Not connected, Your IP: 216.73.216.169
itsamemario
ANSWERED Forced quited and broke something
A bit ago I force quited the airvpn deamon, and now I can't use it anymore.
I may have broke something, but I can't figure out what.
Here is what the console shows:
Thanks for the advice, but it does not work.
Does airvpn write some conf file somewhere? Like to store the password and the login?
Yes, it's AirVPN.xml (see the logs for the path). You can try to delete it, just in case it's corrupt.
