ParadoxQc 0 Posted ... I've recently got this VPN and its been giving me lots of trouble already. Im always on teamspeak and they have a tool to check my connection info including packet loss and at seemingly random I get upward of 15% packet loss. Then it goes back down but always hang around 2% until it spikes again.If I ping google, i mostly get good time but some can go over 350ms and always get lots of request times out. Tried on multiple servers in Canada and US but they all cause this issue.Without the VPN, I got no issues at all. Anyone got an idea of what could be causing this? Quote Share this post Link to post
zhang888 1067 Posted ... What connection method are you using? Try switching to TCP/443. Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
ParadoxQc 0 Posted ... That actually seems to have done it. Surprisingly simple.I probably should have searched a bit more. For some reason, i wasnt able to find anything about this.Thanks a lot for the help. I still get a bit of packet loss but its a lot better. If it matters, I have a Cable connection Quote Share this post Link to post
LZ1 679 Posted ... That actually seems to have done it. Surprisingly simple.I probably should have searched a bit more. For some reason, i wasnt able to find anything about this.Thanks a lot for the help. I still get a bit of packet loss but its a lot better. If it matters, I have a Cable connectionHello! Maybe you should look into doing some port forwarding, which you can do in the client area, as well as checking that your firewall is allowing whichever program that you're using Welcome to AirVPN. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
Tech Jedi Alex 1531 Posted ... That actually seems to have done it. Surprisingly simple.I probably should have searched a bit more. For some reason, i wasnt able to find anything about this.Thanks a lot for the help. I still get a bit of packet loss but its a lot better. If it matters, I have a Cable connectionHello! Maybe you should look into doing some port forwarding, which you can do in the client area, as well as checking that your firewall is allowing whichever program that you're using Welcome to AirVPN. TeamSpeak doesn't listen for connections, ergo it doesn't need an open port Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
