I'm currently only having 1/10 of my rated 30/10 connection. This has been a issue for 3 days now. I use Time Warner and only connect to Canadian servers. Any advice would be appreciated.
You provided next to no information, so it's hard to help you haha. You might as well have said "I have a problem."
Try:
  1. Different ports, including SSL/SSH.
  2. Different TAP drivers.
  3. Contacting Air Support.
  4. Changing your OS and/or upgrading, especially if it's old.
  5. Forwarding some ports, if you're torrenting.
  6. Upgrading to the Experimental Eddie client.
  7. Checking my guide, if you choose to stick with the Stable version.
  8. Different servers.
  9. Disabling anti-virus and/or firewall software and see if anything changes.
  10. Different speedtests and not just Airs speedtest and running the tests more than once.
I use windows 7 mainly. I have tried many different servers in the Canadian side. The other regions just have too high of latency. The speedtest's that I have used is the google, speetest.net and airvps's server test. I have not tried the experimental client as of yet. I will check your guide since I failed to give enough information to make sense.
