awarrilord 0 Posted ... Hey, Have been using AirVPN regularly for about 4-5 months now. Have been having problems starting today where I cannot connect to any server. When I press connect the client keeps saying 'connecting to whatever server' then it will say 'Flushing DNS' then 'Restarting in 3..2..1' and keeps looping like so. Not sure as to how to proceed. Help would be greatly appreciated. Cheers. Share this post Link to post
LZ1 679 Posted ... Hello! Logs from line 1 please . You can find them in the Eddie client. Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Stillos 0 Posted ... We have same problem, maybe you can have mine? I 2016.12.09 23:47:15 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64 . 2016.12.09 23:47:16 - Reading options from C:\Users\Steel\AppData\Local\AirVPN\AirVPN.xml . 2016.12.09 23:47:16 - Data Path: C:\Users\Steel\AppData\Local\AirVPN . 2016.12.09 23:47:16 - App Path: C:\Program Files\AirVPN . 2016.12.09 23:47:16 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe . 2016.12.09 23:47:16 - Command line arguments (1): path="home" . 2016.12.09 23:47:16 - Operating System: Microsoft Windows NT 6.2.9200.0 . 2016.12.09 23:47:16 - Updating systems & servers data ... I 2016.12.09 23:47:16 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1 I 2016.12.09 23:47:16 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe) I 2016.12.09 23:47:16 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe) I 2016.12.09 23:47:16 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe) ! 2016.12.09 23:47:16 - Ready . 2016.12.09 23:47:16 - Systems & servers data update completed ! 2016.12.09 23:47:26 - Activation of Network Lock - Windows Firewall I 2016.12.09 23:47:29 - Checking login ... ! 2016.12.09 23:47:29 - Logged in. I 2016.12.09 23:47:33 - Session starting. I 2016.12.09 23:47:33 - IPv6 disabled. I 2016.12.09 23:47:33 - Checking authorization ... ! 2016.12.09 23:47:33 - Connecting to Turais (Czech Republic, Prague) . 2016.12.09 23:47:33 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.12.09 23:47:33 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.12.09 23:47:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.12.09 23:47:33 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.12.09 23:47:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:47:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:47:33 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072] . 2016.12.09 23:47:33 - OpenVPN > UDPv4 link local: [undef] . 2016.12.09 23:47:33 - OpenVPN > UDPv4 link remote: [AF_INET]185.156.174.154:443 . 2016.12.09 23:47:33 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.174.154:443, sid=5d021b8d b97bff39 . 2016.12.09 23:47:33 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.12.09 23:47:33 - OpenVPN > Validating certificate key usage . 2016.12.09 23:47:33 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.12.09 23:47:33 - OpenVPN > VERIFY KU OK . 2016.12.09 23:47:33 - OpenVPN > Validating certificate extended key usage . 2016.12.09 23:47:33 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.12.09 23:47:33 - OpenVPN > VERIFY EKU OK . 2016.12.09 23:47:33 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Turais, emailAddress=info@airvpn.org . 2016.12.09 23:47:33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 23:47:33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:47:33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 23:47:33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:47:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.12.09 23:47:33 - OpenVPN > [Turais] Peer Connection Initiated with [AF_INET]185.156.174.154:443 . 2016.12.09 23:47:36 - OpenVPN > SENT CONTROL [Turais]: 'PUSH_REQUEST' (status=1) . 2016.12.09 23:47:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.195 255.255.0.0' . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.12.09 23:47:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.12.09 23:47:36 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.12.09 23:47:36 - OpenVPN > open_tun, tt->ipv6=0 . 2016.12.09 23:47:36 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5242340F-C1B4-4E02-B022-843454586435}.tap . 2016.12.09 23:47:36 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.12.09 23:47:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.195/255.255.0.0 [SUCCEEDED] . 2016.12.09 23:47:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.195/255.255.0.0 on interface {5242340F-C1B4-4E02-B022-843454586435} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.12.09 23:47:36 - OpenVPN > Successful ARP Flush on interface [6] {5242340F-C1B4-4E02-B022-843454586435} . 2016.12.09 23:47:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:41 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:46 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:48 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:49 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:50 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:51 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:52 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:53 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:54 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:55 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:56 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:57 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:47:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:47:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:47:59 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:00 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:01 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:02 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:03 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:05 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:05 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:05 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:06 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:06 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:07 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:07 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:07 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:08 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:08 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:08 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:09 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:09 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:09 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:10 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:10 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:10 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:11 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.156.174.154 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:48:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 23:48:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 23:48:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8 . 2016.12.09 23:48:11 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 23:48:11 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 23:48:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:11 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:11 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.12.09 23:48:11 - OpenVPN > Route addition fallback to route.exe . 2016.12.09 23:48:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:11 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:11 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:11 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.12.09 23:48:11 - OpenVPN > Route addition fallback to route.exe . 2016.12.09 23:48:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:11 - OpenVPN > SYSTEM ROUTING TABLE . 2016.12.09 23:48:11 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=8 t=4 pr=3 a=248 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=36/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=256 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=256 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=256 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=36/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.225.83 p=0 i=6 t=3 pr=2 a=243 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 169.254.225.83 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=243 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=243 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 185.156.174.154 255.255.255.255 192.168.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=8 t=3 pr=2 a=248 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=248 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=248 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=256 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.225.83 p=0 i=6 t=3 pr=2 a=253 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=8 t=3 pr=2 a=253 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=256 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=253 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=253 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:11 - OpenVPN > SYSTEM ADAPTER LIST . 2016.12.09 23:48:11 - OpenVPN > Intel(R) Ethernet Connection (2) I219-V . 2016.12.09 23:48:11 - OpenVPN > Index = 8 . 2016.12.09 23:48:11 - OpenVPN > GUID = {8D4806B1-DF70-4A02-BE66-7F30880B2EB9} . 2016.12.09 23:48:11 - OpenVPN > IP = 192.168.0.101/255.255.255.0 . 2016.12.09 23:48:11 - OpenVPN > MAC = d0:17:c2:d4:93:b4 . 2016.12.09 23:48:11 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:11 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:11 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 09 23:44:03 2016 . 2016.12.09 23:48:11 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 10 21:09:58 2016 . 2016.12.09 23:48:11 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:11 - OpenVPN > TAP-Windows Adapter V9 . 2016.12.09 23:48:11 - OpenVPN > Index = 6 . 2016.12.09 23:48:11 - OpenVPN > GUID = {5242340F-C1B4-4E02-B022-843454586435} . 2016.12.09 23:48:11 - OpenVPN > IP = 169.254.225.83/255.255.0.0 . 2016.12.09 23:48:11 - OpenVPN > MAC = 00:ff:52:42:34:0f . 2016.12.09 23:48:11 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.12.09 23:48:11 - OpenVPN > DHCP SERV = 0.0.0.0/255.255.255.255 . 2016.12.09 23:48:11 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 09 23:48:11 2016 . 2016.12.09 23:48:11 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 23:48:11 2016 . 2016.12.09 23:48:11 - OpenVPN > DNS SERV = . 2016.12.09 23:48:11 - Starting Management Interface . 2016.12.09 23:48:11 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) I 2016.12.09 23:48:11 - DNS of a network adapter forced (Intel(R) Ethernet Connection (2) I219-V) ! 2016.12.09 23:48:11 - Disconnecting . 2016.12.09 23:48:11 - Management - Send 'signal SIGTERM' . 2016.12.09 23:48:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.12.09 23:48:11 - OpenVpn Management > SUCCESS: signal SIGTERM thrown I 2016.12.09 23:48:11 - Flushing DNS . 2016.12.09 23:48:11 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.12.09 23:48:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.12.09 23:48:11 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.12.09 23:48:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.156.174.154 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:48:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 23:48:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:48:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 23:48:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:16 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:16 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.12.09 23:48:16 - OpenVPN > Route deletion fallback to route.exe . 2016.12.09 23:48:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:16 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:16 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.12.09 23:48:16 - OpenVPN > Route deletion fallback to route.exe . 2016.12.09 23:48:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:16 - OpenVPN > Closing TUN/TAP interface . 2016.12.09 23:48:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2016.12.09 23:48:16 - Connection terminated. I 2016.12.09 23:48:16 - DNS of a network adapter restored to original settings (Intel(R) Ethernet Connection (2) I219-V) I 2016.12.09 23:48:19 - Checking authorization ... ! 2016.12.09 23:48:20 - Connecting to Turais (Czech Republic, Prague) . 2016.12.09 23:48:20 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Aug 13 2015 . 2016.12.09 23:48:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08 . 2016.12.09 23:48:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.12.09 23:48:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.12.09 23:48:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:48:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:48:20 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072] . 2016.12.09 23:48:20 - OpenVPN > UDPv4 link local: [undef] . 2016.12.09 23:48:20 - OpenVPN > UDPv4 link remote: [AF_INET]185.156.174.154:443 . 2016.12.09 23:48:20 - OpenVPN > TLS: Initial packet from [AF_INET]185.156.174.154:443, sid=f5dcd500 780a7df4 . 2016.12.09 23:48:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.12.09 23:48:20 - OpenVPN > Validating certificate key usage . 2016.12.09 23:48:20 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.12.09 23:48:20 - OpenVPN > VERIFY KU OK . 2016.12.09 23:48:20 - OpenVPN > Validating certificate extended key usage . 2016.12.09 23:48:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.12.09 23:48:20 - OpenVPN > VERIFY EKU OK . 2016.12.09 23:48:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Turais, emailAddress=info@airvpn.org . 2016.12.09 23:48:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 23:48:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:48:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.12.09 23:48:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.12.09 23:48:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.12.09 23:48:20 - OpenVPN > [Turais] Peer Connection Initiated with [AF_INET]185.156.174.154:443 . 2016.12.09 23:48:22 - OpenVPN > SENT CONTROL [Turais]: 'PUSH_REQUEST' (status=1) . 2016.12.09 23:48:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.0.195 255.255.0.0' . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.12.09 23:48:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.12.09 23:48:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.12.09 23:48:22 - OpenVPN > open_tun, tt->ipv6=0 . 2016.12.09 23:48:22 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{5242340F-C1B4-4E02-B022-843454586435}.tap . 2016.12.09 23:48:22 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.12.09 23:48:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.0.195/255.255.0.0 [SUCCEEDED] . 2016.12.09 23:48:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.0.195/255.255.0.0 on interface {5242340F-C1B4-4E02-B022-843454586435} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.12.09 23:48:22 - OpenVPN > Successful ARP Flush on interface [6] {5242340F-C1B4-4E02-B022-843454586435} . 2016.12.09 23:48:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:27 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:27 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:32 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:34 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:35 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:36 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:37 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:39 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:40 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:41 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:42 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:43 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:44 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:45 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:46 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:47 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:48 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:49 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:50 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:51 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:52 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:53 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:54 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:55 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.12.09 23:48:56 - AirVPN Windows Interface Hack executed (Ethernet 2) . 2016.12.09 23:48:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.12.09 23:48:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 185.156.174.154 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:48:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 23:48:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 23:48:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8 . 2016.12.09 23:48:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2016.12.09 23:48:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.12.09 23:48:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:57 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:57 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.12.09 23:48:57 - OpenVPN > Route addition fallback to route.exe . 2016.12.09 23:48:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:48:57 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:48:57 - OpenVPN > Route addition via IPAPI failed [adaptive] . 2016.12.09 23:48:57 - OpenVPN > Route addition fallback to route.exe . 2016.12.09 23:48:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:48:57 - OpenVPN > SYSTEM ROUTING TABLE . 2016.12.09 23:48:57 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=8 t=4 pr=3 a=294 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 0.0.0.0 128.0.0.0 10.4.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=36/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=301 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=301 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=301 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 128.0.0.0 128.0.0.0 10.4.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=36/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 169.254.0.0 255.255.0.0 169.254.225.83 p=0 i=6 t=3 pr=2 a=289 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 169.254.225.83 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=289 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 169.254.255.255 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=289 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 185.156.174.154 255.255.255.255 192.168.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.101 p=0 i=8 t=3 pr=2 a=294 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 192.168.0.1 255.255.255.255 192.168.0.1 p=0 i=8 t=4 pr=3 a=0 h=0 m=35/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 192.168.0.101 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=294 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=294 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=301 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 224.0.0.0 240.0.0.0 169.254.225.83 p=0 i=6 t=3 pr=2 a=299 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.101 p=0 i=8 t=3 pr=2 a=299 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=301 h=0 m=331/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 255.255.255.255 255.255.255.255 169.254.225.83 p=0 i=6 t=3 pr=2 a=299 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.101 p=0 i=8 t=3 pr=2 a=299 h=0 m=291/0/0/0/0 . 2016.12.09 23:48:57 - OpenVPN > SYSTEM ADAPTER LIST . 2016.12.09 23:48:57 - OpenVPN > Intel(R) Ethernet Connection (2) I219-V . 2016.12.09 23:48:57 - OpenVPN > Index = 8 . 2016.12.09 23:48:57 - OpenVPN > GUID = {8D4806B1-DF70-4A02-BE66-7F30880B2EB9} . 2016.12.09 23:48:57 - OpenVPN > IP = 192.168.0.101/255.255.255.0 . 2016.12.09 23:48:57 - OpenVPN > MAC = d0:17:c2:d4:93:b4 . 2016.12.09 23:48:57 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:57 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:57 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 09 23:48:16 2016 . 2016.12.09 23:48:57 - OpenVPN > DHCP LEASE EXPIRES = Sat Dec 10 21:09:57 2016 . 2016.12.09 23:48:57 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255 . 2016.12.09 23:48:57 - OpenVPN > TAP-Windows Adapter V9 . 2016.12.09 23:48:57 - OpenVPN > Index = 6 . 2016.12.09 23:48:57 - OpenVPN > GUID = {5242340F-C1B4-4E02-B022-843454586435} . 2016.12.09 23:48:57 - OpenVPN > IP = 169.254.225.83/255.255.0.0 . 2016.12.09 23:48:57 - OpenVPN > MAC = 00:ff:52:42:34:0f . 2016.12.09 23:48:57 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.12.09 23:48:57 - OpenVPN > DHCP SERV = 0.0.0.0/255.255.255.255 . 2016.12.09 23:48:57 - OpenVPN > DHCP LEASE OBTAINED = Fri Dec 09 23:48:57 2016 . 2016.12.09 23:48:57 - OpenVPN > DHCP LEASE EXPIRES = Fri Dec 09 23:48:57 2016 . 2016.12.09 23:48:57 - OpenVPN > DNS SERV = . 2016.12.09 23:48:57 - Starting Management Interface . 2016.12.09 23:48:57 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) ! 2016.12.09 23:48:57 - Disconnecting . 2016.12.09 23:48:57 - Management - Send 'signal SIGTERM' . 2016.12.09 23:48:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info I 2016.12.09 23:48:57 - DNS of a network adapter forced (Intel(R) Ethernet Connection (2) I219-V) I 2016.12.09 23:48:57 - Flushing DNS . 2016.12.09 23:48:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.12.09 23:48:57 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.12.09 23:48:57 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.12.09 23:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 185.156.174.154 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:49:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 23:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1 . 2016.12.09 23:49:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.12.09 23:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:49:02 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:49:02 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.12.09 23:49:02 - OpenVPN > Route deletion fallback to route.exe . 2016.12.09 23:49:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:49:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.12.09 23:49:02 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.12.09 23:49:02 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.12.09 23:49:02 - OpenVPN > Route deletion fallback to route.exe . 2016.12.09 23:49:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.12.09 23:49:02 - OpenVPN > Closing TUN/TAP interface . 2016.12.09 23:49:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2016.12.09 23:49:02 - Connection terminated. I 2016.12.09 23:49:02 - DNS of a network adapter restored to original settings (Intel(R) Ethernet Connection (2) I219-V) I 2016.12.09 23:49:02 - Cancel requested. I 2016.12.09 23:49:02 - IPv6 restored. ! 2016.12.09 23:49:02 - Session terminated. ! 2016.12.09 23:49:27 - Deactivation of Network Lock Share this post Link to post
LZ1 679 Posted ... Try set your TAP networking adapters media status to always connected. Sent to you from me with datalove Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
........... 0 Posted ... Started having the same issue last few days - using USA servers (Persei for example). Running latest beta. Can the wise ones answer a few questions about some items that have been mentioned previously 1. What is WFP in settings that some say to disable2. What effect does setting media status for the TAP to Always connected versus Application Controlled (also offered as a solution)3. I don't use network lock (not necessary for my setup), is it still wise to set Network lock mode to Windows Firewall, even though I have network lock on startup disabled. Read a huge number of threads but not seeing any obvious solutions other to experiment. I moved to beta at the suggestion of users on here. Share this post Link to post
Tech Jedi Alex 1531 Posted ... What is WFP in settings that some say to disable Windows Filtering Platform. What effect does setting media status for the TAP to Always connected versus Application Controlled From the OpenVPN documentation: An option has been added to the TAP-Windows driver advanced properties page that allows you to control whether the adapter appears to Windows as "Always Connected" or whether the connection status is dynamically brought up and down by OpenVPN ("Application Controlled"). So you're basically eliminating one task of OpenVPN - telling Windows that "a cable has been plugged into the TAP interface". I don't use network lock (not necessary for my setup), is it still wise to set Network lock mode to Windows Firewall, even though I have network lock on startup disabled. If you don't use Network Lock, editing its settings is superfluous. 1 ........... reacted to this Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
awarrilord 0 Posted ... Fixed my problem resetting my TCP/IP. Run command prompt as an admin. Enter 'netsh winsock reset' Then enter 'netsh int ip reset' Restart computer. Share this post Link to post
