MezRoGi
Airvpn not working with Networklock
Everything working fine for weeks until ..
This is not the "Can't connect without airvpn" when network lock is on but the OPPOSITE :
I can connect without airvpn (but have to reset IPv4 DNS) but cannot get a response from any connection when using airvpn and network lock.
I've been using for the past months OpenVPN GUI ( on windows 10) because I don't have to reset IPv4 dns when not using airvpn as with the client.
With openvpn gui : It says it's connected. But every connection times out.
With airvpn client (network lock on) as soon as it finished checking route, it disconnects.
I do not have a secondary firewall and have tried reseting windows firewall.
I also tried getting the latest version of airvpn client, no change.
LOGS :
With airvpn client :
I 2016.09.30 12:38:13 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.09.30 12:38:13 - Reading options from C:\Users\Mezrogi\AppData\Local\AirVPN\AirVPN.xml
. 2016.09.30 12:38:13 - Data Path: C:\Users\Mezrogi\AppData\Local\AirVPN
. 2016.09.30 12:38:13 - App Path: C:\Program Files\AirVPN
. 2016.09.30 12:38:13 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.09.30 12:38:13 - Command line arguments (1): path="home"
. 2016.09.30 12:38:13 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.09.30 12:38:13 - Updating systems & servers data ...
I 2016.09.30 12:38:13 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2016.09.30 12:38:13 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.09.30 12:38:13 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.09.30 12:38:13 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
W 2016.09.30 12:38:13 - Recovery. Unexpected crash?
. 2016.09.30 12:38:14 - Systems & servers data update completed
! 2016.09.30 12:38:14 - Activation of Network Lock - Windows Firewall
! 2016.09.30 12:38:18 - Ready
I 2016.09.30 12:38:47 - Session starting.
I 2016.09.30 12:38:48 - Checking authorization ...
! 2016.09.30 12:38:48 - Connecting to Situla (Netherlands, Alblasserdam)
. 2016.09.30 12:38:48 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.09.30 12:38:48 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.09.30 12:38:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.09.30 12:38:48 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.09.30 12:38:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:38:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:38:48 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.09.30 12:38:48 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.161.14:443 [nonblock]
. 2016.09.30 12:38:49 - OpenVPN > TCP connection established with [AF_INET]213.152.161.14:443
. 2016.09.30 12:38:49 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.09.30 12:38:49 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]213.152.161.14:443
. 2016.09.30 12:38:49 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.14:443, sid=9862b542 2413c8b4
. 2016.09.30 12:38:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.09.30 12:38:49 - OpenVPN > Validating certificate key usage
. 2016.09.30 12:38:49 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.09.30 12:38:49 - OpenVPN > VERIFY KU OK
. 2016.09.30 12:38:49 - OpenVPN > Validating certificate extended key usage
. 2016.09.30 12:38:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.09.30 12:38:49 - OpenVPN > VERIFY EKU OK
. 2016.09.30 12:38:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.09.30 12:38:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.30 12:38:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:38:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.30 12:38:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:38:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.09.30 12:38:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.14:443
. 2016.09.30 12:38:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.09.30 12:38:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.6.211 255.255.0.0'
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.30 12:38:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.30 12:38:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.09.30 12:38:52 - OpenVPN > open_tun, tt->ipv6=0
. 2016.09.30 12:38:52 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B19DAF4D-A24A-4BCC-850A-7F45E01EAB78}.tap
. 2016.09.30 12:38:52 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.09.30 12:38:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.0.0/10.5.6.211/255.255.0.0 [sUCCEEDED]
. 2016.09.30 12:38:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.6.211/255.255.0.0 on interface {B19DAF4D-A24A-4BCC-850A-7F45E01EAB78} [DHCP-serv: 10.5.255.254, lease-time: 31536000]
. 2016.09.30 12:38:52 - OpenVPN > Successful ARP Flush on interface [9] {B19DAF4D-A24A-4BCC-850A-7F45E01EAB78}
. 2016.09.30 12:38:57 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
. 2016.09.30 12:38:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.14 MASK 255.255.255.255 192.168.0.1
. 2016.09.30 12:38:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
. 2016.09.30 12:38:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.09.30 12:38:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 2
. 2016.09.30 12:38:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.09.30 12:38:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2016.09.30 12:38:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.09.30 12:38:57 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: L’objet existe déjà.   [status=5010 if_index=2]
. 2016.09.30 12:38:57 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.09.30 12:38:57 - OpenVPN > Route addition fallback to route.exe
. 2016.09.30 12:38:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.09.30 12:38:58 - Starting Management Interface
. 2016.09.30 12:38:58 - OpenVPN > Initialization Sequence Completed
I 2016.09.30 12:38:58 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.09.30 12:38:58 - DNS of a network adapter forced (The Broadcom 802.11 Network Adapter provides wireless local area networking.)
I 2016.09.30 12:38:58 - Flushing DNS
I 2016.09.30 12:38:58 - Checking route
I 2016.09.30 12:39:07 - Checking DNS
! 2016.09.30 12:39:07 - Connected.
. 2016.09.30 12:39:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.09.30 12:39:07 - OpenVPN > Connection reset, restarting [-1]
. 2016.09.30 12:39:07 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.09.30 12:39:07 - OpenVPN > Restart pause, 5 second(s)
. 2016.09.30 12:39:07 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2016.09.30 12:39:07 - OpenVPN > Attempting to establish TCP connection with [AF_INET]213.152.161.14:443 [nonblock]
. 2016.09.30 12:39:07 - OpenVPN > TCP connection established with [AF_INET]213.152.161.14:443
. 2016.09.30 12:39:07 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.09.30 12:39:07 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]213.152.161.14:443
. 2016.09.30 12:39:07 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.14:443, sid=75c26ec8 24bf5cb4
. 2016.09.30 12:39:07 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.09.30 12:39:07 - OpenVPN > Validating certificate key usage
. 2016.09.30 12:39:07 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.09.30 12:39:07 - OpenVPN > VERIFY KU OK
. 2016.09.30 12:39:07 - OpenVPN > Validating certificate extended key usage
. 2016.09.30 12:39:07 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.09.30 12:39:07 - OpenVPN > VERIFY EKU OK
. 2016.09.30 12:39:07 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.09.30 12:39:07 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.30 12:39:07 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:39:07 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.09.30 12:39:07 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.09.30 12:39:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.09.30 12:39:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.14:443
. 2016.09.30 12:39:07 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.09.30 12:39:07 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.6.211 255.255.0.0'
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.09.30 12:39:07 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.09.30 12:39:07 - OpenVPN > Preserving previous TUN/TAP instance: Ethernet 2
. 2016.09.30 12:39:07 - Starting Management Interface
. 2016.09.30 12:39:07 - OpenVPN > Initialization Sequence Completed
! 2016.09.30 12:39:07 - Disconnecting
. 2016.09.30 12:39:07 - Management - Send 'signal SIGTERM'
OpenVPN GUI thinks it's working, but it isn't :
Fri Sep 30 12:35:16 2016 OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [iPv6] built on May 10 2016
Fri Sep 30 12:35:16 2016 Windows version 6.2 (Windows 8 or greater) 64bit
Fri Sep 30 12:35:16 2016 library versions: OpenSSL 1.0.1t  3 May 2016, LZO 2.09
Fri Sep 30 12:35:16 2016 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:25340
Fri Sep 30 12:35:16 2016 Need hold release from management interface, waiting...
Fri Sep 30 12:35:16 2016 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:25340
Fri Sep 30 12:35:16 2016 MANAGEMENT: CMD 'state on'
Fri Sep 30 12:35:16 2016 MANAGEMENT: CMD 'log all on'
Fri Sep 30 12:35:16 2016 MANAGEMENT: CMD 'hold off'
Fri Sep 30 12:35:16 2016 MANAGEMENT: CMD 'hold release'
Fri Sep 30 12:35:17 2016 Control Channel Authentication: tls-auth using INLINE static key file
Fri Sep 30 12:35:17 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 30 12:35:17 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 30 12:35:17 2016 Socket Buffers: R=[65536->262144] S=[65536->262144]
Fri Sep 30 12:35:17 2016 MANAGEMENT: >STATE:1475231717,RESOLVE,,,
Fri Sep 30 12:35:17 2016 UDPv4 link local: [undef]
Fri Sep 30 12:35:17 2016 UDPv4 link remote: [AF_INET]62.102.148.147:443
Fri Sep 30 12:35:17 2016 MANAGEMENT: >STATE:1475231717,WAIT,,,
Fri Sep 30 12:35:17 2016 MANAGEMENT: >STATE:1475231717,AUTH,,,
Fri Sep 30 12:35:17 2016 TLS: Initial packet from [AF_INET]62.102.148.147:443, sid=97468434 f612593d
Fri Sep 30 12:35:17 2016 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Fri Sep 30 12:35:17 2016 Validating certificate key usage
Fri Sep 30 12:35:17 2016 ++ Certificate has key usage  00a0, expects 00a0
Fri Sep 30 12:35:17 2016 VERIFY KU OK
Fri Sep 30 12:35:17 2016 Validating certificate extended key usage
Fri Sep 30 12:35:17 2016 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Fri Sep 30 12:35:17 2016 VERIFY EKU OK
Fri Sep 30 12:35:17 2016 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Fri Sep 30 12:35:18 2016 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Sep 30 12:35:18 2016 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 30 12:35:18 2016 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Fri Sep 30 12:35:18 2016 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Fri Sep 30 12:35:18 2016 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Fri Sep 30 12:35:18 2016 [server] Peer Connection Initiated with [AF_INET]62.102.148.147:443
Fri Sep 30 12:35:19 2016 MANAGEMENT: >STATE:1475231719,GET_CONFIG,,,
Fri Sep 30 12:35:20 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Sep 30 12:35:20 2016 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.26.208 255.255.0.0'
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: timers and/or timeouts modified
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: LZO parms modified
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: --ifconfig/up options modified
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: route options modified
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: route-related options modified
Fri Sep 30 12:35:20 2016 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Fri Sep 30 12:35:20 2016 ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=2 HWADDR=24:0a:64:ec:55:db
Fri Sep 30 12:35:20 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Fri Sep 30 12:35:20 2016 MANAGEMENT: >STATE:1475231720,ASSIGN_IP,,10.4.26.208,
Fri Sep 30 12:35:20 2016 open_tun, tt->ipv6=0
Fri Sep 30 12:35:20 2016 TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B19DAF4D-A24A-4BCC-850A-7F45E01EAB78}.tap
Fri Sep 30 12:35:20 2016 TAP-Windows Driver Version 9.21
Fri Sep 30 12:35:20 2016 Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.26.208/255.255.0.0 [sUCCEEDED]
Fri Sep 30 12:35:20 2016 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.26.208/255.255.0.0 on interface {B19DAF4D-A24A-4BCC-850A-7F45E01EAB78} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
Fri Sep 30 12:35:20 2016 Successful ARP Flush on interface [9] {B19DAF4D-A24A-4BCC-850A-7F45E01EAB78}
Fri Sep 30 12:35:25 2016 TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
Fri Sep 30 12:35:25 2016 C:\WINDOWS\system32\route.exe ADD 62.102.148.147 MASK 255.255.255.255 192.168.0.1
Fri Sep 30 12:35:25 2016 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4
Fri Sep 30 12:35:25 2016 Route addition via IPAPI succeeded [adaptive]
Fri Sep 30 12:35:25 2016 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
Fri Sep 30 12:35:25 2016 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
Fri Sep 30 12:35:25 2016 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
Fri Sep 30 12:35:25 2016 Initialization Sequence Completed
Fri Sep 30 12:35:25 2016 MANAGEMENT: >STATE:1475231725,CONNECTED,SUCCESS,10.4.26.208,62.102.148.147
Any help would be greatly appreciated.
Maybe you could try changing your TAP drivers to an earlier version and see if that works
check your IP-Settings of your TAP-Adapter. See if everything is filled in correctly. Maybe no gateway IP?
