12.08 22:39:04 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )I 2016.12.08 22:39:04 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 22:39:04 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:39:04 - Flushing DNS! 2016.12.08 22:39:04 - Disconnecting. 2016.12.08 22:39:04 - Management - Send 'signal SIGTERM'. 2016.12.08 22:39:04 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.08 22:39:04 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 22:39:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 22:39:04 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 22:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:09 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:09 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:09 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:39:09 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:39:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:09 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:09 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:09 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:39:09 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:39:09 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:09 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 22:39:09 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 22:39:09 - Connection terminated.I 2016.12.08 22:39:09 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 22:39:09 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:39:13 - Checking authorization ...! 2016.12.08 22:39:13 - Connecting to Hyadum (Netherlands, Alblasserdam). 2016.12.08 22:39:13 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 22:39:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 22:39:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 22:39:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 22:39:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:13 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 22:39:13 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 22:39:13 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2016.12.08 22:39:13 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=7f017abb ff5946d5. 2016.12.08 22:39:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 22:39:13 - OpenVPN > Validating certificate key usage. 2016.12.08 22:39:13 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 22:39:13 - OpenVPN > VERIFY KU OK. 2016.12.08 22:39:13 - OpenVPN > Validating certificate extended key usage. 2016.12.08 22:39:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 22:39:13 - OpenVPN > VERIFY EKU OK. 2016.12.08 22:39:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 22:39:13 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:39:13 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:13 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:39:13 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 22:39:13 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2016.12.08 22:39:15 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 22:39:15 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.77.127 255.255.0.0'. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 22:39:15 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 22:39:16 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 22:39:16 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 22:39:16 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}.tap. 2016.12.08 22:39:16 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 22:39:16 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.77.127/255.255.0.0 [sUCCEEDED]. 2016.12.08 22:39:16 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.77.127/255.255.0.0 on interface {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 22:39:16 - OpenVPN > Successful ARP Flush on interface [3] {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:39:21 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:21 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:21 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:26 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:28 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:29 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:30 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:31 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:33 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:34 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:35 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:36 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:37 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:38 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:39 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:40 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:41 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:42 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:43 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:44 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:45 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:47 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:48 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:49 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 22:39:50 - AirVPN Windows Interface Hack executed (Ethernet 2). 2016.12.08 22:39:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 22:39:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:39:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:39:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 4. 2016.12.08 22:39:51 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 22:39:51 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 22:39:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:51 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:51 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:39:51 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:39:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:51 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:51 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:51 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 22:39:51 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 22:39:51 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:51 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 22:39:51 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=4 t=4 pr=3 a=4014 h=0 m=25/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386238 h=0 m=331/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386238 h=0 m=331/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386238 h=0 m=331/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=2525 h=0 m=291/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 169.254.20.104 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2525 h=0 m=291/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=2525 h=0 m=291/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=4014 h=0 m=281/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 192.168.0.14 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=4014 h=0 m=281/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=4014 h=0 m=281/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 213.152.161.34 255.255.255.255 192.168.0.1 p=0 i=4 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386238 h=0 m=331/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386236 h=0 m=281/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.20.104 p=0 i=3 t=3 pr=2 a=4017 h=0 m=291/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2386238 h=0 m=331/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.14 p=0 i=4 t=3 pr=2 a=2386236 h=0 m=281/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.20.104 p=0 i=3 t=3 pr=2 a=4017 h=0 m=291/0/0/0/0. 2016.12.08 22:39:51 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 22:39:51 - OpenVPN > Intel® Ethernet Connection (2) I218-V. 2016.12.08 22:39:51 - OpenVPN > Index = 4. 2016.12.08 22:39:51 - OpenVPN > GUID = {4822C4F8-34F2-4523-8AF5-F0998D0D3559}. 2016.12.08 22:39:51 - OpenVPN > IP = 192.168.0.14/255.255.255.0. 2016.12.08 22:39:51 - OpenVPN > MAC = ac:9e:17:b4:f4:de. 2016.12.08 22:39:51 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255. 2016.12.08 22:39:51 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:39:10 2016. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 22:39:10 2016. 2016.12.08 22:39:51 - OpenVPN > DNS SERV = 194.168.4.100/255.255.255.255 194.168.8.100/255.255.255.255. 2016.12.08 22:39:51 - OpenVPN > VPN Client Adapter - VPN. 2016.12.08 22:39:51 - OpenVPN > Index = 7. 2016.12.08 22:39:51 - OpenVPN > GUID = {96B9CD66-8088-4D86-9DF2-88BF5D2233FF}. 2016.12.08 22:39:51 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 22:39:51 - OpenVPN > MAC = 00:ad:74:1a:87:7c. 2016.12.08 22:39:51 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:39:51 - OpenVPN > DHCP SERV =. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:39:51 2016. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:39:51 2016. 2016.12.08 22:39:51 - OpenVPN > DNS SERV =. 2016.12.08 22:39:51 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 22:39:51 - OpenVPN > Index = 3. 2016.12.08 22:39:51 - OpenVPN > GUID = {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}. 2016.12.08 22:39:51 - OpenVPN > IP = 169.254.20.104/255.255.0.0. 2016.12.08 22:39:51 - OpenVPN > MAC = 00:ff:1c:4e:f3:0d. 2016.12.08 22:39:51 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 22:39:51 - OpenVPN > DHCP SERV =. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 22:39:51 2016. 2016.12.08 22:39:51 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 22:39:51 2016. 2016.12.08 22:39:51 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 22:39:51 - Starting Management Interface. 2016.12.08 22:39:51 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )I 2016.12.08 22:39:51 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 22:39:51 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)! 2016.12.08 22:39:51 - Disconnecting. 2016.12.08 22:39:51 - Management - Send 'signal SIGTERM'. 2016.12.08 22:39:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoI 2016.12.08 22:39:51 - Flushing DNS. 2016.12.08 22:39:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 22:39:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 22:39:51 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 22:39:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.34 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:39:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1. 2016.12.08 22:39:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 22:39:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:56 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:56 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:39:56 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:39:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 22:39:56 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 22:39:56 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 22:39:56 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 22:39:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 22:39:56 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 22:39:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 22:39:56 - Connection terminated.I 2016.12.08 22:39:56 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 22:39:56 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)I 2016.12.08 22:39:59 - Checking authorization ...! 2016.12.08 22:39:59 - Connecting to Hyadum (Netherlands, Alblasserdam). 2016.12.08 22:39:59 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 22:39:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 22:39:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 22:39:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 22:39:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:39:59 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 22:39:59 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 22:39:59 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.34:443. 2016.12.08 22:39:59 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.34:443, sid=f759a941 8653fad0. 2016.12.08 22:39:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 22:39:59 - OpenVPN > Validating certificate key usage. 2016.12.08 22:39:59 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 22:39:59 - OpenVPN > VERIFY KU OK. 2016.12.08 22:39:59 - OpenVPN > Validating certificate extended key usage. 2016.12.08 22:39:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 22:39:59 - OpenVPN > VERIFY EKU OK. 2016.12.08 22:39:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 22:40:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:40:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:40:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 22:40:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 22:40:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 22:40:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.34:443. 2016.12.08 22:40:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 22:40:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.77.127 255.255.0.0'. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 22:40:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 22:40:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 22:40:02 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 22:40:02 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{1C4EF30D-6C77-41C1-86BB-11C51D5B23BB}.tap. 2016.12.08 22:40:02 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 22:40:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.77.127/255.255.0.0 [sUCCEEDED]. 2016.12.08 22:40:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.77.127/255.255.0.0 on interface {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 22:40:02 - OpenVPN > Successful ARP Flush on interface [3] {1C4EF30D-6C77-41C1-86BB-11C51D5B23BB} Quote Share this post Link to post
kumquatq3 0 Posted ... I have the same issue. Tried a clean reinstall. Tried turning off windows firewall. Made sure DNS settings set to automatic. Tried about a dozen servers. Nothing. EDIT: Active Network lock off and on, no change. . 2016.12.08 16:47:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 16:47:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.9.80 255.255.0.0'. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 16:47:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 16:47:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 16:47:17 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 16:47:17 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}.tap. 2016.12.08 16:47:17 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 16:47:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.9.80/255.255.0.0 [sUCCEEDED]. 2016.12.08 16:47:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.9.80/255.255.0.0 on interface {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 16:47:17 - OpenVPN > Successful ARP Flush on interface [8] {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}. 2016.12.08 16:47:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:22 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:27 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:28 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:28 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:29 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:31 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:32 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:33 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:34 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:35 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:36 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:37 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:38 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:39 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:40 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:41 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:43 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:44 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:45 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:46 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:47 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:49 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:50 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 16:47:51 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 16:47:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 16:47:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.58 MASK 255.255.255.255 192.168.1.1. 2016.12.08 16:47:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 16:47:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 16:47:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 20. 2016.12.08 16:47:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 16:47:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 16:47:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 16:47:52 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 16:47:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 16:47:52 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 16:47:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 16:47:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 16:47:52 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 16:47:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 16:47:52 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 16:47:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 16:47:52 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 16:47:52 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=20 t=4 pr=3 a=1462025 h=0 m=25/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2421261 h=0 m=331/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2421261 h=0 m=331/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2421261 h=0 m=331/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.12.191 p=0 i=8 t=3 pr=2 a=172 h=0 m=291/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 169.254.12.191 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=172 h=0 m=291/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=172 h=0 m=291/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 184.75.221.58 255.255.255.255 192.168.1.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.154 p=0 i=20 t=3 pr=2 a=1462025 h=0 m=281/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 192.168.1.1 255.255.255.255 192.168.1.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 192.168.1.154 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=1462025 h=0 m=281/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=1462025 h=0 m=281/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2421261 h=0 m=331/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.154 p=0 i=20 t=3 pr=2 a=2421248 h=0 m=281/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.12.191 p=0 i=8 t=3 pr=2 a=10789 h=0 m=291/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2421261 h=0 m=331/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=2421248 h=0 m=281/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=10789 h=0 m=291/0/0/0/0. 2016.12.08 16:47:52 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 16:47:52 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 16:47:52 - OpenVPN > Index = 8. 2016.12.08 16:47:52 - OpenVPN > GUID = {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}. 2016.12.08 16:47:52 - OpenVPN > IP = 169.254.12.191/255.255.0.0. 2016.12.08 16:47:52 - OpenVPN > MAC = 00:ff:ab:94:ec:06. 2016.12.08 16:47:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > DHCP SERV =. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > Bluetooth Device (Personal Area Network). 2016.12.08 16:47:52 - OpenVPN > Index = 17. 2016.12.08 16:47:52 - OpenVPN > GUID = {62B8661A-226C-475B-810E-1192C9AFC9FB}. 2016.12.08 16:47:52 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 16:47:52 - OpenVPN > MAC = 00:02:72:ce:2b:0d. 2016.12.08 16:47:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > DHCP SERV =. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DNS SERV =. 2016.12.08 16:47:52 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30). 2016.12.08 16:47:52 - OpenVPN > Index = 19. 2016.12.08 16:47:52 - OpenVPN > GUID = {D4FDE18D-7406-46A1-A843-8953E73B0341}. 2016.12.08 16:47:52 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 16:47:52 - OpenVPN > MAC = 90:2b:34:34:d1:8e. 2016.12.08 16:47:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > DHCP SERV =. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 16:47:52 2016. 2016.12.08 16:47:52 - OpenVPN > DNS SERV =. 2016.12.08 16:47:52 - OpenVPN > Intel® 82579V Gigabit Network Connection. 2016.12.08 16:47:52 - OpenVPN > Index = 20. 2016.12.08 16:47:52 - OpenVPN > GUID = {892AA65F-0FC8-40F3-84D8-7A44584E76EB}. 2016.12.08 16:47:52 - OpenVPN > IP = 192.168.1.154/255.255.255.0. 2016.12.08 16:47:52 - OpenVPN > MAC = 90:2b:34:34:d1:7e. 2016.12.08 16:47:52 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 16:47:08 2016. 2016.12.08 16:47:52 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 16:47:08 2016. 2016.12.08 16:47:52 - OpenVPN > DNS SERV = 192.168.1.1/255.255.255.255. 2016.12.08 16:47:52 - Starting Management Interface. 2016.12.08 16:47:52 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )! 2016.12.08 16:47:52 - Disconnecting. 2016.12.08 16:47:52 - Management - Send 'signal SIGTERM'. 2016.12.08 16:47:52 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more infoI 2016.12.08 16:47:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 16:47:52 - DNS of a network adapter forced (Intel® 82579V Gigabit Network Connection)I 2016.12.08 16:47:52 - Flushing DNS. 2016.12.08 16:47:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 16:47:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 16:47:52 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.12.08 16:47:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.221.58 MASK 255.255.255.255 192.168.1.1. 2016.12.08 16:47:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 16:47:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.1.1 MASK 255.255.255.255 192.168.1.1. 2016.12.08 16:47:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2016.12.08 16:47:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 16:47:57 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 16:47:57 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 16:47:57 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 16:47:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 16:47:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 16:47:57 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 16:47:57 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2016.12.08 16:47:57 - OpenVPN > Route deletion fallback to route.exe. 2016.12.08 16:47:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 16:47:57 - OpenVPN > Closing TUN/TAP interface. 2016.12.08 16:47:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2016.12.08 16:47:57 - Connection terminated.I 2016.12.08 16:47:57 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)I 2016.12.08 16:47:57 - DNS of a network adapter restored to original settings (Intel® 82579V Gigabit Network Connection)I 2016.12.08 16:48:00 - Checking authorization ...! 2016.12.08 16:48:00 - Connecting to Ukdah (Canada, Toronto, Ontario). 2016.12.08 16:48:00 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 16:48:00 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 16:48:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 16:48:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 16:48:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 16:48:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 16:48:00 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 16:48:00 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 16:48:00 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.58:443. 2016.12.08 16:48:00 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.58:443, sid=82a2a4d4 8f9c629e. 2016.12.08 16:48:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 16:48:00 - OpenVPN > Validating certificate key usage. 2016.12.08 16:48:00 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 16:48:00 - OpenVPN > VERIFY KU OK. 2016.12.08 16:48:00 - OpenVPN > Validating certificate extended key usage. 2016.12.08 16:48:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 16:48:00 - OpenVPN > VERIFY EKU OK. 2016.12.08 16:48:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 16:48:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 16:48:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 16:48:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 16:48:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 16:48:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 16:48:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.58:443 Quote Share this post Link to post
LZ1 679 Posted ... Hello! It's excellent you both provided logs in spoilers. Remember to always provide logs from line 1 as well, as it contains useful information. Anyhow, your TAP adapter isn't turning on. So try go to your networking settings and disable and then enable the TAP adapter. Then you can go into the properties of that adapter as well and under Advanced, set its "Media Status" to either "Always Connected" or "Application Controlled". Then click Apply. That will fix the issue, at least on Windows . Otherwise OP, you should try a restart as well, if you're on OSX. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
djswitchone 0 Posted ... Once again I stand impressed with the speed of the customer service here. Quality! Many thanks my friend. That's it connected now. Cheers! Quote Share this post Link to post
kumquatq3 0 Posted ... First, thank you for trying. Unfortunately, didn't do that trick. First, you were right, in network connections (windows 10) my TAP had a red "x". I disabled and reenabled. No change with Air VPN or the red X. Went to "properties" then "config" then Advanced tab, then "media status", which give me only "Always Connected" or "Application Controlled". It was on Application Controlled, switched to Always connected. Bingo, Red X goes away, but it just says "identifying". I disable and enable, just says "identifying". I diagnose, it tells me "Ethernet 3 doesn't have a valid IP configuration. I got to IPv4, notice it is not set to automatic for DNS, I change it to Automatic. No change. That's where I am at. I then tried to connect, and included the logs below: I 2016.12.08 18:05:11 - Session starting.I 2016.12.08 18:05:11 - Checking authorization ...! 2016.12.08 18:05:12 - Connecting to Sualocin (Canada, Toronto, Ontario). 2016.12.08 18:05:12 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015. 2016.12.08 18:05:12 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08. 2016.12.08 18:05:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.12.08 18:05:12 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.12.08 18:05:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 18:05:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 18:05:12 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]. 2016.12.08 18:05:12 - OpenVPN > UDPv4 link local: [undef]. 2016.12.08 18:05:12 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.221.42:443. 2016.12.08 18:05:12 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.221.42:443, sid=617392fb cb5252d0. 2016.12.08 18:05:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2016.12.08 18:05:12 - OpenVPN > Validating certificate key usage. 2016.12.08 18:05:12 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2016.12.08 18:05:12 - OpenVPN > VERIFY KU OK. 2016.12.08 18:05:12 - OpenVPN > Validating certificate extended key usage. 2016.12.08 18:05:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2016.12.08 18:05:12 - OpenVPN > VERIFY EKU OK. 2016.12.08 18:05:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2016.12.08 18:05:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 18:05:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 18:05:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2016.12.08 18:05:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.12.08 18:05:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2016.12.08 18:05:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.221.42:443. 2016.12.08 18:05:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2016.12.08 18:05:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.11.92 255.255.0.0'. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: route options modified. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2016.12.08 18:05:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2016.12.08 18:05:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0. 2016.12.08 18:05:17 - OpenVPN > open_tun, tt->ipv6=0. 2016.12.08 18:05:17 - OpenVPN > TAP-WIN32 device [Ethernet 3] opened: \\.\Global\{AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}.tap. 2016.12.08 18:05:17 - OpenVPN > TAP-Windows Driver Version 9.21. 2016.12.08 18:05:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.11.92/255.255.0.0 [sUCCEEDED]. 2016.12.08 18:05:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.11.92/255.255.0.0 on interface {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2016.12.08 18:05:17 - OpenVPN > Successful ARP Flush on interface [8] {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}. 2016.12.08 18:05:22 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:22 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:22 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:27 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:29 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:30 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:31 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:32 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:33 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:35 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:36 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:37 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:38 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:39 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:41 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:42 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:43 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:44 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:45 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:46 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:47 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:48 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:49 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up.... 2016.12.08 18:05:50 - AirVPN Windows Interface Hack executed (Ethernet 3). 2016.12.08 18:05:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down. 2016.12.08 18:05:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.221.42 MASK 255.255.255.255 192.168.1.1. 2016.12.08 18:05:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 18:05:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 18:05:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.1 MASK 255.255.255.255 192.168.1.1 IF 20. 2016.12.08 18:05:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2016.12.08 18:05:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2016.12.08 18:05:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 18:05:52 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 18:05:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 18:05:52 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 18:05:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 18:05:52 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2016.12.08 18:05:52 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2016.12.08 18:05:52 - OpenVPN > Route addition via IPAPI failed [adaptive]. 2016.12.08 18:05:52 - OpenVPN > Route addition fallback to route.exe. 2016.12.08 18:05:52 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem. 2016.12.08 18:05:52 - OpenVPN > SYSTEM ROUTING TABLE. 2016.12.08 18:05:52 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.1.1 p=0 i=20 t=4 pr=3 a=1466704 h=0 m=25/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2425940 h=0 m=331/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2425940 h=0 m=331/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2425940 h=0 m=331/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=26/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.12.191 p=0 i=8 t=3 pr=2 a=200 h=0 m=291/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 169.254.12.191 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=200 h=0 m=291/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=200 h=0 m=291/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 184.75.221.42 255.255.255.255 192.168.1.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 192.168.1.0 255.255.255.0 192.168.1.154 p=0 i=20 t=3 pr=2 a=1466704 h=0 m=281/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 192.168.1.1 255.255.255.255 192.168.1.1 p=0 i=20 t=4 pr=3 a=0 h=0 m=25/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 192.168.1.154 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=1466704 h=0 m=281/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 192.168.1.255 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=1466704 h=0 m=281/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=2425940 h=0 m=331/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.1.154 p=0 i=20 t=3 pr=2 a=2425928 h=0 m=281/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.12.191 p=0 i=8 t=3 pr=2 a=210 h=0 m=291/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=2425940 h=0 m=331/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.1.154 p=0 i=20 t=3 pr=2 a=2425928 h=0 m=281/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.12.191 p=0 i=8 t=3 pr=2 a=210 h=0 m=291/0/0/0/0. 2016.12.08 18:05:52 - OpenVPN > SYSTEM ADAPTER LIST. 2016.12.08 18:05:52 - OpenVPN > TAP-Windows Adapter V9. 2016.12.08 18:05:52 - OpenVPN > Index = 8. 2016.12.08 18:05:52 - OpenVPN > GUID = {AB94EC06-2629-4F3A-A4B3-9566FA2FCCD2}. 2016.12.08 18:05:52 - OpenVPN > IP = 169.254.12.191/255.255.0.0. 2016.12.08 18:05:52 - OpenVPN > MAC = 00:ff:ab:94:ec:06. 2016.12.08 18:05:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > DHCP SERV =. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DNS SERV = 10.4.0.1/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > Bluetooth Device (Personal Area Network). 2016.12.08 18:05:52 - OpenVPN > Index = 17. 2016.12.08 18:05:52 - OpenVPN > GUID = {62B8661A-226C-475B-810E-1192C9AFC9FB}. 2016.12.08 18:05:52 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 18:05:52 - OpenVPN > MAC = 00:02:72:ce:2b:0d. 2016.12.08 18:05:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > DHCP SERV =. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DNS SERV =. 2016.12.08 18:05:52 - OpenVPN > Qualcomm Atheros AR8151 PCI-E Gigabit Ethernet Controller (NDIS 6.30). 2016.12.08 18:05:52 - OpenVPN > Index = 19. 2016.12.08 18:05:52 - OpenVPN > GUID = {D4FDE18D-7406-46A1-A843-8953E73B0341}. 2016.12.08 18:05:52 - OpenVPN > IP = 0.0.0.0/0.0.0.0. 2016.12.08 18:05:52 - OpenVPN > MAC = 90:2b:34:34:d1:8e. 2016.12.08 18:05:52 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > DHCP SERV =. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE EXPIRES = Thu Dec 08 18:05:52 2016. 2016.12.08 18:05:52 - OpenVPN > DNS SERV =. 2016.12.08 18:05:52 - OpenVPN > Intel® 82579V Gigabit Network Connection. 2016.12.08 18:05:52 - OpenVPN > Index = 20. 2016.12.08 18:05:52 - OpenVPN > GUID = {892AA65F-0FC8-40F3-84D8-7A44584E76EB}. 2016.12.08 18:05:52 - OpenVPN > IP = 192.168.1.154/255.255.255.0. 2016.12.08 18:05:52 - OpenVPN > MAC = 90:2b:34:34:d1:7e. 2016.12.08 18:05:52 - OpenVPN > GATEWAY = 192.168.1.1/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > DHCP SERV = 192.168.1.1/255.255.255.255. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE OBTAINED = Thu Dec 08 17:51:27 2016. 2016.12.08 18:05:52 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 17:51:27 2016. 2016.12.08 18:05:52 - OpenVPN > DNS SERV = 192.168.1.1/255.255.255.255. 2016.12.08 18:05:52 - Starting Management Interface. 2016.12.08 18:05:52 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv )I 2016.12.08 18:05:52 - DNS of a network adapter forced (TAP-Windows Adapter V9)I 2016.12.08 18:05:52 - DNS of a network adapter forced (Intel® 82579V Gigabit Network Connection)I 2016.12.08 18:05:52 - Flushing DNS! 2016.12.08 18:05:52 - Disconnecting. 2016.12.08 18:05:52 - Management - Send 'signal SIGTERM'. 2016.12.08 18:05:52 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2016.12.08 18:05:52 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2016.12.08 18:05:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2016.12.08 18:05:52 - OpenVPN > SIGTERM received, sending exit notification to peer Quote Share this post Link to post
kumquatq3 0 Posted ... Now that I know it's TAP, I'm going to try that pinned reinstall of the driver. Get back to you. Quote Share this post Link to post
kumquatq3 0 Posted ... Uninstalled the driver, reboot, installed the driver. BAM. Working. Thanks LZ1, would never have solved this without you, as I have no idea what TAP is! Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... Once again I stand impressed with the speed of the customer service here The community forums are mostly user-driven and as such don't replace a full-featured customer service. There are users with godlike knowledge, though. And some of them like to help out. as I have no idea what TAP is It's more or less "faking" electronic signals so that your OS thinks it deals with a physical ("existent", where you can plug in something) interface when it actually talks to software. Then you tell your OS to route packets through this software interface and OpenVPN does some encrypting.Now that I think of it, it's like backdooring your network configuration. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
LZ1 679 Posted ... Once again I stand impressed with the speed of the customer service here. Quality! Many thanks my friend. That's it connected now. Cheers!Haha, it's great you think so. But I can't take credit from Air support . They're the real professionals. We're just a helpful community. @ kumquatq3 It's great you checked out the stickied threads haha! Good effort. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
djswitchone 0 Posted ... Once again I stand impressed with the speed of the customer service hereThe community forums are mostly user-driven and as such don't replace a full-featured customer service. There are users with godlike knowledge, though. And some of them like to help out. Haha, it's great you think so. But I can't take credit from Air support . They're the real professionals. We're just a helpful community. My apologies. I just assumed you worked for the airvpn. Credit where credit's due then. Much appreciated for helping networking peons like myself out on your own time. Cheers! Quote Share this post Link to post
