What is going to happen when Comcast continues to update and upgrade their infrastructure. The speeds and bandwidth allocations are growing up yet the VPN's are not updating.
TL;DR
With the faster speeds are VPN's going to continue to mask my activity?
I don't see the connection between faster speeds and the possibility that VPNs might not continue to mask you - could you elaborate? AirVPN already has quality hardware and solid speeds on its own.
I'm worried about sniffers from the internet provider, with increased speeds from fiber optic the provider could possibly sneak sniffers through packets and vpns might not detect it because it might be overloaded from the increased speeds from the fiber optic
I've never heard of that concept before. Do you have a link to this actually happening? Your connection is encrypted and as long as you're not leaking things like your DNS, which you can ensure by using Network Lock especially, then there should be little to worry about in that regard.
