I keep getting "the remote name could not be resolved". I just paid for a 3 day trial and have not connected to 1 server after trying for 45+ minutes... here is my log, I don't know where else to go from here.
My Tap adapter has a red 'X' next to it when Air vpn times out, then goes back to normal
I 2016.11.03 23:22:17 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.11.03 23:22:17 - Reading options from C:\Users\Liam\AppData\Local\AirVPN\AirVPN.xml
. 2016.11.03 23:22:17 - Data Path: C:\Users\Liam\AppData\Local\AirVPN
. 2016.11.03 23:22:17 - App Path: C:\Program Files\AirVPN
. 2016.11.03 23:22:17 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.11.03 23:22:17 - Command line arguments (1): path="home"
. 2016.11.03 23:22:17 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.11.03 23:22:17 - Updating systems & servers data ...
I 2016.11.03 23:22:17 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2016.11.03 23:22:17 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.11.03 23:22:17 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.11.03 23:22:17 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.11.03 23:22:17 - Ready
. 2016.11.03 23:22:18 - Systems & servers data update completed
I 2016.11.03 23:22:19 - Session starting.
F 2016.11.03 23:22:19 - OpenVPN is already running.
I 2016.11.03 23:22:50 - Session starting.
I 2016.11.03 23:22:50 - IPv6 disabled.
I 2016.11.03 23:22:51 - Checking authorization ...
! 2016.11.03 23:22:51 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:22:51 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:22:51 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:22:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:22:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:22:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:22:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:22:51 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:22:51 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:22:51 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:22:51 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=4cb1c3bc 963547c8
. 2016.11.03 23:22:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:22:51 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:22:51 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:22:51 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:22:51 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:22:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:22:51 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:22:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:22:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:22:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:22:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:22:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:22:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:22:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:22:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:22:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:22:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:22:55 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:22:55 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:22:55 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:22:55 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:22:55 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:22:55 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:22:55 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:23:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:23:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:23:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:23:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:23:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:23:00 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=18]
. 2016.11.03 23:23:00 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.11.03 23:23:00 - OpenVPN > Route addition fallback to route.exe
. 2016.11.03 23:23:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.11.03 23:23:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:00 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=8]
. 2016.11.03 23:23:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:00 - Starting Management Interface
. 2016.11.03 23:23:00 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:23:00 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:23:00 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:23:00 - Flushing DNS
I 2016.11.03 23:23:00 - Checking route
W 2016.11.03 23:23:24 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:23:24 - Disconnecting
. 2016.11.03 23:23:24 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:23:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:23:24 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:23:24 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:23:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:23:29 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:23:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:23:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:29 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:29 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:23:29 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:23:29 - Connection terminated.
I 2016.11.03 23:23:29 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:23:29 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
E 2016.11.03 23:23:32 - Unknown command
I 2016.11.03 23:23:33 - Checking authorization ...
! 2016.11.03 23:23:33 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:23:33 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:23:33 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:23:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:23:33 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:23:33 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:23:33 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:23:33 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:23:33 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:23:33 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:23:33 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=52e34986 abff91e5
. 2016.11.03 23:23:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:23:36 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:23:36 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:23:36 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:23:36 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:23:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:23:36 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:23:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:23:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:23:39 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:23:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:23:39 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:23:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:23:39 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:23:41 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:23:41 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:23:41 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:23:41 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:23:41 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:23:41 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:23:41 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:23:41 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:23:41 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:23:41 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:23:46 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:23:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:23:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:23:46 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:23:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:23:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:46 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:23:46 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:23:46 - Starting Management Interface
. 2016.11.03 23:23:46 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:23:46 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:23:46 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:23:46 - Flushing DNS
I 2016.11.03 23:23:47 - Checking route
W 2016.11.03 23:24:11 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:24:11 - Disconnecting
. 2016.11.03 23:24:11 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:24:11 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:24:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:24:11 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:24:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:16 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:24:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:16 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:16 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:24:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:24:16 - Connection terminated.
I 2016.11.03 23:24:16 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:24:16 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:24:19 - Checking authorization ...
! 2016.11.03 23:24:20 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:24:20 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:24:20 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:24:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:24:20 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:24:20 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:20 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:20 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:24:20 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:24:20 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:24:20 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=c25c082a fa5c93fc
. 2016.11.03 23:24:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:24:20 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:24:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:24:20 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:24:20 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:24:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:24:20 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:24:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:24:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:24:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:24:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:20 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:24:20 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:24:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:24:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:24:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:24:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:24:22 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:24:22 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:24:22 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:24:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:24:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:24:22 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:24:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:24:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:24:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:24:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:24:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:24:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:27 - Starting Management Interface
. 2016.11.03 23:24:27 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:24:27 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:24:27 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:24:27 - Flushing DNS
I 2016.11.03 23:24:27 - Checking route
W 2016.11.03 23:24:39 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:24:39 - Disconnecting
. 2016.11.03 23:24:39 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:24:39 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:24:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:24:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:24:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:24:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:44 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:24:44 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:24:44 - Connection terminated.
I 2016.11.03 23:24:44 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:24:44 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:24:47 - Checking authorization ...
! 2016.11.03 23:24:47 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:24:47 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:24:47 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:24:47 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:24:47 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:24:47 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:47 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:47 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:24:47 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:24:47 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:24:47 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=818b4644 062bab0c
. 2016.11.03 23:24:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:24:47 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:24:47 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:24:47 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:24:47 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:24:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:24:47 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:24:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:24:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:24:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:24:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:24:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:24:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:24:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:24:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:24:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:24:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:24:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:24:50 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:24:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:24:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:24:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:24:50 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:24:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:24:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:24:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:24:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:24:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:24:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:24:55 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:24:55 - Starting Management Interface
. 2016.11.03 23:24:55 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:24:55 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:24:55 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:24:55 - Flushing DNS
I 2016.11.03 23:24:55 - Checking route
W 2016.11.03 23:25:07 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:25:07 - Disconnecting
. 2016.11.03 23:25:07 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:25:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:25:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:25:07 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:25:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:25:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:25:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:25:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:12 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:25:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:25:12 - Connection terminated.
I 2016.11.03 23:25:12 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:25:12 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:25:15 - Checking authorization ...
! 2016.11.03 23:25:15 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:25:15 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:25:15 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:25:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:25:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:25:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:25:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:25:15 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:25:15 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:25:15 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:25:15 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=f5158855 1f182493
. 2016.11.03 23:25:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:25:16 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:25:16 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:25:16 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:25:16 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:25:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:25:16 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:25:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:25:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:25:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:25:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:25:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:25:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:25:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:25:22 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:25:22 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:25:22 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:25:22 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:25:22 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:25:22 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:25:22 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:25:22 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:25:22 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:25:22 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:25:27 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:25:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:25:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:25:27 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:25:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:25:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:27 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:25:27 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:27 - Starting Management Interface
. 2016.11.03 23:25:27 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:25:27 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:25:27 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:25:27 - Flushing DNS
I 2016.11.03 23:25:27 - Checking route
W 2016.11.03 23:25:51 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:25:51 - Disconnecting
. 2016.11.03 23:25:51 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:25:51 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:25:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:25:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:25:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:25:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:25:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:25:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:56 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:25:56 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:25:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:25:56 - Connection terminated.
I 2016.11.03 23:25:56 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:25:56 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:25:59 - Checking authorization ...
! 2016.11.03 23:25:59 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:25:59 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:25:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:25:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:26:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:26:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:00 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:26:00 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:26:00 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:26:00 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=e4d164ea 516fc449
. 2016.11.03 23:26:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:26:00 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:26:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:26:00 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:26:00 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:26:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:26:00 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:26:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:26:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:26:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:26:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:26:00 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:26:02 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:26:02 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:26:02 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:26:02 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:26:02 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:26:02 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:26:02 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:26:02 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:26:02 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:26:02 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:26:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:26:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:26:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:26:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:26:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:26:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:26:07 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:07 - Starting Management Interface
. 2016.11.03 23:26:07 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:26:07 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:26:07 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:26:07 - Flushing DNS
I 2016.11.03 23:26:07 - Checking route
W 2016.11.03 23:26:19 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:26:19 - Disconnecting
. 2016.11.03 23:26:19 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:26:19 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:26:19 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:26:19 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:26:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:26:24 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:26:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:26:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:24 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:24 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:26:24 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:26:24 - Connection terminated.
I 2016.11.03 23:26:24 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:26:24 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:26:27 - Checking authorization ...
! 2016.11.03 23:26:28 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:26:28 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:26:28 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:26:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:26:28 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:26:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:28 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:26:28 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:26:28 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:26:28 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=fad8c385 c201983e
. 2016.11.03 23:26:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:26:31 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:26:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:26:31 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:26:31 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:26:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:26:31 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:26:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:26:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:26:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:26:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:26:36 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:26:36 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:26:38 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:26:38 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:26:38 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:26:38 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:26:38 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:26:38 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:26:38 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:26:38 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:26:38 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:26:38 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:26:43 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:26:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:26:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:26:43 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:26:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:26:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:43 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:26:43 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:26:43 - Starting Management Interface
. 2016.11.03 23:26:43 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:26:43 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:26:43 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:26:43 - Flushing DNS
I 2016.11.03 23:26:43 - Checking route
W 2016.11.03 23:27:07 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:27:07 - Disconnecting
. 2016.11.03 23:27:07 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:27:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:27:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:27:07 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:27:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:27:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:27:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:27:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:12 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:27:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:27:12 - Connection terminated.
I 2016.11.03 23:27:12 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:27:12 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:27:15 - Checking authorization ...
! 2016.11.03 23:27:15 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:27:15 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:27:15 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:27:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:27:15 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:27:15 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:15 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:15 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:27:15 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:27:15 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:27:15 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=1c51d2ec e51921d4
. 2016.11.03 23:27:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:27:15 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:27:15 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:27:15 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:27:15 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:27:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:27:15 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:27:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:27:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:27:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:27:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:27:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:27:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:27:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:27:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:27:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:27:20 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:27:20 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:27:20 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:27:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:27:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:27:20 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:27:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:27:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:27:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:27:25 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:27:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:27:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:25 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:27:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:25 - Starting Management Interface
. 2016.11.03 23:27:25 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:27:25 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:27:25 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:27:25 - Flushing DNS
I 2016.11.03 23:27:26 - Checking route
W 2016.11.03 23:27:50 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:27:50 - Disconnecting
. 2016.11.03 23:27:50 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:27:50 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:27:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:27:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:27:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:27:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:27:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:27:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:27:55 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:27:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:27:55 - Connection terminated.
I 2016.11.03 23:27:55 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:27:55 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:27:58 - Checking authorization ...
! 2016.11.03 23:27:59 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:27:59 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:27:59 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:27:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:27:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:27:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:27:59 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:27:59 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:27:59 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:00 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=ae559e42 79cd54c1
. 2016.11.03 23:28:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:28:03 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:28:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:28:03 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:28:03 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:28:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:28:03 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:28:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:28:05 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:05 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:05 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:05 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:05 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:28:05 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:28:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:28:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:28:07 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:28:07 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:28:08 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:28:08 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:28:08 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:28:08 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:28:08 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:28:13 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.11.03 23:28:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:28:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.11.03 23:28:13 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.11.03 23:28:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.2.1 MASK 255.255.255.255 192.168.2.1 IF 18
. 2016.11.03 23:28:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:28:13 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.11.03 23:28:13 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:28:13 - Starting Management Interface
. 2016.11.03 23:28:13 - OpenVPN > Initialization Sequence Completed
I 2016.11.03 23:28:13 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.11.03 23:28:13 - DNS of a network adapter forced (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:28:13 - Flushing DNS
I 2016.11.03 23:28:13 - Checking route
W 2016.11.03 23:28:37 - The remote name could not be resolved: 'avior_exit.airservers.org'
! 2016.11.03 23:28:37 - Disconnecting
. 2016.11.03 23:28:37 - Management - Send 'signal SIGTERM'
. 2016.11.03 23:28:37 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.11.03 23:28:37 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.11.03 23:28:37 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2016.11.03 23:28:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 184.75.223.234 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:28:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.11.03 23:28:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 192.168.2.1 MASK 255.255.255.255 192.168.2.1
. 2016.11.03 23:28:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:28:42 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.11.03 23:28:42 - OpenVPN > Closing TUN/TAP interface
. 2016.11.03 23:28:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2016.11.03 23:28:42 - Connection terminated.
I 2016.11.03 23:28:42 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.11.03 23:28:42 - DNS of a network adapter restored to original settings (Intel® Ethernet Connection (2) I218-V)
I 2016.11.03 23:28:45 - Checking authorization ...
! 2016.11.03 23:28:46 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:28:46 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:28:46 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:28:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:28:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:28:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:46 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:28:46 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:28:46 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:46 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=796e89e0 bfd8609c
. 2016.11.03 23:28:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:28:46 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:28:46 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:28:46 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:28:46 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:28:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:28:46 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:28:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:28:48 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:48 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:48 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:48 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:48 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:28:48 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:50 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:28:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:28:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:28:50 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:28:50 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:28:50 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:28:50 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.11.03 23:28:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.61.225/255.255.0.0 [sUCCEEDED]
. 2016.11.03 23:28:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.61.225/255.255.0.0 on interface {8A120592-FC45-4CCB-B86E-70C849C87B04} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.11.03 23:28:50 - OpenVPN > Successful ARP Flush on interface [8] {8A120592-FC45-4CCB-B86E-70C849C87B04}
. 2016.11.03 23:28:53 - OpenVPN > TUN/TAP I/O operation aborted, exiting
. 2016.11.03 23:28:53 - OpenVPN > Exiting due to fatal error
. 2016.11.03 23:28:53 - OpenVPN > Closing TUN/TAP interface
! 2016.11.03 23:28:53 - Disconnecting
. 2016.11.03 23:28:53 - Connection terminated.
I 2016.11.03 23:28:56 - Checking authorization ...
! 2016.11.03 23:28:57 - Connecting to Avior (Canada, Toronto, Ontario)
. 2016.11.03 23:28:57 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.11.03 23:28:57 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.11.03 23:28:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.11.03 23:28:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.11.03 23:28:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:57 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.11.03 23:28:57 - OpenVPN > UDPv4 link local: [undef]
. 2016.11.03 23:28:57 - OpenVPN > UDPv4 link remote: [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:57 - OpenVPN > TLS: Initial packet from [AF_INET]184.75.223.234:443, sid=d34b5a02 292f630d
. 2016.11.03 23:28:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.11.03 23:28:57 - OpenVPN > Validating certificate key usage
. 2016.11.03 23:28:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.11.03 23:28:57 - OpenVPN > VERIFY KU OK
. 2016.11.03 23:28:57 - OpenVPN > Validating certificate extended key usage
. 2016.11.03 23:28:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.11.03 23:28:57 - OpenVPN > VERIFY EKU OK
. 2016.11.03 23:28:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.11.03 23:28:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.11.03 23:28:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.11.03 23:28:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.11.03 23:28:57 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]184.75.223.234:443
. 2016.11.03 23:28:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.11.03 23:28:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.61.225 255.255.0.0'
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.11.03 23:28:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.11.03 23:28:59 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.11.03 23:28:59 - OpenVPN > open_tun, tt->ipv6=0
. 2016.11.03 23:28:59 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{8A120592-FC45-4CCB-B86E-70C849C87B04}.tap
. 2016.11.03 23:28:59 - OpenVPN > All TAP-Windows adapters on this system are currently in use.
. 2016.11.03 23:28:59 - OpenVPN > Exiting due to fatal error
! 2016.11.03 23:28:59 - Disconnecting
. 2016.11.03 23:28:59 - Connection terminated.
Welcome to AirVPN !
You can try:
Turning off IPv6 in your system.
Upgrading to the experimental/beta Eddie client.
Trying different servers and/or protocols.
Restarting the TAP driver: Control Panel>Network & Internet>Network Connections>Disable and then re-enable the TAP driver. Sometimes works.
Then make sure no firewall/anti-virus software might be blocking AirVPN.exe or OpenVPN.exe. The Beta Client handles such 3rd party security software better.
For instruction, my signature is at your service.
