I have generated configurations using UDP 443, but all of these fail to allow browsing (but connects to Air) when imported directly into network manager. I can browse if I tick the "Use a TCP connection" in Advanced Options. I have searched, but am unable to find any posts with the same issue. Can anyone explain oe give insight as to why I am unable to use the UDP protocol?
I suppose you're on Linux? Are you not wanting to use the Eddie client or what? I'm not sure if the Network Manager is the best choice.
Yes, I am indeed on Linux, and have the Eddie Client installed. I like to randomize several specific servers, so I use the .ovpn file with NM ​to do that. Not sure how to configure Eddie properly to do that. I'm wondering if TCP 53 is required to get UDP connections to allow browsing. I could experiment to find out, but am hesitant to change unless I find I need to.
