Dragomar
"What is my IP" sites showing actual IP?
So, I've been using air VPN ("Premium" or whatever, $60/yr which is amazing btw)
Very satisfied so far.
However, when I go to various "what is my ip" sites such as https://www.whatismyip.com/
they display either - my real ISP's headquarters (assuming AT&Ts headquarters/servers/etc are in Richardson, TX)
or my actual IP address and location.
Is this something to worry about? After a while (5-10 minutes) on a VPN server they all display the correct proxied information. (with the exception of the site linked above, that one still shows Richardson, TX) Should I wait 5-10 minutes before I use the VPN after connecting to be completely safe or...?
In addition to what zhang said, you can also enable Network Lock, if you're using the Eddie client.
Whenever you buy an Air subscription, you become a "Premium" user .
