boggleholeclough^
Auto-connect at boot
I wonder if anyone could explain how to get airvpn connecting automatically on start-up, if one cannot use Eddie. I can't use Eddie on Lubuntu because of "unsatisfiable dependencies" involving mono, and in (L)ubuntu's network connections manager there is no option to "connect automatically" with a vpn. Does anyone know how to do this?
Download the experimental, it does not require Mono.
Download the experimental, it does not require Mono. :)
 It does require Mono. However, unlike Eddie 2.10 and older versions, it is compatible with Mono 4.
See this:
https://airvpn.org/topic/16800-linux-how-to-start-openvpn-on-boot-and-auto-log-on/?p=37685
It involves using shell scripts - no GUI. And it uses crontab.
If you have never done things without a GUI, it may be a learning curve to understand that post.
