I don't think that's in the cards at the moment. But there's nothing stopping you from using Tor or Network Lock right now.
Can you tell me how i can do it?
For network lock you just download the Eddie client and click to enable it.
For Tor you download the Tor browser bundle typically, start the browser and then go into the Eddie preferences>protocols and enable Tor. Then you click the test button, to make sure it works.
Tor>VPN and Network Lock are 2 quite self-refuting ideas.
Network Lock ensures that you are connecting only to Air nodes, while with Tor before VPN
you are randomly connecting to as many guards as possible.
This is an important point you have to understand before trying other various approaches.
One of the easy solutions would be creating a virtual network interface, or another virtual machine,
binding Tor on that network with a firewall rule to push all traffic via Tor, then enabling Network Lock
with an exception for local networks and connecting over that to VPN.
Sounds interesting. Could you please explain more on the practical steps on how to create virtual network interface and binding Tor? I use Mac OSX. For ordinary users like me it is too technical.
https://support.apple.com/kb/PH21618?viewlocale=en_US&locale=en_US
Or using the command line:
sudo ifconfig bridge1 create
sudo ifconfig bridge1 192.168.1.123/24
Assuming your network segment is 192.168.1.1/24 and you are assigning 192.168.1.123 to your new bridge.
Then some additional torrc configuration has to be done, according to:
https://trac.torproject.org/projects/tor/wiki/doc/TransparentProxy
¶ Local Redirection and Anonymizing Middlebox
VirtualAddrNetworkIPv4 192.168.1.123/32
AutomapHostsOnResolve 1
TransPort 9040
DNSPort 53
Then you have to configure pf rules as per this example (save to a file, then pfctl -f /some/file) :
int_if = "bridge1"
trans_port = "9040"
set skip on lo
match in all scrub (no-df random-id)
pass in quick on $int_if inet proto tcp to !($int_if) rdr-to 127.0.0.1 port $trans_port
pass in quick on $int_if inet proto udp to port domain rdr-to 127.0.0.1 port domain
Then you need to block outgoing connections from your main interface, here it will be very
specific to each setup (Ethernet/Wireless) and interface names, but generally it will be something like:
block drop out on en0 inet proto tcp all
block drop out on en0 inet proto udp all
TransPort 9040
DNSPort 53
int_if = "bridge1"
trans_port = "9040"
set skip on lo
Is it soo hard to add this feature in to eddie client? because i am not good in english...
The question here is not hard or not but if it is the correct way to get things done.
Not everything that is potentially possible should be part of the client, one of the reasons is that
this adds major networking complexity that might break things for people who are not familiar with it.
Note that the more common, secure and recommended approach to have such setup is running Tor
completely isolated in a VM, which will do the Tor tasks with minimum privileges in a virtual environment.
https://www.howtoforge.com/how-to-set-up-a-tor-middlebox-routing-all-virtualbox-virtual-machine-traffic-over-the-tor-network
https://www.malwaretech.com/2015/08/creating-ultimate-tor-virtual-network.html
I am tried with pfSense, can`t install pkg >< soo i can`t install this.
