karn
Ticketmaster blocked by airvpn.org US servers
Hello !
Do you mean http://www.ticketmaster.com/?tm_link=tm_logo ? It would be nice with a link, both for convenience and to be 100% sure.
Because I had no problems accessing the site; albeit I'm not using a us server. So if it's purely for notification purposes, that's nice of you. Otherwise, you could try change servers
Checking the routes does yield failure across the board though, on my screen, except for two Romanian servers which got a 403 forbidden code.
Did you get any message about the block? If so, maybe it would be helpful to post here, if you'd like.
