nouk2016
Network becomes periodically unusable.
Hi guys,
Using Eddie 2.10.3 on Windows 10.
I use this in Network Lock mode. However, I've noticed that from time to time, when surfing I become unable to connect. Eddie shows minimal traffic during these periods, of the order of bytes only. If I'm prepared to wait, sometimes the issue resolves itself in about a minute.
If I then try disconnecting and reconnecting, regardless of whether I'm using Network Lock mode or not, I cannot reconnect to an AirVPN server. It gets halted at the 'Checking Route' phase and after 5 failed attempts, the cycle repeats.
When it works, I have good speed.
Any ideas?
thanks
It's always best if you supply your logs. From line 1, in spoilers.
But you can go to the Eddie preferences and experiment with turning off one or both of tunnel and DNS route checking.
It happened again.
I 2016.12.09 15:27:12 - DNS of a network adapter restored to original settings (Dell Wireless 1820A 802.11ac)
I 2016.12.09 15:27:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.09 15:27:18 - Checking authorization ...
! 2016.12.09 15:27:18 - Connecting to Talitha (Netherlands, Alblasserdam)
. 2016.12.09 15:27:18 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.09 15:27:18 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.09 15:27:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.09 15:27:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.09 15:27:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 15:27:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 15:27:19 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.09 15:27:19 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.09 15:27:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.137:443
. 2016.12.09 15:27:19 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.137:443, sid=f0db4608 f13ec628
. 2016.12.09 15:27:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.09 15:27:19 - OpenVPN > Validating certificate key usage
. 2016.12.09 15:27:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.12.09 15:27:19 - OpenVPN > VERIFY KU OK
. 2016.12.09 15:27:19 - OpenVPN > Validating certificate extended key usage
. 2016.12.09 15:27:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.09 15:27:19 - OpenVPN > VERIFY EKU OK
. 2016.12.09 15:27:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.09 15:27:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 15:27:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 15:27:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 15:27:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 15:27:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.09 15:27:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.137:443
. 2016.12.09 15:27:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.09 15:27:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.155 255.255.0.0'
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.09 15:27:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.09 15:27:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.09 15:27:28 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.09 15:27:28 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}.tap
. 2016.12.09 15:27:28 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.09 15:27:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.155/255.255.0.0 [sUCCEEDED]
. 2016.12.09 15:27:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.155/255.255.0.0 on interface {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.09 15:27:28 - OpenVPN > Successful ARP Flush on interface [15] {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}
. 2016.12.09 15:27:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.12.09 15:27:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.137 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 15:27:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4
. 2016.12.09 15:27:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.09 15:27:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8
. 2016.12.09 15:27:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 15:27:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.12.09 15:27:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 15:27:33 - Starting Management Interface
. 2016.12.09 15:27:33 - OpenVPN > Initialization Sequence Completed
I 2016.12.09 15:27:33 - DNS of a network adapter forced (Dell Wireless 1820A 802.11ac)
I 2016.12.09 15:27:33 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.09 15:27:33 - Flushing DNS
I 2016.12.09 15:27:33 - Checking route
I 2016.12.09 15:27:33 - Checking DNS
. 2016.12.09 15:27:40 - Updating systems & servers data ...
. 2016.12.09 15:27:41 - Systems & servers data update completed
! 2016.12.09 15:27:46 - Connected.
. 2016.12.09 15:27:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.09 15:27:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.12.09 15:57:52 - Updating systems & servers data ...
. 2016.12.09 15:58:02 - Updating systems & servers data ..., 1° try failed (The operation has timed out)
. 2016.12.09 15:58:12 - Updating systems & servers data ..., 2° try failed (The operation has timed out)
. 2016.12.09 15:58:22 - Updating systems & servers data ..., 3° try failed (The operation has timed out)
. 2016.12.09 15:58:32 - Updating systems & servers data ..., 4° try failed (The operation has timed out)
. 2016.12.09 15:58:32 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (The operation has timed out)
! 2016.12.09 15:59:21 - Disconnecting
. 2016.12.09 15:59:21 - Management - Send 'signal SIGTERM'
. 2016.12.09 15:59:21 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.09 15:59:21 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.09 15:59:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.137 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 15:59:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.09 15:59:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 15:59:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 15:59:26 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 15:59:26 - OpenVPN > Closing TUN/TAP interface
. 2016.12.09 15:59:26 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.09 15:59:26 - Connection terminated.
I 2016.12.09 15:59:26 - DNS of a network adapter restored to original settings (Dell Wireless 1820A 802.11ac)
I 2016.12.09 15:59:26 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.09 15:59:26 - IPv6 restored.
! 2016.12.09 15:59:26 - Session terminated.
I 2016.12.09 15:59:32 - Session starting.
I 2016.12.09 15:59:32 - IPv6 disabled.
I 2016.12.09 15:59:33 - Checking authorization ...
. 2016.12.09 15:59:43 - Checking authorization ..., 1° try failed (The operation has timed out)
. 2016.12.09 15:59:53 - Checking authorization ..., 2° try failed (The operation has timed out)
. 2016.12.09 16:00:03 - Checking authorization ..., 3° try failed (The operation has timed out)
. 2016.12.09 16:00:13 - Checking authorization ..., 4° try failed (The operation has timed out)
W 2016.12.09 16:00:13 - Authorization check failed, continue anyway ({1])
! 2016.12.09 16:00:13 - Connecting to Skat (Netherlands, Alblasserdam)
. 2016.12.09 16:00:13 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.09 16:00:13 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.09 16:00:13 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.09 16:00:13 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.09 16:00:13 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:00:13 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:00:13 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.09 16:00:13 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.09 16:00:13 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.73:443
. 2016.12.09 16:00:13 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.73:443, sid=36f55322 2c524999
. 2016.12.09 16:00:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.09 16:00:14 - OpenVPN > Validating certificate key usage
. 2016.12.09 16:00:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.12.09 16:00:14 - OpenVPN > VERIFY KU OK
. 2016.12.09 16:00:14 - OpenVPN > Validating certificate extended key usage
. 2016.12.09 16:00:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.09 16:00:14 - OpenVPN > VERIFY EKU OK
. 2016.12.09 16:00:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.09 16:00:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 16:00:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:00:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 16:00:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:00:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.09 16:00:17 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.73:443
. 2016.12.09 16:00:19 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.09 16:00:19 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.93.108 255.255.0.0'
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.09 16:00:19 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.09 16:00:19 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.09 16:00:19 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.09 16:00:19 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}.tap
. 2016.12.09 16:00:19 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.09 16:00:19 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.93.108/255.255.0.0 [sUCCEEDED]
. 2016.12.09 16:00:19 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.93.108/255.255.0.0 on interface {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.09 16:00:19 - OpenVPN > Successful ARP Flush on interface [15] {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}
. 2016.12.09 16:00:24 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.12.09 16:00:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.73 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 16:00:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4
. 2016.12.09 16:00:24 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.09 16:00:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8
. 2016.12.09 16:00:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:00:24 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.12.09 16:00:24 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:00:24 - Starting Management Interface
. 2016.12.09 16:00:24 - OpenVPN > Initialization Sequence Completed
I 2016.12.09 16:00:24 - DNS of a network adapter forced (Dell Wireless 1820A 802.11ac)
I 2016.12.09 16:00:24 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.09 16:00:24 - Flushing DNS
I 2016.12.09 16:00:24 - Checking route
W 2016.12.09 16:04:19 - Checking route, 1° try failed (The operation has timed out)
W 2016.12.09 16:04:31 - Checking route, 2° try failed (The operation has timed out)
I 2016.12.09 16:04:33 - Checking DNS
! 2016.12.09 16:04:34 - Connected.
. 2016.12.09 16:04:34 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.12.09 16:04:34 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
! 2016.12.09 16:04:34 - Disconnecting
. 2016.12.09 16:04:34 - Management - Send 'signal SIGTERM'
. 2016.12.09 16:04:34 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.12.09 16:04:34 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.12.09 16:04:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.73 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 16:04:39 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.12.09 16:04:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 16:04:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:04:39 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:04:39 - OpenVPN > Closing TUN/TAP interface
. 2016.12.09 16:04:39 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.12.09 16:04:39 - Connection terminated.
I 2016.12.09 16:04:39 - DNS of a network adapter restored to original settings (Dell Wireless 1820A 802.11ac)
I 2016.12.09 16:04:39 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.12.09 16:04:39 - IPv6 restored.
! 2016.12.09 16:04:39 - Session terminated.
I 2016.12.09 16:04:56 - Session starting.
I 2016.12.09 16:04:56 - IPv6 disabled.
I 2016.12.09 16:04:56 - Checking authorization ...
! 2016.12.09 16:04:56 - Connecting to Diphda (Netherlands, Alblasserdam)
. 2016.12.09 16:04:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.12.09 16:04:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.12.09 16:04:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.12.09 16:04:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.12.09 16:04:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:04:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:04:57 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.12.09 16:04:57 - OpenVPN > UDPv4 link local: [undef]
. 2016.12.09 16:04:57 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.164:443
. 2016.12.09 16:04:57 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.164:443, sid=62ee31dc 3780c923
. 2016.12.09 16:04:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.12.09 16:04:57 - OpenVPN > Validating certificate key usage
. 2016.12.09 16:04:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.12.09 16:04:57 - OpenVPN > VERIFY KU OK
. 2016.12.09 16:04:57 - OpenVPN > Validating certificate extended key usage
. 2016.12.09 16:04:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.12.09 16:04:57 - OpenVPN > VERIFY EKU OK
. 2016.12.09 16:04:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.12.09 16:04:59 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 16:04:59 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:04:59 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.12.09 16:04:59 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.12.09 16:04:59 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.12.09 16:04:59 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.164:443
. 2016.12.09 16:05:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.12.09 16:05:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.92.3 255.255.0.0'
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.12.09 16:05:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.12.09 16:05:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.12.09 16:05:02 - OpenVPN > open_tun, tt->ipv6=0
. 2016.12.09 16:05:02 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}.tap
. 2016.12.09 16:05:02 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.12.09 16:05:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.92.3/255.255.0.0 [sUCCEEDED]
. 2016.12.09 16:05:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.92.3/255.255.0.0 on interface {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.12.09 16:05:02 - OpenVPN > Successful ARP Flush on interface [15] {B7603D0E-2B56-42D1-B5B5-EC9CC037FE9E}
. 2016.12.09 16:05:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.12.09 16:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.164 MASK 255.255.255.255 192.168.0.1
. 2016.12.09 16:05:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=45 and dwForwardType=4
. 2016.12.09 16:05:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.12.09 16:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8
. 2016.12.09 16:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:05:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.12.09 16:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.12.09 16:05:07 - Starting Management Interface
. 2016.12.09 16:05:07 - OpenVPN > Initialization Sequence Completed
I 2016.12.09 16:05:07 - DNS of a network adapter forced (Dell Wireless 1820A 802.11ac)
I 2016.12.09 16:05:07 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.12.09 16:05:08 - Flushing DNS
I 2016.12.09 16:05:08 - Checking route
I 2016.12.09 16:05:09 - Checking DNS
! 2016.12.09 16:05:21 - Connected.
. 2016.12.09 16:05:21 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.12.09 16:05:21 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
The log starts at when I opened up my laptop from hibernation.
At 15:50 the network went dead spontaneously. After waiting for a while for the network to recover, I disconnected at 15:57 and then tried to reconnect, to Skat. This stalled at the checking route stage. I cancelled the connection attempt (contrary to what the log says, Eddie never showed a connected state at 16:04) and tried again. This time I got through to Diphda.
In the meantime I will try turning off tunnel and/or DNS route checking. Please could you tell me where these are exactly in preferences as I can't find them.
many thanks
Did you turn off both tunnel and DNS route check? Did you try different protocols and then reconnect?
With Eddie 2.10, make sure to turn it off via its own menus before you close your computer.
You could also try the experimental version .
