Paximus 0 Posted ... I get a leak when I use the configs for openVPN. No leaks with airVPN client, though. I seem to get a marginally better speed when using the openVPN configs, so I'd like to figure out what's causing it. Quote Share this post Link to post
foxmulder 43 Posted ... To prevent DNS leaks when using the generic OpenVPN client, you can use software like DNSJumper or SimpleDNSCrypt. Then you should be fine. https://simplednscrypt.org/ http://www.sordum.org/7952/dns-jumper-v2-0/ Regards Fox 1 Paximus reacted to this Quote Share this post Link to post
zhang888 1067 Posted ... You can add the "block-outside-dns" directive in your OpenVPN config - requires OpenVPN 2.3.9 and above. There is no explanation for the speed difference, but you can verify that the same configs are present both inthe configs downloaded from the client area and Eddie. Except the server address they are identical.Besides that there is no difference in the way it should work - both are using the OpenVPN binary. 4 itsmefloraluca, l33t, foxmulder and 1 other reacted to this Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
Tech Jedi Alex 1583 Posted ... There's simply no need for additional software to manage DNS (except for when you want to use DNSSEC). Just set your primary network interface's DNS settings to 10.4.0.1 and DNS issues are gone. 1 Paximus reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Paximus 0 Posted ... I think I figured it out. I had an alternate DNS set up through googles DNS server. The AirVPN client took care of it but OpenVPN wasn't. Quote Share this post Link to post
LZ1 686 Posted ... Hello! You could use the Air-supported OpenNic if you want . Have you tried the AirVPN Eddie client at all? Sent to you from me with datalove 1 Paximus reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Paximus 0 Posted ... Hello! You could use the Air-supported OpenNic if you want . Have you tried the AirVPN Eddie client at all? Sent to you from me with datalove Using Eddie now, sorry for not being more clear. Quote Share this post Link to post
foxmulder 43 Posted ... There is really no need to prefer the generic OpenVPN client over Eddie. The network lock feature is something very powerful and far outweighs the minor speed improvements with the generic OpenVPN client. And Eddie is open source and trustworthy. So i would definitely go with Eddie here, it is just the safest thing to do. No DNS and no IP leaks. Problems solved. Quote Share this post Link to post
LZ1 686 Posted ... In your case, Eddie is the way to go. Nicer interface, FOSS software, additional features such as network lock, plenty flexibility in the form of custom directives and such, as well as matching speeds. It's just great to use Airs own software & hardware ^=^. OpenNIC is a good alternative, in the sense that you can thus avoid using googles DNS (as it's otherwise a little self-defeating potentially haha). I don't otherwise see any advantages to not using Airs DNS, when they run things so well. If you don't use their DNS, I also don't think you can make use of their neat little micro-routing scheme. Sent to you from me with datalove Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
ntropia 0 Posted ... I found this topic while reading in the forum for a solution to the very same problem. I am using OpenVPN on Raspberry Pi, and I'm trying to reproduce all the features of Eddie without having to run the GUI, to save the memory to bring up the desktop. I found useful information on how to get something that looks like the Network lock from here, but I don't understand how to fix the DNS issue. Any advice is more than welcome. Quote Share this post Link to post
