cm0s 118 Posted ... itz all about the pup treatz.... 1 Tech Jedi Alex reacted to this Quote Share this post Link to post
Tech Jedi Alex 1526 Posted ... Interesting. Thank you! Downloading as I speak. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
OmniNegro 155 Posted ... giganerd, zhang or anyone didn't want to start a new thread for this kinda off topic but here goes, is there a way for me to be able to set my local from my router to static and not have comcast kick my whole network down after a few days ? so if i shut off the dhcp server on the router, already got my dns static either way to airvpn, what in the world do they do to figure it out anyway ? i got my server, my boxes etc and security cam like to have them all static but things will work for about a week then i get kicked after i shut everything down go back to dhcp i'm online againbasically what i do is i shut off dhcp on the router, set the netctl and other files to static, things are fine, then yup, down she goesor maybe i'm doing something wrong or not understanding networking right, which has been known to be a possibility or is this their way of 'forcing' their business accounts on consumers ? coz yeah everytime power goes down good chance i gotta edit my firewall scripts and redo other files blah blah, i can live with it but a pain, and how in the world do they know ? anything i google on this just brings up tutorials on static scoured comcast forums didn't see anything eitherthanx cm0sI have no idea if it will work for what you want, but the DDNS option sounds perfect for you.https://airvpn.org/ports/ Just make sure you setup a DDNS name you will remember, and note that it is all lowercase. So if you setup "example.airvpn.org" it may not work as "Example.airvpn.org" or any other such thing. (Or it might. I never tried.) And if you are forgetful, you can go to that link and see what you set it to. This way, Comcast cannot force you into anything. DDNS is the solution to many of the problems of rotating IPs. Quote Hide OmniNegro's signature Hide all signatures Debugging is at least twice as hard as writing the program in the first place.So if you write your code as clever as you can possibly make it, then by definition you are not smart enough to debug it. Share this post Link to post
cm0s 118 Posted ... got a hold of comcast figured out what i was doing wrongwhat i was doing wrong was in the ddwrt from my sb6121 moto modem i'd cat 5 to the ddwrtwhat i was doing was i saw 'dhcp automatic'and made that static not understanding that that was thesetting for comcast's side of my local down below i set thingsas usual to static dns settings blah blahthanx for the help everyone finally got it solid very happy cheerz 1 OmniNegro reacted to this Quote Share this post Link to post
zhang888 1067 Posted ... I did not quite understand the question. Can you please form it according to some basic format i.e.1) The symptom / the issue, as it see on your side - 1/2 lines.2) The way you would like to have it set - 2/3 lines.3) Some steps you tried to get this done - 1/2 lines. Regarding how ISPs can tunnel into your network bypassing your VPN, is for example the DOCSIS protocol,the only one that is used for cable modems all over the world. In this way, when your modem boots up, itsends and receives information from your ISP on the coax interface, allowing them to SNMP to the deviceas well, and many ISPs have their CMTS (big cable routers) SNMP to the subscriber modems once in a whileand check the settings. Mostly for debugging though, I cannot say it is done for the purpose to invade privacy.They mostly check the uptime of the modem services, the signal strength, the firmware version, and in casesomething is wrong the first step is usually sending a firmware upgrade package and a reboot, then calling upa cable technician to your home. If you ever had a call from your ISP, telling that a technician has to arrive and fix your line, that is probably anautomatic alert your modem sent, again over the DOCSIS protocol to your cable provider.ADSL has something similar and it is called TR-069. What you have to do in order to avoid this, is using your ISP CPE as a modem only, and connecting a separaterouter to your devices, while using your modems LAN as a separate router's WAN.There is no way for you to reliably disable DHCP on devices you don't fully control, and in fact are not truly yours,as I believe you have to return this device if you plan to switch your ISP, so it's their right to do so. 1 LZ1 reacted to this Quote Hide zhang888's signature Hide all signatures Occasional moderator, sometimes BOFH. Opinions are my own, except when my wife disagrees. Share this post Link to post
LZ1 679 Posted ... I did not quite understand the question. Can you please form it according to some basic format i.e.1) The symptom / the issue, as it see on your side - 1/2 lines.2) The way you would like to have it set - 2/3 lines.3) Some steps you tried to get this done - 1/2 lines. Regarding how ISPs can tunnel into your network bypassing your VPN, is for example the DOCSIS protocol,the only one that is used for cable modems all over the world. In this way, when your modem boots up, itsends and receives information from your ISP on the coax interface, allowing them to SNMP to the deviceas well, and many ISPs have their CMTS (big cable routers) SNMP to the subscriber modems once in a whileand check the settings. Mostly for debugging though, I cannot say it is done for the purpose to invade privacy.They mostly check the uptime of the modem services, the signal strength, the firmware version, and in casesomething is wrong the first step is usually sending a firmware upgrade package and a reboot, then calling upa cable technician to your home. If you ever had a call from your ISP, telling that a technician has to arrive and fix your line, that is probably anautomatic alert your modem sent, again over the DOCSIS protocol to your cable provider.ADSL has something similar and it is called TR-069. What you have to do in order to avoid this, is using your ISP CPE as a modem only, and connecting a separaterouter to your devices, while using your modems LAN as a separate router's WAN.There is no way for you to reliably disable DHCP on devices you don't fully control, and in fact are not truly yours,as I believe you have to return this device if you plan to switch your ISP, so it's their right to do so.Hello ! zhang have you ever heard the joke: If you don't know your TLAs then you will be engaging in CLAs?Aka, if you don't know your Three Letter Acronyms, you'll be engaging in Career Limiting Activities. Hahaha.Thanks for the info zhang. Thanks for the post OP - was a good doc. 1 cm0s reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
