romeo4you
normal navigation after network lock
hi  guys
i m really  satisfied about  using vpn  but
after  using it  whit  network lock activated  how  can i  navigate  "normal"???
beacuse  after  using  it  i  cannot  navigate  more  without  vpn
there is a  procedure  to use  when i 'm  stopping  use  vpn?
really  thank  you
ps :  sistem  is  windows  7 ultimate
Hello !
You should try to deactivate network lock via the button and when you close Eddie, you should do so via its own menus by clicking exit. If not, you might get an error, wherein settings aren't restored.
It sounds like settings weren't restored in your case, so try go to your internet settings and set IPv4 and DNS to "obtain automatically"
