onetwofree 0 Posted ... is AirVPN compatible with IKEv2 standard to setup on a supervised iphone for an always on VPN ? as per guide shown there: http://www.howtogeek.com/218851/how-to-enable-always-on-vpn-on-an-iphone-or-ipad/ cheers Quote Share this post Link to post
Tech Jedi Alex 1499 Posted ... Only OpenVPN is supported.I know that Always-On is possible on Android, don't know about iOS, though. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Staff 10331 Posted ... Only OpenVPN is supported.I know that Always-On is possible on Android, don't know about iOS, though. Yes, the "Seamless tunnel" option was lately implemented in "openvpn-connect" for iOS application. Kind regards Quote Share this post Link to post
onetwofree 0 Posted ... Only OpenVPN is supported.I know that Always-On is possible on Android, don't know about iOS, though.Yes, the "Seamless tunnel" option was lately implemented in "openvpn-connect" for iOS application. Kind regardsWhat do you mean by seamless tunnel ? Tried to open the OpenVPN app but could not find any option for it. Does seamless tunnel enable always ON ?thank you Quote Share this post Link to post
zhang888 1067 Posted ... https://docs.openvpn.net/docs/openvpn-connect/openvpn-connect-ios-faq.html Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
onetwofree 0 Posted ... That's great; thank you for the link however I already had seamless enabled and reconnect on startup but it does not seam to work... Any idea ? Quote Share this post Link to post
Keksjdjdke 35 Posted ... That's great; thank you for the link however I already had seamless enabled and reconnect on startup but it does not seam to work... Any idea ? See if this helps https://www.derman.com/blogs/iOS-OpenVPN-OnDemand-Setup Quote Share this post Link to post
uselpa 0 Posted ... HelloI'm having the same question... I recently put my iPhone into supervised mode and would like to configure a VPN workload in Apple Configurator 2.Can't seem to be able to attach a screenshot of the fields which appear to be required. Quote Share this post Link to post
Khariz 109 Posted ... Seeing as how you can't user AirVPN with IPsec or IKEv2 protocols with iOS natively, you won't be able to get on demand functionality anyway. You'll have to use a VPN provider that has servers that talk over those protocols. Quote Share this post Link to post
