jeweethet
Airvpn - Problem - am i being observed?
recently since like 1 or 1.5 week my airvpn is having strange behaviour.
It now and then suddenly disconnects, and then needs to reconnect / authorize again.
Somehow it doesnt feel natural / a pc conflict this problem but i could be wrong.
Maybe its important, but these logs no one changed anything like settings not on the network and not on my laptop.
The first 2 disconnects i was sleeping, so no user activity on the laptop as well.
last disconnect i was browsing.
. 2016.07.15 23:11:45 - Systems & servers data update completed
. 2016.07.15 23:23:44 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.15 23:23:44 - OpenVPN > Validating certificate key usage
. 2016.07.15 23:23:44 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.15 23:23:44 - OpenVPN > VERIFY KU OK
. 2016.07.15 23:23:44 - OpenVPN > Validating certificate extended key usage
. 2016.07.15 23:23:44 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.15 23:23:44 - OpenVPN > VERIFY EKU OK
. 2016.07.15 23:23:44 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.15 23:23:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.15 23:23:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:23:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.15 23:23:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:23:46 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.15 23:40:00 - OpenVPN > read TCPv4_CLIENT: Connection timed out (WSAETIMEDOUT) (code=10060)
. 2016.07.15 23:40:00 - OpenVPN > Connection reset, restarting [-1]
. 2016.07.15 23:40:00 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.07.15 23:40:00 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.15 23:40:00 - Disconnecting
. 2016.07.15 23:40:00 - Management - Send 'signal SIGTERM'
. 2016.07.15 23:40:00 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.15 23:40:00 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.07.15 23:40:00 - OpenVPN > Assertion failed at misc.c:788
. 2016.07.15 23:40:00 - OpenVPN > Exiting due to fatal error
. 2016.07.15 23:40:01 - Connection terminated.
I 2016.07.15 23:40:02 - DNS of a network adapter restored to original settings (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.15 23:40:02 - DNS of a network adapter restored to original settings (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.15 23:40:02 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.15 23:40:02 - DNS of a network adapter restored to original settings (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.15 23:40:21 - Checking authorization ...
! 2016.07.15 23:40:21 - Connecting to Azmidiske (Sweden, Uppsala)
. 2016.07.15 23:40:21 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2016.07.15 23:40:21 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2016.07.15 23:40:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.15 23:40:22 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.15 23:40:22 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:40:22 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:40:22 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2016.07.15 23:40:22 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.141:443 [nonblock]
. 2016.07.15 23:40:23 - OpenVPN > TCP connection established with [AF_INET]62.102.148.141:443
. 2016.07.15 23:40:23 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.15 23:40:23 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]62.102.148.141:443
. 2016.07.15 23:40:23 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.141:443, sid=f51e2740 2526a036
. 2016.07.15 23:40:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.15 23:40:23 - OpenVPN > Validating certificate key usage
. 2016.07.15 23:40:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.15 23:40:23 - OpenVPN > VERIFY KU OK
. 2016.07.15 23:40:23 - OpenVPN > Validating certificate extended key usage
. 2016.07.15 23:40:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.15 23:40:23 - OpenVPN > VERIFY EKU OK
. 2016.07.15 23:40:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.15 23:40:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.15 23:40:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:40:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.15 23:40:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.15 23:40:25 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.15 23:40:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.141:443
. 2016.07.15 23:40:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.15 23:40:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.1.224 255.255.0.0'
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.15 23:40:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.15 23:40:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.15 23:40:28 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.15 23:40:28 - OpenVPN > TAP-WIN32 device [LAN-verbinding 2] opened: \\.\Global\{803E74C5-D35D-4D62-BC35-D64DC578DDC0}.tap
. 2016.07.15 23:40:28 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.15 23:40:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.0.0/10.5.1.224/255.255.0.0 [sUCCEEDED]
. 2016.07.15 23:40:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.224/255.255.0.0 on interface {803E74C5-D35D-4D62-BC35-D64DC578DDC0} [DHCP-serv: 10.5.255.254, lease-time: 31536000]
. 2016.07.15 23:40:28 - OpenVPN > Successful ARP Flush on interface [24] {803E74C5-D35D-4D62-BC35-D64DC578DDC0}
. 2016.07.15 23:40:33 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=1 u/d=up
. 2016.07.15 23:40:33 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.141 MASK 255.255.255.255 192.168.0.1
. 2016.07.15 23:40:33 - OpenVPN > Warning: route gateway is ambiguous: 192.168.0.1 (2 matches)
. 2016.07.15 23:40:33 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.07.15 23:40:33 - OpenVPN > Route addition fallback to route.exe
. 2016.07.15 23:40:33 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.15 23:40:33 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 30
. 2016.07.15 23:40:33 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: Het object bestaat al.   [status=5010 if_index=30]
. 2016.07.15 23:40:33 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.15 23:40:33 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: Het object bestaat al.   [status=5010 if_index=24]
. 2016.07.15 23:40:33 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.15 23:40:33 - OpenVPN > C:\Windows\system32\route.exe ADD 66.211.169.3 MASK 255.255.255.255 192.168.0.1
. 2016.07.15 23:40:34 - Starting Management Interface
. 2016.07.15 23:40:34 - OpenVPN > Initialization Sequence Completed
I 2016.07.15 23:40:34 - DNS of a network adapter forced (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.15 23:40:34 - DNS of a network adapter forced (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.15 23:40:34 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.15 23:40:34 - DNS of a network adapter forced (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.15 23:40:34 - Flushing DNS
I 2016.07.15 23:40:35 - Checking DNS
! 2016.07.15 23:40:36 - Connected.
. 2016.07.15 23:40:36 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.15 23:40:36 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.15 23:42:20 - Updating systems & servers data ...
. 2016.07.15 23:42:21 - Systems & servers data update completed
. 2016.07.16 00:12:56 - Updating systems & servers data ...
. 2016.07.16 00:12:57 - Systems & servers data update completed
. 2016.07.16 00:40:25 - OpenVPN > TLS: soft reset sec=0 bytes=1306479/0 pkts=4397/0
. 2016.07.16 00:40:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 00:40:26 - OpenVPN > Validating certificate key usage
. 2016.07.16 00:40:26 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 00:40:26 - OpenVPN > VERIFY KU OK
. 2016.07.16 00:40:26 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 00:40:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 00:40:26 - OpenVPN > VERIFY EKU OK
. 2016.07.16 00:40:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 00:40:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 00:40:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 00:40:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 00:40:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 00:40:27 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 00:43:32 - Updating systems & servers data ...
. 2016.07.16 00:43:33 - Systems & servers data update completed
. 2016.07.16 01:13:50 - Updating systems & servers data ...
. 2016.07.16 01:13:52 - Systems & servers data update completed
I 2016.07.16 01:40:25 - Renewing TLS key
. 2016.07.16 01:40:25 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 01:40:27 - OpenVPN > TLS: soft reset sec=0 bytes=14841430/0 pkts=38149/0
. 2016.07.16 01:40:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 01:40:27 - OpenVPN > Validating certificate key usage
. 2016.07.16 01:40:27 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 01:40:27 - OpenVPN > VERIFY KU OK
. 2016.07.16 01:40:27 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 01:40:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 01:40:27 - OpenVPN > VERIFY EKU OK
. 2016.07.16 01:40:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 01:40:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 01:40:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 01:40:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 01:40:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 01:40:28 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 01:44:32 - Updating systems & servers data ...
. 2016.07.16 01:44:34 - Systems & servers data update completed
. 2016.07.16 02:14:41 - Updating systems & servers data ...
. 2016.07.16 02:14:42 - Systems & servers data update completed
I 2016.07.16 02:40:27 - Renewing TLS key
. 2016.07.16 02:40:27 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 02:40:28 - OpenVPN > TLS: soft reset sec=0 bytes=24638897/0 pkts=53803/0
. 2016.07.16 02:40:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 02:40:28 - OpenVPN > Validating certificate key usage
. 2016.07.16 02:40:28 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 02:40:28 - OpenVPN > VERIFY KU OK
. 2016.07.16 02:40:28 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 02:40:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 02:40:28 - OpenVPN > VERIFY EKU OK
. 2016.07.16 02:40:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 02:40:29 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 02:40:29 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 02:40:29 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 02:40:29 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 02:40:29 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 02:44:44 - Updating systems & servers data ...
. 2016.07.16 02:44:46 - Systems & servers data update completed
. 2016.07.16 03:15:37 - Updating systems & servers data ...
. 2016.07.16 03:15:39 - Systems & servers data update completed
I 2016.07.16 03:40:28 - Renewing TLS key
. 2016.07.16 03:40:28 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 03:40:29 - OpenVPN > TLS: soft reset sec=0 bytes=11152806/0 pkts=38076/0
. 2016.07.16 03:40:29 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 03:40:29 - OpenVPN > Validating certificate key usage
. 2016.07.16 03:40:29 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 03:40:29 - OpenVPN > VERIFY KU OK
. 2016.07.16 03:40:29 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 03:40:29 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 03:40:29 - OpenVPN > VERIFY EKU OK
. 2016.07.16 03:40:29 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 03:40:31 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 03:40:31 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 03:40:31 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 03:40:31 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 03:40:31 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 03:46:14 - Updating systems & servers data ...
. 2016.07.16 03:46:16 - Systems & servers data update completed
. 2016.07.16 04:16:50 - Updating systems & servers data ...
. 2016.07.16 04:16:51 - Systems & servers data update completed
I 2016.07.16 04:40:29 - Renewing TLS key
. 2016.07.16 04:40:29 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 04:40:30 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 04:40:30 - OpenVPN > Validating certificate key usage
. 2016.07.16 04:40:30 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 04:40:30 - OpenVPN > VERIFY KU OK
. 2016.07.16 04:40:30 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 04:40:30 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 04:40:30 - OpenVPN > VERIFY EKU OK
. 2016.07.16 04:40:30 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 04:40:32 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 04:40:32 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 04:40:32 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 04:40:32 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 04:40:32 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 04:47:30 - Updating systems & servers data ...
. 2016.07.16 04:47:31 - Systems & servers data update completed
. 2016.07.16 05:18:05 - Updating systems & servers data ...
. 2016.07.16 05:18:06 - Systems & servers data update completed
I 2016.07.16 05:40:30 - Renewing TLS key
. 2016.07.16 05:40:30 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 05:40:31 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 05:40:31 - OpenVPN > Validating certificate key usage
. 2016.07.16 05:40:31 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 05:40:31 - OpenVPN > VERIFY KU OK
. 2016.07.16 05:40:31 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 05:40:31 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 05:40:31 - OpenVPN > VERIFY EKU OK
. 2016.07.16 05:40:31 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 05:40:33 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 05:40:33 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 05:40:33 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 05:40:33 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 05:40:33 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 05:48:36 - Updating systems & servers data ...
. 2016.07.16 05:48:37 - Systems & servers data update completed
. 2016.07.16 06:19:12 - Updating systems & servers data ...
. 2016.07.16 06:19:13 - Systems & servers data update completed
I 2016.07.16 06:40:31 - Renewing TLS key
. 2016.07.16 06:40:31 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 06:40:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 06:40:32 - OpenVPN > Validating certificate key usage
. 2016.07.16 06:40:32 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 06:40:32 - OpenVPN > VERIFY KU OK
. 2016.07.16 06:40:32 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 06:40:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 06:40:32 - OpenVPN > VERIFY EKU OK
. 2016.07.16 06:40:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 06:40:34 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 06:40:34 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 06:40:34 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 06:40:34 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 06:40:34 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 06:49:47 - Updating systems & servers data ...
. 2016.07.16 06:49:48 - Systems & servers data update completed
. 2016.07.16 07:20:23 - Updating systems & servers data ...
. 2016.07.16 07:20:24 - Systems & servers data update completed
I 2016.07.16 07:40:32 - Renewing TLS key
. 2016.07.16 07:40:32 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 07:40:34 - OpenVPN > TLS: soft reset sec=0 bytes=5686342/0 pkts=37009/0
. 2016.07.16 07:40:34 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 07:40:34 - OpenVPN > Validating certificate key usage
. 2016.07.16 07:40:34 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 07:40:34 - OpenVPN > VERIFY KU OK
. 2016.07.16 07:40:34 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 07:40:34 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 07:40:34 - OpenVPN > VERIFY EKU OK
. 2016.07.16 07:40:34 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 07:40:36 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 07:40:36 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 07:40:36 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 07:40:36 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 07:40:36 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 07:50:59 - Updating systems & servers data ...
. 2016.07.16 07:51:00 - Systems & servers data update completed
. 2016.07.16 08:21:35 - Updating systems & servers data ...
. 2016.07.16 08:21:37 - Systems & servers data update completed
I 2016.07.16 08:40:34 - Renewing TLS key
. 2016.07.16 08:40:34 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 08:40:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 08:40:35 - OpenVPN > Validating certificate key usage
. 2016.07.16 08:40:35 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 08:40:35 - OpenVPN > VERIFY KU OK
. 2016.07.16 08:40:35 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 08:40:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 08:40:35 - OpenVPN > VERIFY EKU OK
. 2016.07.16 08:40:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 08:40:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 08:40:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 08:40:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 08:40:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 08:40:37 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 08:52:12 - Updating systems & servers data ...
. 2016.07.16 08:52:13 - Systems & servers data update completed
. 2016.07.16 09:22:46 - Updating systems & servers data ...
. 2016.07.16 09:22:47 - Systems & servers data update completed
I 2016.07.16 09:40:35 - Renewing TLS key
. 2016.07.16 09:40:35 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 09:40:36 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 09:40:36 - OpenVPN > Validating certificate key usage
. 2016.07.16 09:40:36 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 09:40:36 - OpenVPN > VERIFY KU OK
. 2016.07.16 09:40:36 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 09:40:36 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 09:40:36 - OpenVPN > VERIFY EKU OK
. 2016.07.16 09:40:36 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 09:40:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 09:40:37 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 09:40:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 09:40:37 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 09:40:37 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 09:53:22 - Updating systems & servers data ...
. 2016.07.16 09:53:23 - Systems & servers data update completed
. 2016.07.16 10:23:58 - Updating systems & servers data ...
. 2016.07.16 10:23:58 - Systems & servers data update completed
I 2016.07.16 10:40:36 - Renewing TLS key
. 2016.07.16 10:40:36 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 10:40:37 - OpenVPN > TLS: soft reset sec=0 bytes=258557956/0 pkts=300692/0
. 2016.07.16 10:40:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 10:40:37 - OpenVPN > Validating certificate key usage
. 2016.07.16 10:40:37 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 10:40:37 - OpenVPN > VERIFY KU OK
. 2016.07.16 10:40:37 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 10:40:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 10:40:37 - OpenVPN > VERIFY EKU OK
. 2016.07.16 10:40:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 10:40:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 10:40:38 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:40:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 10:40:38 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:40:38 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 10:54:33 - Updating systems & servers data ...
. 2016.07.16 10:54:36 - OpenVPN > Connection reset, restarting [-1]
. 2016.07.16 10:54:36 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.07.16 10:54:36 - OpenVPN > Restart pause, 5 second(s)
! 2016.07.16 10:54:36 - Disconnecting
. 2016.07.16 10:54:36 - Management - Send 'signal SIGTERM'
. 2016.07.16 10:54:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.16 10:54:36 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.07.16 10:54:36 - OpenVPN > Assertion failed at misc.c:788
. 2016.07.16 10:54:36 - OpenVPN > Exiting due to fatal error
. 2016.07.16 10:54:37 - Connection terminated.
. 2016.07.16 10:54:37 - Systems & servers data update completed
I 2016.07.16 10:54:38 - DNS of a network adapter restored to original settings (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.16 10:54:38 - DNS of a network adapter restored to original settings (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.16 10:54:38 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.16 10:54:38 - DNS of a network adapter restored to original settings (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.16 10:54:50 - Checking authorization ...
! 2016.07.16 10:54:50 - Connecting to Algieba (Sweden, Uppsala)
. 2016.07.16 10:54:51 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2016.07.16 10:54:51 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2016.07.16 10:54:51 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.16 10:54:51 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.16 10:54:51 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:54:51 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:54:51 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2016.07.16 10:54:51 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.142:443 [nonblock]
. 2016.07.16 10:54:52 - OpenVPN > TCP connection established with [AF_INET]62.102.148.142:443
. 2016.07.16 10:54:52 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.16 10:54:52 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]62.102.148.142:443
. 2016.07.16 10:54:52 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.142:443, sid=d15a8dca c995bc1d
. 2016.07.16 10:54:52 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 10:54:52 - OpenVPN > Validating certificate key usage
. 2016.07.16 10:54:52 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 10:54:52 - OpenVPN > VERIFY KU OK
. 2016.07.16 10:54:52 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 10:54:52 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 10:54:52 - OpenVPN > VERIFY EKU OK
. 2016.07.16 10:54:52 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 10:54:54 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 10:54:54 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:54:54 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 10:54:54 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 10:54:54 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 10:54:54 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.142:443
. 2016.07.16 10:54:56 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.16 10:54:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.1.190 255.255.0.0'
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.16 10:54:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.16 10:54:57 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.16 10:54:57 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.16 10:54:57 - OpenVPN > TAP-WIN32 device [LAN-verbinding 2] opened: \\.\Global\{803E74C5-D35D-4D62-BC35-D64DC578DDC0}.tap
. 2016.07.16 10:54:57 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.16 10:54:57 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.0.0/10.5.1.190/255.255.0.0 [sUCCEEDED]
. 2016.07.16 10:54:57 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.190/255.255.0.0 on interface {803E74C5-D35D-4D62-BC35-D64DC578DDC0} [DHCP-serv: 10.5.255.254, lease-time: 31536000]
. 2016.07.16 10:54:57 - OpenVPN > Successful ARP Flush on interface [24] {803E74C5-D35D-4D62-BC35-D64DC578DDC0}
. 2016.07.16 10:55:02 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=1 u/d=up
. 2016.07.16 10:55:02 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.142 MASK 255.255.255.255 192.168.0.1
. 2016.07.16 10:55:02 - OpenVPN > Warning: route gateway is ambiguous: 192.168.0.1 (2 matches)
. 2016.07.16 10:55:02 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.07.16 10:55:02 - OpenVPN > Route addition fallback to route.exe
. 2016.07.16 10:55:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.16 10:55:02 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 30
. 2016.07.16 10:55:02 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: Het object bestaat al.   [status=5010 if_index=30]
. 2016.07.16 10:55:02 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.16 10:55:02 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: Het object bestaat al.   [status=5010 if_index=24]
. 2016.07.16 10:55:02 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.16 10:55:02 - OpenVPN > C:\Windows\system32\route.exe ADD 66.211.169.3 MASK 255.255.255.255 192.168.0.1
. 2016.07.16 10:55:02 - Starting Management Interface
. 2016.07.16 10:55:02 - OpenVPN > Initialization Sequence Completed
I 2016.07.16 10:55:02 - DNS of a network adapter forced (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.16 10:55:02 - DNS of a network adapter forced (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.16 10:55:03 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.16 10:55:03 - DNS of a network adapter forced (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.16 10:55:03 - Flushing DNS
I 2016.07.16 10:55:04 - Checking DNS
! 2016.07.16 10:55:05 - Connected.
. 2016.07.16 10:55:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.16 10:55:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.07.16 11:25:14 - Updating systems & servers data ...
. 2016.07.16 11:25:17 - Systems & servers data update completed
. 2016.07.16 11:54:54 - OpenVPN > TLS: soft reset sec=0 bytes=141395814/0 pkts=215960/0
. 2016.07.16 11:54:54 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 11:54:54 - OpenVPN > Validating certificate key usage
. 2016.07.16 11:54:54 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 11:54:54 - OpenVPN > VERIFY KU OK
. 2016.07.16 11:54:54 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 11:54:54 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 11:54:54 - OpenVPN > VERIFY EKU OK
. 2016.07.16 11:54:54 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 11:54:55 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 11:54:55 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 11:54:55 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 11:54:55 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 11:54:55 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 11:55:51 - Updating systems & servers data ...
. 2016.07.16 11:55:52 - Systems & servers data update completed
. 2016.07.16 12:26:30 - Updating systems & servers data ...
. 2016.07.16 12:26:31 - Systems & servers data update completed
I 2016.07.16 12:54:54 - Renewing TLS key
. 2016.07.16 12:54:54 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 12:54:55 - OpenVPN > TLS: soft reset sec=0 bytes=272454219/0 pkts=360490/0
. 2016.07.16 12:54:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 12:54:55 - OpenVPN > Validating certificate key usage
. 2016.07.16 12:54:55 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 12:54:55 - OpenVPN > VERIFY KU OK
. 2016.07.16 12:54:55 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 12:54:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 12:54:55 - OpenVPN > VERIFY EKU OK
. 2016.07.16 12:54:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 12:54:56 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 12:54:56 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 12:54:56 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 12:54:56 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 12:54:56 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 12:57:10 - Updating systems & servers data ...
. 2016.07.16 12:57:11 - Systems & servers data update completed
. 2016.07.16 13:27:56 - Updating systems & servers data ...
. 2016.07.16 13:27:58 - Systems & servers data update completed
I 2016.07.16 13:54:55 - Renewing TLS key
. 2016.07.16 13:54:56 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 13:54:56 - OpenVPN > TLS: soft reset sec=0 bytes=150296496/0 pkts=248976/0
. 2016.07.16 13:54:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 13:54:56 - OpenVPN > Validating certificate key usage
. 2016.07.16 13:54:56 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 13:54:56 - OpenVPN > VERIFY KU OK
. 2016.07.16 13:54:56 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 13:54:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 13:54:56 - OpenVPN > VERIFY EKU OK
. 2016.07.16 13:54:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 13:54:57 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 13:54:57 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 13:54:57 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 13:54:57 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 13:54:57 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 13:58:48 - Updating systems & servers data ...
. 2016.07.16 13:58:50 - Systems & servers data update completed
. 2016.07.16 14:29:36 - Updating systems & servers data ...
. 2016.07.16 14:29:37 - Systems & servers data update completed
I 2016.07.16 14:54:56 - Renewing TLS key
. 2016.07.16 14:54:56 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 14:54:57 - OpenVPN > TLS: soft reset sec=0 bytes=238603046/0 pkts=356017/0
. 2016.07.16 14:54:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 14:54:57 - OpenVPN > Validating certificate key usage
. 2016.07.16 14:54:57 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 14:54:57 - OpenVPN > VERIFY KU OK
. 2016.07.16 14:54:57 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 14:54:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 14:54:57 - OpenVPN > VERIFY EKU OK
. 2016.07.16 14:54:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 14:54:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 14:54:58 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 14:54:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 14:54:58 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 14:54:58 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 14:59:53 - Updating systems & servers data ...
. 2016.07.16 14:59:54 - Systems & servers data update completed
. 2016.07.16 15:30:02 - Updating systems & servers data ...
. 2016.07.16 15:30:03 - Systems & servers data update completed
I 2016.07.16 15:54:57 - Renewing TLS key
. 2016.07.16 15:54:57 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 15:54:58 - OpenVPN > TLS: soft reset sec=0 bytes=70346271/0 pkts=148144/0
. 2016.07.16 15:54:58 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 15:54:58 - OpenVPN > Validating certificate key usage
. 2016.07.16 15:54:58 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 15:54:58 - OpenVPN > VERIFY KU OK
. 2016.07.16 15:54:58 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 15:54:58 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 15:54:58 - OpenVPN > VERIFY EKU OK
. 2016.07.16 15:54:58 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 15:55:00 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 15:55:00 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 15:55:00 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 15:55:00 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 15:55:00 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 16:00:35 - Updating systems & servers data ...
. 2016.07.16 16:00:36 - Systems & servers data update completed
. 2016.07.16 16:31:36 - Updating systems & servers data ...
. 2016.07.16 16:31:37 - Systems & servers data update completed
I 2016.07.16 16:54:58 - Renewing TLS key
. 2016.07.16 16:54:58 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 16:55:00 - OpenVPN > TLS: soft reset sec=0 bytes=289003815/0 pkts=406451/0
. 2016.07.16 16:55:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 16:55:00 - OpenVPN > Validating certificate key usage
. 2016.07.16 16:55:00 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 16:55:00 - OpenVPN > VERIFY KU OK
. 2016.07.16 16:55:00 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 16:55:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 16:55:00 - OpenVPN > VERIFY EKU OK
. 2016.07.16 16:55:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 16:55:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 16:55:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 16:55:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 16:55:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 16:55:01 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 17:01:46 - Updating systems & servers data ...
. 2016.07.16 17:01:48 - Systems & servers data update completed
. 2016.07.16 17:32:07 - Updating systems & servers data ...
. 2016.07.16 17:32:08 - Systems & servers data update completed
I 2016.07.16 17:55:00 - Renewing TLS key
. 2016.07.16 17:55:00 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 17:55:01 - OpenVPN > TLS: soft reset sec=0 bytes=261338769/0 pkts=368887/0
. 2016.07.16 17:55:02 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 17:55:02 - OpenVPN > Validating certificate key usage
. 2016.07.16 17:55:02 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 17:55:02 - OpenVPN > VERIFY KU OK
. 2016.07.16 17:55:02 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 17:55:02 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 17:55:02 - OpenVPN > VERIFY EKU OK
. 2016.07.16 17:55:02 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 17:55:07 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 17:55:07 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 17:55:07 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 17:55:07 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 17:55:07 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 18:02:17 - Updating systems & servers data ...
. 2016.07.16 18:02:21 - Systems & servers data update completed
. 2016.07.16 18:33:01 - Updating systems & servers data ...
. 2016.07.16 18:33:05 - Systems & servers data update completed
I 2016.07.16 18:55:01 - Renewing TLS key
. 2016.07.16 18:55:01 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 18:55:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 18:55:06 - OpenVPN > Validating certificate key usage
. 2016.07.16 18:55:06 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 18:55:06 - OpenVPN > VERIFY KU OK
. 2016.07.16 18:55:06 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 18:55:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 18:55:06 - OpenVPN > VERIFY EKU OK
. 2016.07.16 18:55:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 18:55:08 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 18:55:08 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 18:55:08 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 18:55:08 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 18:55:08 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 19:03:29 - Updating systems & servers data ...
. 2016.07.16 19:03:33 - Systems & servers data update completed
. 2016.07.16 19:34:20 - Updating systems & servers data ...
. 2016.07.16 19:34:21 - Systems & servers data update completed
I 2016.07.16 19:55:06 - Renewing TLS key
. 2016.07.16 19:55:06 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 19:55:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 19:55:08 - OpenVPN > Validating certificate key usage
. 2016.07.16 19:55:08 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 19:55:08 - OpenVPN > VERIFY KU OK
. 2016.07.16 19:55:08 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 19:55:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 19:55:08 - OpenVPN > VERIFY EKU OK
. 2016.07.16 19:55:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 19:55:10 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 19:55:10 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 19:55:10 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 19:55:10 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 19:55:10 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 20:04:20 - Updating systems & servers data ...
. 2016.07.16 20:04:22 - Systems & servers data update completed
. 2016.07.16 20:34:41 - Updating systems & servers data ...
. 2016.07.16 20:34:43 - Systems & servers data update completed
I 2016.07.16 20:55:08 - Renewing TLS key
. 2016.07.16 20:55:08 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 20:55:10 - OpenVPN > TLS: soft reset sec=0 bytes=299919922/0 pkts=402243/0
. 2016.07.16 20:55:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 20:55:10 - OpenVPN > Validating certificate key usage
. 2016.07.16 20:55:10 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 20:55:10 - OpenVPN > VERIFY KU OK
. 2016.07.16 20:55:10 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 20:55:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 20:55:10 - OpenVPN > VERIFY EKU OK
. 2016.07.16 20:55:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 20:55:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 20:55:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 20:55:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 20:55:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 20:55:12 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 21:04:51 - Updating systems & servers data ...
. 2016.07.16 21:04:56 - Systems & servers data update completed
. 2016.07.16 21:35:14 - Updating systems & servers data ...
. 2016.07.16 21:35:15 - Systems & servers data update completed
I 2016.07.16 21:55:10 - Renewing TLS key
. 2016.07.16 21:55:10 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 21:55:12 - OpenVPN > TLS: soft reset sec=0 bytes=325518219/0 pkts=430958/0
. 2016.07.16 21:55:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 21:55:12 - OpenVPN > Validating certificate key usage
. 2016.07.16 21:55:12 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 21:55:12 - OpenVPN > VERIFY KU OK
. 2016.07.16 21:55:12 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 21:55:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 21:55:12 - OpenVPN > VERIFY EKU OK
. 2016.07.16 21:55:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 21:55:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 21:55:14 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 21:55:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 21:55:14 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 21:55:14 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 22:06:16 - Updating systems & servers data ...
. 2016.07.16 22:06:18 - Systems & servers data update completed
. 2016.07.16 22:37:05 - Updating systems & servers data ...
. 2016.07.16 22:37:18 - Systems & servers data update completed
I 2016.07.16 22:55:12 - Renewing TLS key
. 2016.07.16 22:55:12 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 22:55:14 - OpenVPN > TLS: soft reset sec=0 bytes=269122759/0 pkts=379891/0
. 2016.07.16 22:55:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 22:55:14 - OpenVPN > Validating certificate key usage
. 2016.07.16 22:55:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 22:55:14 - OpenVPN > VERIFY KU OK
. 2016.07.16 22:55:14 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 22:55:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 22:55:14 - OpenVPN > VERIFY EKU OK
. 2016.07.16 22:55:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 22:55:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 22:55:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 22:55:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 22:55:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 22:55:17 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.16 23:07:35 - Updating systems & servers data ...
. 2016.07.16 23:07:36 - Systems & servers data update completed
. 2016.07.16 23:38:31 - Updating systems & servers data ...
. 2016.07.16 23:38:33 - Systems & servers data update completed
I 2016.07.16 23:55:14 - Renewing TLS key
. 2016.07.16 23:55:14 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.16 23:55:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.16 23:55:18 - OpenVPN > Validating certificate key usage
. 2016.07.16 23:55:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.16 23:55:18 - OpenVPN > VERIFY KU OK
. 2016.07.16 23:55:18 - OpenVPN > Validating certificate extended key usage
. 2016.07.16 23:55:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.16 23:55:18 - OpenVPN > VERIFY EKU OK
. 2016.07.16 23:55:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.16 23:55:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 23:55:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 23:55:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.16 23:55:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.16 23:55:20 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 00:08:51 - Updating systems & servers data ...
. 2016.07.17 00:08:59 - Systems & servers data update completed
. 2016.07.17 00:39:42 - Updating systems & servers data ...
. 2016.07.17 00:39:43 - Systems & servers data update completed
I 2016.07.17 00:55:16 - Renewing TLS key
. 2016.07.17 00:55:16 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 00:55:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 00:55:20 - OpenVPN > Validating certificate key usage
. 2016.07.17 00:55:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 00:55:20 - OpenVPN > VERIFY KU OK
. 2016.07.17 00:55:20 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 00:55:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 00:55:20 - OpenVPN > VERIFY EKU OK
. 2016.07.17 00:55:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 00:55:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 00:55:21 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 00:55:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 00:55:21 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 00:55:21 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 01:10:19 - Updating systems & servers data ...
. 2016.07.17 01:10:20 - Systems & servers data update completed
. 2016.07.17 01:40:53 - Updating systems & servers data ...
. 2016.07.17 01:40:54 - Systems & servers data update completed
. 2016.07.17 01:55:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 01:55:15 - OpenVPN > Validating certificate key usage
. 2016.07.17 01:55:15 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 01:55:15 - OpenVPN > VERIFY KU OK
. 2016.07.17 01:55:15 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 01:55:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 01:55:15 - OpenVPN > VERIFY EKU OK
. 2016.07.17 01:55:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 01:55:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 01:55:17 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 01:55:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 01:55:17 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 01:55:17 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 02:11:42 - Updating systems & servers data ...
. 2016.07.17 02:11:44 - Systems & servers data update completed
. 2016.07.17 02:42:39 - Updating systems & servers data ...
. 2016.07.17 02:42:40 - Systems & servers data update completed
I 2016.07.17 02:55:15 - Renewing TLS key
. 2016.07.17 02:55:15 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 02:55:17 - OpenVPN > TLS: soft reset sec=0 bytes=194567558/0 pkts=272952/0
. 2016.07.17 02:55:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 02:55:17 - OpenVPN > Validating certificate key usage
. 2016.07.17 02:55:17 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 02:55:17 - OpenVPN > VERIFY KU OK
. 2016.07.17 02:55:17 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 02:55:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 02:55:17 - OpenVPN > VERIFY EKU OK
. 2016.07.17 02:55:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 02:55:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 02:55:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 02:55:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 02:55:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 02:55:18 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 03:13:09 - Updating systems & servers data ...
. 2016.07.17 03:13:11 - Systems & servers data update completed
. 2016.07.17 03:44:32 - Updating systems & servers data ...
. 2016.07.17 03:44:39 - Systems & servers data update completed
I 2016.07.17 03:55:17 - Renewing TLS key
. 2016.07.17 03:55:17 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 03:55:18 - OpenVPN > TLS: soft reset sec=0 bytes=1165265937/0 pkts=1309392/0
. 2016.07.17 03:55:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 03:55:18 - OpenVPN > Validating certificate key usage
. 2016.07.17 03:55:18 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 03:55:18 - OpenVPN > VERIFY KU OK
. 2016.07.17 03:55:18 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 03:55:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 03:55:18 - OpenVPN > VERIFY EKU OK
. 2016.07.17 03:55:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 03:55:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 03:55:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 03:55:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 03:55:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 03:55:19 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 04:14:58 - Updating systems & servers data ...
. 2016.07.17 04:14:59 - Systems & servers data update completed
. 2016.07.17 04:45:21 - Updating systems & servers data ...
. 2016.07.17 04:45:23 - Systems & servers data update completed
I 2016.07.17 04:55:18 - Renewing TLS key
. 2016.07.17 04:55:18 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 04:55:19 - OpenVPN > TLS: soft reset sec=0 bytes=233301899/0 pkts=328699/0
. 2016.07.17 04:55:19 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 04:55:19 - OpenVPN > Validating certificate key usage
. 2016.07.17 04:55:19 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 04:55:19 - OpenVPN > VERIFY KU OK
. 2016.07.17 04:55:19 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 04:55:19 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 04:55:19 - OpenVPN > VERIFY EKU OK
. 2016.07.17 04:55:19 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 04:55:20 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 04:55:20 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 04:55:20 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 04:55:20 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 04:55:20 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 05:15:32 - Updating systems & servers data ...
. 2016.07.17 05:15:34 - Systems & servers data update completed
. 2016.07.17 05:45:51 - Updating systems & servers data ...
. 2016.07.17 05:45:52 - Systems & servers data update completed
I 2016.07.17 05:55:19 - Renewing TLS key
. 2016.07.17 05:55:19 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 05:55:20 - OpenVPN > TLS: soft reset sec=0 bytes=212919884/0 pkts=266892/0
. 2016.07.17 05:55:20 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 05:55:20 - OpenVPN > Validating certificate key usage
. 2016.07.17 05:55:20 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 05:55:20 - OpenVPN > VERIFY KU OK
. 2016.07.17 05:55:20 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 05:55:20 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 05:55:20 - OpenVPN > VERIFY EKU OK
. 2016.07.17 05:55:20 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 05:55:21 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 05:55:21 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 05:55:21 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 05:55:21 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 05:55:21 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 06:16:10 - Updating systems & servers data ...
. 2016.07.17 06:16:11 - Systems & servers data update completed
. 2016.07.17 06:46:25 - Updating systems & servers data ...
. 2016.07.17 06:46:26 - Systems & servers data update completed
I 2016.07.17 06:55:20 - Renewing TLS key
. 2016.07.17 06:55:20 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 06:55:21 - OpenVPN > TLS: soft reset sec=0 bytes=213225290/0 pkts=259269/0
. 2016.07.17 06:55:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 06:55:21 - OpenVPN > Validating certificate key usage
. 2016.07.17 06:55:21 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 06:55:21 - OpenVPN > VERIFY KU OK
. 2016.07.17 06:55:21 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 06:55:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 06:55:21 - OpenVPN > VERIFY EKU OK
. 2016.07.17 06:55:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 06:55:22 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 06:55:22 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 06:55:22 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 06:55:22 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 06:55:22 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 07:16:38 - Updating systems & servers data ...
. 2016.07.17 07:16:39 - Systems & servers data update completed
. 2016.07.17 07:46:52 - Updating systems & servers data ...
. 2016.07.17 07:46:54 - Systems & servers data update completed
I 2016.07.17 07:55:21 - Renewing TLS key
. 2016.07.17 07:55:21 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 07:55:22 - OpenVPN > TLS: soft reset sec=0 bytes=236101110/0 pkts=319176/0
. 2016.07.17 07:55:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 07:55:22 - OpenVPN > Validating certificate key usage
. 2016.07.17 07:55:22 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 07:55:22 - OpenVPN > VERIFY KU OK
. 2016.07.17 07:55:22 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 07:55:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 07:55:22 - OpenVPN > VERIFY EKU OK
. 2016.07.17 07:55:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 07:55:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 07:55:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 07:55:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 07:55:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 07:55:23 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 08:17:02 - Updating systems & servers data ...
. 2016.07.17 08:17:03 - Systems & servers data update completed
. 2016.07.17 08:48:09 - Updating systems & servers data ...
. 2016.07.17 08:48:10 - Systems & servers data update completed
I 2016.07.17 08:55:22 - Renewing TLS key
. 2016.07.17 08:55:22 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 08:55:23 - OpenVPN > TLS: soft reset sec=0 bytes=252179535/0 pkts=365885/0
. 2016.07.17 08:55:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 08:55:23 - OpenVPN > Validating certificate key usage
. 2016.07.17 08:55:23 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 08:55:23 - OpenVPN > VERIFY KU OK
. 2016.07.17 08:55:23 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 08:55:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 08:55:23 - OpenVPN > VERIFY EKU OK
. 2016.07.17 08:55:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 08:55:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 08:55:24 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 08:55:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 08:55:24 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 08:55:24 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 09:19:02 - Updating systems & servers data ...
. 2016.07.17 09:19:03 - Systems & servers data update completed
. 2016.07.17 09:49:27 - Updating systems & servers data ...
. 2016.07.17 09:49:30 - Systems & servers data update completed
I 2016.07.17 09:55:23 - Renewing TLS key
. 2016.07.17 09:55:23 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 09:55:24 - OpenVPN > TLS: soft reset sec=0 bytes=250581123/0 pkts=320129/0
. 2016.07.17 09:55:24 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 09:55:24 - OpenVPN > Validating certificate key usage
. 2016.07.17 09:55:24 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 09:55:24 - OpenVPN > VERIFY KU OK
. 2016.07.17 09:55:24 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 09:55:24 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 09:55:24 - OpenVPN > VERIFY EKU OK
. 2016.07.17 09:55:24 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 09:55:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 09:55:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 09:55:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 09:55:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 09:55:25 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 10:20:00 - Updating systems & servers data ...
. 2016.07.17 10:20:01 - Systems & servers data update completed
. 2016.07.17 10:50:19 - Updating systems & servers data ...
. 2016.07.17 10:50:20 - Systems & servers data update completed
I 2016.07.17 10:55:24 - Renewing TLS key
. 2016.07.17 10:55:24 - OpenVPN > TLS: tls_process: killed expiring key
. 2016.07.17 10:55:25 - OpenVPN > TLS: soft reset sec=0 bytes=397505535/0 pkts=484501/0
. 2016.07.17 10:55:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 10:55:25 - OpenVPN > Validating certificate key usage
. 2016.07.17 10:55:25 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 10:55:25 - OpenVPN > VERIFY KU OK
. 2016.07.17 10:55:25 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 10:55:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 10:55:25 - OpenVPN > VERIFY EKU OK
. 2016.07.17 10:55:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 10:55:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 10:55:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 10:55:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 10:55:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 10:55:26 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 11:04:25 - OpenVPN > write TCPv4_CLIENT: Connection reset by peer (WSAECONNRESET) (code=10054)
. 2016.07.17 11:04:25 - OpenVPN > Connection reset, restarting [-1]
! 2016.07.17 11:04:25 - Disconnecting
. 2016.07.17 11:04:31 - Management - Send 'signal SIGTERM'
. 2016.07.17 11:04:36 - OpenVPN > SIGUSR1[soft,connection-reset] received, process restarting
. 2016.07.17 11:04:40 - OpenVPN > Restart pause, 5 second(s)
. 2016.07.17 11:04:42 - Management - Send 'signal SIGTERM'
. 2016.07.17 11:04:44 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2016.07.17 11:04:44 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.142:443 [nonblock]
. 2016.07.17 11:04:45 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.07.17 11:04:45 - OpenVPN > C:\Windows\system32\route.exe DELETE 66.211.169.3 MASK 255.255.255.255 192.168.0.1
. 2016.07.17 11:04:46 - OpenVPN > ROUTE: route deletion failed using DeleteIpForwardEntry: Kan element niet vinden.
. 2016.07.17 11:04:46 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.07.17 11:04:46 - OpenVPN > Route deletion fallback to route.exe
. 2016.07.17 11:04:46 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.17 11:04:51 - Management - Send 'signal SIGTERM'
. 2016.07.17 11:04:52 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2016.07.17 11:04:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 62.102.148.142 MASK 255.255.255.255 192.168.0.1
. 2016.07.17 11:04:54 - OpenVPN > ROUTE: route deletion failed using DeleteIpForwardEntry: Kan element niet vinden.
. 2016.07.17 11:04:54 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2016.07.17 11:04:54 - OpenVPN > Route deletion fallback to route.exe
. 2016.07.17 11:04:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.17 11:04:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 192.168.0.1 MASK 255.255.255.255 192.168.0.1
. 2016.07.17 11:04:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.17 11:04:54 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2016.07.17 11:04:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.17 11:04:54 - OpenVPN > Closing TUN/TAP interface
. 2016.07.17 11:04:54 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2016.07.17 11:04:57 - Connection terminated.
I 2016.07.17 11:05:15 - DNS of a network adapter restored to original settings (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.17 11:05:15 - DNS of a network adapter restored to original settings (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.17 11:05:16 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.07.17 11:05:16 - DNS of a network adapter restored to original settings (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.17 11:05:42 - Checking authorization ...
! 2016.07.17 11:05:42 - Connecting to Alrami (Sweden, Uppsala)
. 2016.07.17 11:05:45 - OpenVPN > OpenVPN 2.3.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Jan 12 2015
. 2016.07.17 11:05:45 - OpenVPN > library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
. 2016.07.17 11:05:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.07.17 11:05:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.07.17 11:05:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 11:05:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 11:05:45 - OpenVPN > Socket Buffers: R=[8192->8192] S=[8192->8192]
. 2016.07.17 11:05:45 - OpenVPN > Attempting to establish TCP connection with [AF_INET]62.102.148.145:443 [nonblock]
. 2016.07.17 11:05:46 - OpenVPN > TCP connection established with [AF_INET]62.102.148.145:443
. 2016.07.17 11:05:46 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2016.07.17 11:05:46 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]62.102.148.145:443
. 2016.07.17 11:05:46 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.145:443, sid=e4192879 ebb234b9
. 2016.07.17 11:05:47 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.07.17 11:05:47 - OpenVPN > Validating certificate key usage
. 2016.07.17 11:05:47 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.07.17 11:05:47 - OpenVPN > VERIFY KU OK
. 2016.07.17 11:05:47 - OpenVPN > Validating certificate extended key usage
. 2016.07.17 11:05:47 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.07.17 11:05:47 - OpenVPN > VERIFY EKU OK
. 2016.07.17 11:05:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.07.17 11:05:49 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 11:05:49 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 11:05:49 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.07.17 11:05:49 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.07.17 11:05:49 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2016.07.17 11:05:49 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]62.102.148.145:443
. 2016.07.17 11:05:51 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.07.17 11:05:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.5.0.1,comp-lzo no,route-gateway 10.5.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.5.1.195 255.255.0.0'
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.07.17 11:05:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.07.17 11:05:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.07.17 11:05:52 - OpenVPN > open_tun, tt->ipv6=0
. 2016.07.17 11:05:53 - OpenVPN > TAP-WIN32 device [LAN-verbinding 2] opened: \\.\Global\{803E74C5-D35D-4D62-BC35-D64DC578DDC0}.tap
. 2016.07.17 11:05:53 - OpenVPN > TAP-Windows Driver Version 9.21
. 2016.07.17 11:05:53 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.0.0/10.5.1.195/255.255.0.0 [sUCCEEDED]
. 2016.07.17 11:05:53 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.1.195/255.255.0.0 on interface {803E74C5-D35D-4D62-BC35-D64DC578DDC0} [DHCP-serv: 10.5.255.254, lease-time: 31536000]
. 2016.07.17 11:05:53 - OpenVPN > Successful ARP Flush on interface [24] {803E74C5-D35D-4D62-BC35-D64DC578DDC0}
. 2016.07.17 11:05:57 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=1 u/d=up
. 2016.07.17 11:05:57 - OpenVPN > C:\Windows\system32\route.exe ADD 62.102.148.145 MASK 255.255.255.255 192.168.0.1
. 2016.07.17 11:05:57 - OpenVPN > Warning: route gateway is ambiguous: 192.168.0.1 (2 matches)
. 2016.07.17 11:05:57 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.07.17 11:05:57 - OpenVPN > Route addition fallback to route.exe
. 2016.07.17 11:05:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.17 11:05:58 - OpenVPN > C:\Windows\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 30
. 2016.07.17 11:05:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2016.07.17 11:05:58 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.07.17 11:05:58 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.17 11:05:58 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.07.17 11:05:58 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.0.1
. 2016.07.17 11:05:58 - OpenVPN > C:\Windows\system32\route.exe ADD 66.211.169.3 MASK 255.255.255.255 192.168.0.1
. 2016.07.17 11:05:58 - OpenVPN > Warning: route gateway is ambiguous: 192.168.0.1 (2 matches)
. 2016.07.17 11:05:58 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.07.17 11:05:58 - OpenVPN > Route addition fallback to route.exe
. 2016.07.17 11:05:58 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.07.17 11:05:58 - Starting Management Interface
. 2016.07.17 11:05:58 - OpenVPN > Initialization Sequence Completed
I 2016.07.17 11:05:58 - DNS of a network adapter forced (VMware Virtual Ethernet Adapter for VMnet1)
I 2016.07.17 11:05:59 - DNS of a network adapter forced (Broadcom 4313GN 802.11b/g/n 1x1 Wi-Fi-adapter)
I 2016.07.17 11:05:59 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.07.17 11:06:00 - DNS of a network adapter forced (Linksys WUSB600N Wireless-N USB Network Adapter with Dual-Band ver. 2 #3)
I 2016.07.17 11:06:01 - Flushing DNS
I 2016.07.17 11:06:04 - Checking DNS
! 2016.07.17 11:06:07 - Connected.
. 2016.07.17 11:06:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.07.17 11:06:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Hello !
Try changing your TAP drivers. You may also want to disable adapters you don't use.
And please put your logs into spoilers. You can see it's not very friendly for us to read, that the logs take up the whole page.
In preferences>advance;  change your send and receive buffers from 8K to either 256K or 512K.
Which version of the eddie client are you using since your logfile shows OpenVPN 2.3.6.
Eddie client 2.10.3 uses OpenVPN 2.3.10.
Eddie experimental 2.11 used OpenVPN 2.3.11.
Check with AirVPN support about the OpenVPN 2.3.6 that you are using.
