ogward 0 Posted ... Greetings, I just got a three day trial to try out your service.After installing I am not able to connect, the connection gets terminated over and over again.Read somewhere here on the forums that I should try installing the experimental version and that DNS switch mode should be disabled and check AirVPN DNS unchecked.The connection problem remains.Logs:I 2016.09.06 11:47:10 - Eddie client version: 2.11.3 / x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1 / x64. 2016.09.06 11:47:10 - Reading options from C:\Users\otomanovic\AppData\Local\AirVPN\AirVPN.xml. 2016.09.06 11:47:10 - Data Path: C:\Users\otomanovic\AppData\Local\AirVPN. 2016.09.06 11:47:10 - App Path: C:\Program Files\AirVPN. 2016.09.06 11:47:10 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe. 2016.09.06 11:47:10 - Command line arguments (1): path="home". 2016.09.06 11:47:10 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1I 2016.09.06 11:47:11 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2I 2016.09.06 11:47:11 - OpenVPN - Version: OpenVPN 2.3.11 (C:\Program Files\AirVPN\openvpn.exe)I 2016.09.06 11:47:11 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)I 2016.09.06 11:47:11 - SSL - Version: stunnel 5.32 (C:\Program Files\AirVPN\stunnel.exe)! 2016.09.06 11:47:11 - Ready. 2016.09.06 11:47:11 - Updating systems & servers data .... 2016.09.06 11:47:12 - Systems & servers data update completedI 2016.09.06 11:47:33 - Session starting.I 2016.09.06 11:47:33 - IPv6 disabled with packet filtering.I 2016.09.06 11:47:33 - Checking authorization ...! 2016.09.06 11:47:33 - Connecting to Albali (Sweden, Uppsala). 2016.09.06 11:47:33 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:47:33 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:47:33 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:47:33 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:47:34 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:47:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:47:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:47:34 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:47:34 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:47:34 - OpenVPN > UDPv4 link remote: [AF_INET]62.102.148.149:443. 2016.09.06 11:48:07 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:48:07 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:48:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:48:12 - Disconnecting. 2016.09.06 11:48:12 - Connection terminated.I 2016.09.06 11:48:15 - Checking authorization ...! 2016.09.06 11:48:15 - Connecting to Skat (Netherlands, Alblasserdam). 2016.09.06 11:48:15 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:48:15 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:48:15 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:48:15 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:48:16 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:48:16 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:48:16 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:48:16 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:48:16 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:48:16 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.73:443. 2016.09.06 11:48:48 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:48:48 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:48:54 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:48:54 - Disconnecting. 2016.09.06 11:48:54 - Connection terminated.I 2016.09.06 11:48:57 - Checking authorization ...! 2016.09.06 11:48:57 - Connecting to Atik (Netherlands, Alblasserdam). 2016.09.06 11:48:57 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:48:57 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:48:57 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:48:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:48:57 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:48:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:48:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:48:57 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:48:57 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:48:57 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.9:443. 2016.09.06 11:49:29 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:49:29 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:49:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:49:34 - Disconnecting. 2016.09.06 11:49:34 - Connection terminated.I 2016.09.06 11:49:37 - Checking authorization ...! 2016.09.06 11:49:38 - Connecting to Hassaleh (Netherlands, Alblasserdam). 2016.09.06 11:49:38 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:49:38 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:49:38 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:49:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:49:38 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:49:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:49:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:49:38 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:49:38 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:49:38 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.39:443. 2016.09.06 11:50:11 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:50:11 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:50:16 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:50:16 - Disconnecting. 2016.09.06 11:50:16 - Connection terminated.I 2016.09.06 11:50:19 - Checking authorization ...! 2016.09.06 11:50:19 - Connecting to Nash (Netherlands, Alblasserdam). 2016.09.06 11:50:19 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:50:19 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:50:19 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:50:19 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:50:19 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:50:19 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:50:19 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:50:19 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:50:19 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:50:19 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.24:443. 2016.09.06 11:50:51 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:50:51 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:50:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:50:56 - Disconnecting. 2016.09.06 11:50:56 - Connection terminated.I 2016.09.06 11:50:59 - Checking authorization ...! 2016.09.06 11:50:59 - Connecting to Gianfar (Netherlands, Alblasserdam). 2016.09.06 11:50:59 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jun 1 2016. 2016.09.06 11:50:59 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2016.09.06 11:50:59 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09. 2016.09.06 11:50:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2016.09.06 11:50:59 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file. 2016.09.06 11:50:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:50:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2016.09.06 11:50:59 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2016.09.06 11:50:59 - OpenVPN > UDPv4 link local: [undef]. 2016.09.06 11:50:59 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.100:443. 2016.09.06 11:51:31 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2016.09.06 11:51:31 - OpenVPN > SIGTERM received, sending exit notification to peer. 2016.09.06 11:51:36 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2016.09.06 11:51:36 - Disconnecting. 2016.09.06 11:51:36 - Connection terminated.I 2016.09.06 11:51:37 - Cancel requested.I 2016.09.06 11:51:37 - IPv6 restored with packet filtering.! 2016.09.06 11:51:37 - Session terminated.. 2016.09.06 11:57:12 - Updating systems & servers data .... 2016.09.06 11:57:12 - Systems & servers data update completed Cheers! Quote Share this post Link to post
Staff 10525 Posted ... Read somewhere here on the forums that I should try installing the experimental version and that DNS switch mode should be disabled and check AirVPN DNS unchecked.The connection problem remains. Hello! In your case the problem appears different: route check and DNS check do not even start because the connection can not be established. Something is blocking UDP and/or OpenVPN packets, according to the logs. Before anything else please check any packet filtering tool, both on your system and router. Kind regards Quote Share this post Link to post
ogward 0 Posted ... Ah ok. As I'm doing this from my PC at work it seems like it's company policy to block this.Guess there is nothing I can do Quote Share this post Link to post
ogward 0 Posted ... I unchecked automatic protocols and tried out a few from the list. Seems to work now Quote Share this post Link to post
ghost0104 0 Posted ... Hey ogward, seems like I have the same problem as yours.Can you tell me in specific detail, what all you did that worked for you?Many thanks in advance.Have a nice day. Quote Share this post Link to post
ogward 0 Posted ... Hey ogward, seems like I have the same problem as yours.Can you tell me in specific detail, what all you did that worked for you?Many thanks in advance.Have a nice day. Copy paste from the PM I sent you regarding this. "Well I didn't do much. It seems like company policy was blocking ports and protocols so I tried to find one that was not blocked.Preference->Protocol->Uncheck Automatic now chose one form the list and try to connect. SSH on port 22 worked for me. Hope this helps." ReplyReportEdit Quote Share this post Link to post
