ryanturner100 0 Posted ... Hi, http://puu.sh/sGdus/d3998886fb.png Above is a screenshot of the logs, as per this thread https://airvpn.org/topic/16496-cannot-find-tunnel-adapter-any-help-greatfully-appreciated/ I tried installing the TAP Virtual Ethernet Adapter through open VPN but I am still getting the same error message, im not particularly computer literate so any help is welcomed. Thanks Quote Share this post Link to post
greenclaydog 6 Posted ... Hi, http://puu.sh/sGdus/d3998886fb.png Above is a screenshot of the logs, as per this thread https://airvpn.org/topic/16496-cannot-find-tunnel-adapter-any-help-greatfully-appreciated/ I tried installing the TAP Virtual Ethernet Adapter through open VPN but I am still getting the same error message, im not particularly computer literate so any help is welcomed. Thanks Try using the experimental client, i believe it has a new TAP driver. If that fails i would suggest submitting a support ticket. Quote Share this post Link to post
Khariz 109 Posted ... It's highly odd that Eddit cannot find either your OpenVPN or TAP drivers. I'd try running Eddie as an administrator. Go into the folder where Eddie is installed, right click on the executable and "run as administrator". Where do you have Eddie installed? Is it in the standard installation path, or did you put it somewhere else? Quote Share this post Link to post
ryanturner100 0 Posted ... I have tried running the client as an administrator as well as running the installation as an administrator and it made no difference, the installation path is standard, can someone just give me a really quick rundown on the initial installation steps because it feels like I must have missed something out as all the recommended troubleshooting hasn't worked from other forum threads so maybe I've done something more significantly wrong? Thanks. Quote Share this post Link to post
ryanturner100 0 Posted ... So i just completely started over after restarting my computer and without seemingly doing anything different than the first time around it seems to be working. Thanks guys Quote Share this post Link to post
LZ1 679 Posted ... Hello! Sometimes that can be fixed if you restart the Eddie client completely. It can't always find the tunnel driver on the first install, I've experienced. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
