Hello all,
In the past i've used AirVPN and it was great, but now I encounter problems with DNS resolving. I run Ubuntu Gnome 16.04 LTS and once I connect with OpenVPN, I can't access websites through domain names. I can ping websites and grab the IP adres, which I can paste in a browser and access them. How and why is this happening? I tried different server in different countries, but I can only succeed in changing the DNS to Googles DNS.
Anyone experience the same problem?
Thanks in advance!
Instead of googles DNS, you could try OpenNIC
No, but you could append an OpenVPN log file if you want us to help you fix this. Connect and right after a successful connection, paste the whole log output into spoilers. How-To on spoilers in my signature.
Thanks for your answers!
Yeah sorry, should have be more precise indeed. Here's my log when succesfully connecting with OpenVPN.
Thu Sep  8 21:20:43 2016 OpenVPN 2.3.10 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [iPv6] built on Feb  2 2016
Thu Sep  8 21:20:43 2016 library versions: OpenSSL 1.0.2g-fips  1 Mar 2016, LZO 2.08
Thu Sep  8 21:20:43 2016 Control Channel Authentication: tls-auth using INLINE static key file
Thu Sep  8 21:20:43 2016 Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Sep  8 21:20:43 2016 Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Sep  8 21:20:43 2016 Socket Buffers: R=[212992->212992] S=[212992->212992]
Thu Sep  8 21:20:43 2016 UDPv4 link local: [undef]
Thu Sep  8 21:20:43 2016 UDPv4 link remote: [AF_INET]213.152.161.84:443
Thu Sep  8 21:20:43 2016 TLS: Initial packet from [AF_INET]213.152.161.84:443, sid=f977d458 2e72fb79
Thu Sep  8 21:20:43 2016 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Sep  8 21:20:43 2016 Validating certificate key usage
Thu Sep  8 21:20:43 2016 ++ Certificate has key usage  00a0, expects 00a0
Thu Sep  8 21:20:43 2016 VERIFY KU OK
Thu Sep  8 21:20:43 2016 Validating certificate extended key usage
Thu Sep  8 21:20:43 2016 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Thu Sep  8 21:20:43 2016 VERIFY EKU OK
Thu Sep  8 21:20:43 2016 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Sep  8 21:20:43 2016 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Sep  8 21:20:43 2016 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Sep  8 21:20:43 2016 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Sep  8 21:20:43 2016 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Sep  8 21:20:43 2016 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Thu Sep  8 21:20:43 2016 [server] Peer Connection Initiated with [AF_INET]213.152.161.84:443
Thu Sep  8 21:20:46 2016 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Sep  8 21:20:46 2016 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.79.124 255.255.0.0'
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: timers and/or timeouts modified
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: LZO parms modified
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: --ifconfig/up options modified
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: route options modified
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: route-related options modified
Thu Sep  8 21:20:46 2016 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Sep  8 21:20:46 2016 ROUTE_GATEWAY 192.168.178.1/255.255.255.0 IFACE=enp3s0 HWADDR=44:8a:5b:84:6e:46
Thu Sep  8 21:20:46 2016 TUN/TAP device tun0 opened
Thu Sep  8 21:20:46 2016 TUN/TAP TX queue length set to 100
Thu Sep  8 21:20:46 2016 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Sep  8 21:20:46 2016 /sbin/ip link set dev tun0 up mtu 1500
Thu Sep  8 21:20:46 2016 /sbin/ip addr add dev tun0 10.4.79.124/16 broadcast 10.4.255.255
Thu Sep  8 21:20:51 2016 /sbin/ip route add 213.152.161.84/32 via 192.168.178.1
Thu Sep  8 21:20:51 2016 /sbin/ip route add 0.0.0.0/1 via 10.4.0.1
Thu Sep  8 21:20:51 2016 /sbin/ip route add 128.0.0.0/1 via 10.4.0.1
Thu Sep  8 21:20:51 2016 Initialization Sequence Completed
