drive1
will i get my same Internetspeed
hi i have A 20MBPS INTERNET connecton from comcast if i join airvpn will i get the same speed as from my isp and can i connect multiple devices to the vpn like have all connectons go through my router its a linksys e300 with ddwrt fw.
You will not get the same speed (please see the FAQ for details). We must be clear on this point: adding a VPN hop will unavoidably decrease performance. Since we pick servers on datacenters connected to tier1 providers, the performance decrease in most cases is a fair price to pay for a layer of anonymity and privacy.
On the other hand, if your ISP caps certain protocols (for example p2p) you will get a better performance with a VPN on those protocols. We do not discriminate against any protocol and we do not monitor the connections, not even to determine protocols for technical reasons. The only exception to the purest Net Neutrality is the block of outbound port 25 that we are forced to perform to keep the service alive.
You can connect as many devices as you wish through your DD-WRT router, you will need just one account that you can use directly on your router. See also https://airvpn.org/ddwrt
Please do not hesitate to contact us for any further information.
