Hi all
I begun yesterday to use this VPN service and try to installed on my opensuse distro. Well, only the manual installation with openvpn and configuration file works, portable or rpms files doesn't do it.
I use an Internet connection with 300/300 Mb speed. Well, at the moment I use airvpn, it was impossible arrive at 5% this speed download any different files or check on different Internet_speed Web sites... Is it normal?
Enviado desde mi Nexus 5 mediante Tapatalk
I assume you downloaded the latest stable version. Please go to the download page> Other versions> Experimental/Beta version and try that .
Yes I did it, but with no luck.
Now, I just download deb file and convert to rpm with alien. Install and seems works. I can see servers,etc...
But the speed is minimal. A file 800 Mbs to download,normaly I use 3 minuts to do it,now I download one and see it cost 1 hour to the same...
Hi again. I tried to switch servers from the list that appears and I find that some who have good speed (I speak a little more than 10% of what I usually have) are as locked in some servers ... I'll go test and I comment.
Thank you
So you even tried the portable version of the experimental version and it didn't work?
Yes, yesterday I downloaded rpm and portable files. None of them worked, so far I have already said that I installed the beta deb file and it has worked.
